Go to Post Just be nice. It works better in the long run. - Libby K [more]
Unread 05-02-2008, 15:54
SuperSexcGuy SuperSexcGuy is offline
Junior Member
AKA: Achmed
FRC #1514 (QWERTYUIOPASDFGHJKLZXCVBNM)
Team Role: Mascot
Rookie Year: 1965
SuperSexcGuy is an unknown quantity at this point
IR SENSOR BOARD
hi im SuperSexcGuy and i was wondering how will i know if my ir sensor board works or not... I used a 9V battery to turn it on but i got no results..the chip does not turn on Can some one please tell me how i can find out if i need a new 1?
Unread 05-02-2008, 16:35
Re: IR SENSOR BOARD
If the LEDs do not light as expected when you correctly follow the directions in the IR board documentation, it is possible that your IR board is faulty. You can check to make sure the 5 volt regulator is indeed providing 5 volts; if it is not, you can try replacing it to see if that makes the board work properly.
(For what it's worth, I think you'll be more likely to get constructive advice if you identified yourself and your team with a less foolish attitude.)
Unread 05-02-2008, 17:49
GrammarNazi GrammarNazi is offline
FRC #2952
GrammarNazi is on a distinguished road
Send a message via AIM to GrammarNazi
Re: IR SENSOR BOARD
He is the mascot though.
First one to reply gets a cookie!!!
Unread 05-02-2008, 17:50
hunter7 hunter7 is offline
AKA: Spence
FRC #2226 (Broncos)
hunter7 is an unknown quantity at this point
Send a message via MSN to hunter7
Re: IR SENSOR BOARD
We had the same thing happen, we programmed it and then put it away for the day. The next day it wouldn't turn on, so we have no idea what to do.
Unread 05-02-2008, 20:12
Miner Miner is offline
AKA: Jacob Miner
FRC #2077 (Laser Robotics)
Miner is on a distinguished road
Re: IR SENSOR BOARD
Make sure that you have the positive lead connected to pins 1 and/or 2 and negative to pins 3 and/or 4. If you did it backwards, you might have seen a puff of smoke or a wierd noise or something. That would mean that your voltage regulator is blown.
If that is not the case and the voltage regulator is putting out 5 volts, contact FIRST... other teams have come up with faulty boards.
Good luck!
Do what you like... Like what you do!
Jake, the Life Is Good guy
Unread 05-02-2008, 20:35
Bochek's Avatar
Bochek Bochek is offline
AKA: Adam Bochek
FRC #2200 (MMRambotics)
Bochek has much to be proud ofBochek has much to be proud ofBochek has much to be proud ofBochek has much to be proud ofBochek has much to be proud ofBochek has much to be proud ofBochek has much to be proud ofBochek has much to be proud ofBochek has much to be proud ofBochek has much to be proud of
Re: IR SENSOR BOARD
We ran into the same problem today.
It was working fine (as it has been for the last 2 weeks), we moved the robot to another room and it no longer works.
Took it all apart and tested it,
Power regulator is fine, and everything checks out okay, but no led's are lighting and the board is not functioning, my guess is that a low voltage situation caused the PIC16F chip on the board to loose its memory. The board probably requires a re-program which we can do if we had the code.
- Bochek
Adam Bochek - FRC 2200
http://www.mmrambotics.com
http://www.watchfirstnow.com
Unread 06-02-2008, 00:29
urg8rb8 urg8rb8 is offline
FRC #0108
urg8rb8 is an unknown quantity at this point
Re: IR SENSOR BOARD
We have experienced a problem today with our IR board as well. Our board would power up (so the voltage regulator seems to be working correctly), go through the regular training, but then would stop detecting any of the signals. We were able to get it working before using the same remote but all of a sudden it stopped working. Not sure why.
I have read that some teams have been able to reflash the microcontrollers on these boards. Can someone please provide some information on how to obtain the microcontroller software, the programmer, and the program cabling?
That would be greatly appreciated! Thank you!
Unread 06-02-2008, 09:24
EricS-Team180's Avatar
EricS-Team180 EricS-Team180 is offline
SPAM, the lunchmeat of superheroes!
AKA: Eric Schreffler
FRC #0180 (SPAM)
EricS-Team180 has a reputation beyond reputeEricS-Team180 has a reputation beyond reputeEricS-Team180 has a reputation beyond reputeEricS-Team180 has a reputation beyond reputeEricS-Team180 has a reputation beyond reputeEricS-Team180 has a reputation beyond reputeEricS-Team180 has a reputation beyond reputeEricS-Team180 has a reputation beyond reputeEricS-Team180 has a reputation beyond reputeEricS-Team180 has a reputation beyond reputeEricS-Team180 has a reputation beyond repute
Re: IR SENSOR BOARD
Dang! Same thing happenned to us! We were speculating that we could re-flash the PIC. ...looks like I'll go searching. Frankly we're been very "gentle" with this board, since it is a new "toy". If these problems are common, I'll have to doubt it usefulness in competition. .....we'll see
Eric
Don't PANIC!
S. P. A. M.
Wiring the IR sensor board govvijay Programming 9 05-02-2008 19:41
ir sensor Board ?????????????????????? RRA4LIFE2 Programming 12 31-01-2008 23:16
Hooking up the IR sensor board chattycat14 Programming 0 30-01-2008 15:57
How to program ir sensor board?? RRA4LIFE2 Programming 1 11-01-2008 21:47
Making a Sensor Board SpaceOsc Technical Discussion 11 15-05-2004 12:46
