Go to Post Winning or losing on the field has nothing to do with this success. - E. Wood [more]
Unread 05-02-2008, 09:24
Steven S's Avatar
Steven S Steven S is offline
Steven
FRC #0701 (Robovikes)
Team Role: Electrical
Steven S is an unknown quantity at this point
What do you think about mounting an air compressor vertically?
This year we've crammed too much stuff in our robot and our compresor wouldn't fit, so we're gonna put it vertically, we put surgical tubing between the 4 bolts and the fiberglass we're using and it doesn't let it shake the whole system. What do you guys think? there isnt a rule against this is there?
Unread 05-02-2008, 09:37
Miner Miner is offline
AKA: Jacob Miner
FRC #2077 (Laser Robotics)
Miner is on a distinguished road
Re: What do you think about mounting an air compressor vertically?
I don't know if there is a rule against it, but i would find it a little dangerous.
First of all, the heat that the compressed air creates would be enough to maybe melt the rubber of pnumatic tubing or some wires. Be careful that you dont place the compressor near any of that.
Second, You want to be able to secure the compressor to the frame, but allow it to move a little. The legs that came with it in the Kit of Parts are vibration reducers. I would suggest using them, but also secure the robot.
Check section 8 of the rule book, pnumatics manual on the FIRST website and look for that rule.
Good luck!
Jacob
Unread 05-02-2008, 09:42
Steven S's Avatar
Steven
yeah we don't have tubing near it, and we tested the surgical tubing around the bolts (it works as good or better than the rubber bolts that came with it)
I really don't think there's a rule against it.
Just a warning to everyone else.........if you do this, after taking the plate off make sure NOTHING gets in your compressor......safety purposes.
Unread 05-02-2008, 10:01
AKA: Jacob Miner
Good Point. We are also going to try and put one of the large fans above our compressor to blow air down on to it and cool it off... it might help.
Unread 05-02-2008, 12:02
dlavery's Avatar
dlavery dlavery is offline
Curmudgeon
FRC #0116 (Epsilon Delta)
Just to clarify, are you saying you took the metal plate off the front of the compressor? If so, that is a big no-no. Rule <R92>.
-dave
Unread 05-02-2008, 13:12
iwashere1990's Avatar
iwashere1990 iwashere1990 is offline
Team 1389's Everything
AKA: Jason
FRC #1389 (The Stig)
iwashere1990 is an unknown quantity at this point
I think he means he replaced the rubber footings that came with the compressor. Then crafted new ones with the surgical tubing and bolts
I Think...
"Achievement is not always success while reputed failure often is. It is honest endeavor, persistent effort to do the best possible under any and all circumstances."
Team Number:1389
My Job on the Team:Everything but Programing
My Rookie Year:2007
My Team's Rookie Year:2004
Awards: Zero
Number of Members: 7-9
Number of Mentors: 1 (more like zero)
Our Current Budget for the Team: -6,000$
Number of Headaches this Year: 4
Number of Colds: 1
Number of PHAILS: > 10
Unread 05-02-2008, 13:17
Rosiebotboss's Avatar
Rosiebotboss Rosiebotboss is offline
2015-16 Divisional LRI - Archimedes
AKA: Dana P. Henry
FRC #0839 (Rosie Robotics)
Rosiebotboss has a reputation beyond reputeRosiebotboss has a reputation beyond reputeRosiebotboss has a reputation beyond reputeRosiebotboss has a reputation beyond reputeRosiebotboss has a reputation beyond reputeRosiebotboss has a reputation beyond reputeRosiebotboss has a reputation beyond reputeRosiebotboss has a reputation beyond reputeRosiebotboss has a reputation beyond reputeRosiebotboss has a reputation beyond reputeRosiebotboss has a reputation beyond repute
Send a message via AIM to Rosiebotboss
Exactly what plate are you talking about? You didn't modify the compressor in any way, did you?
If you did, don't show up at my inspection station with a modified compressor. (Or any other inspector for that matter!)
Co-Founder/Mentor FRC Team 839 / JrFLL Team 137/Rosie Robotics/Agawam HS
Winner NEF District WPI 2016
Regional CA-08 Boston, 12 WPI, Eng'g Excellence, 12-15 UL Safety, 15 Motorola Quality
KPCB Entrepreneurship 04, 05, 06, 07, 10, 11, 13, 14, 15, 16
Rookie All Star and Top Rookie Seed 2002
Paul Harris Fellow, CMP Inspector 05-16, Head LRI NE FIRST JTB 1944-2008 "What did you do with your dash?"
Unread 05-02-2008, 13:26
camtunkpa camtunkpa is online now
it's like shooting fish in a barrel
AKA: Cliff Mock
FRC #0222 (Tigertrons)
camtunkpa has a reputation beyond reputecamtunkpa has a reputation beyond reputecamtunkpa has a reputation beyond reputecamtunkpa has a reputation beyond reputecamtunkpa has a reputation beyond reputecamtunkpa has a reputation beyond reputecamtunkpa has a reputation beyond reputecamtunkpa has a reputation beyond reputecamtunkpa has a reputation beyond reputecamtunkpa has a reputation beyond reputecamtunkpa has a reputation beyond repute
As other have mentioned, as long as you didn't modify the compressor itself you should be fine. As far as rules I don't think there are any rules about the position of the air compressor. 222 ran out of space in 2005 and our compressor ended up mounted upside down
"Engineering is making the impossible happen"
"We are here to create, not merely survive" - unknown fortune cookie
"If you don't push the envelope you're just spinning your wheels"
Unread 05-02-2008, 14:30
TubaMorg TubaMorg is offline
Programmermechanicalelect ricalcoach
AKA: Dan
FRC #1480 (Robatos Locos)
TubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond repute
In addition to what's already been said:
Not all motors are designed to run in a vertical orientation. As in there may not be thrust bearings designed to take an axial load like you would see when mounted in a vertical position. Running the compressor like this may lead to failure. Then again I could be wrong!
Andrew Bates's Avatar
Andrew Bates Andrew Bates is offline
AKA: Bates
FRC #0125 (NUTRONS)
Andrew Bates has a reputation beyond reputeAndrew Bates has a reputation beyond reputeAndrew Bates has a reputation beyond reputeAndrew Bates has a reputation beyond reputeAndrew Bates has a reputation beyond reputeAndrew Bates has a reputation beyond reputeAndrew Bates has a reputation beyond reputeAndrew Bates has a reputation beyond reputeAndrew Bates has a reputation beyond reputeAndrew Bates has a reputation beyond reputeAndrew Bates has a reputation beyond repute
We mounted ours horizontally on its side at the front of our robot using the vibration isolators. We were worried that the compressor being on side might be too much for the vibration isolators but after 3 weeks it seems fine. The compressor seems to run fine too.
ME Student at Northeastern University, Captain of the NUTRONs #125 FRC
Former member of VEXELLENT and Cranbrook Robotics
Unread 05-02-2008, 14:39
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
While this is true, the effect a gravity imposed thrust load would be negligible in this circumstance.
Unread 05-02-2008, 15:33
The manufacturer does not list any restrictions in mounting orientation for this pump. The shock isolators will not give their design deflection when mounted on the side or upside down. That is not likely to be an issue in our designs.
Unread 05-02-2008, 17:28
ALIBI's Avatar
ALIBI ALIBI is offline
FRC #0141
Team Role: Parent
ALIBI is a name known to allALIBI is a name known to allALIBI is a name known to allALIBI is a name known to allALIBI is a name known to allALIBI is a name known to all
This year it does not matter to us, we are not using compressed air. In years past we have rotated the the head of the compressor so that the exhaust fittings are in a different direction. We always passed inspection. Would you consider that a modification? Is changing the orientation of the fittnigs a rule violation?
Unread 05-02-2008, 23:22
EricRobodox's Avatar
EricRobodox EricRobodox is offline
AKA: Eric... I think a lot
FRC #0599 (RoboDox)
EricRobodox has a brilliant futureEricRobodox has a brilliant futureEricRobodox has a brilliant futureEricRobodox has a brilliant futureEricRobodox has a brilliant futureEricRobodox has a brilliant futureEricRobodox has a brilliant futureEricRobodox has a brilliant futureEricRobodox has a brilliant futureEricRobodox has a brilliant futureEricRobodox has a brilliant future
Send a message via AIM to EricRobodox
careful with rotating the head. If you dont put the o-ring correctly back in, which is a pain in the butt sometimes, you will completely mess up the seal. We tried with an old compressor once and figured it was not worth the time.
when mounting, please keep in mind that the compressor heats up. If its going to be around electronics, make sure there is some breathing room where things can get cooled. Otherwise, you will have a hot area on the robot that wont be good for compressor, electronics components, or other part in the area sensitive to high temperatures.
My other car is being built to go to Mars in 2011.
Bet you aint got one of these...
Unread 06-02-2008, 01:24
Steven S's Avatar
Steven
we put the metal plate back on the compressor, we just took it off to replace the screws holding it with longer ones that we can use to mount it.
The 4 screws that came with it weren't long enough to go through the fiberglass supporting our compressor.
mounting vertically Nitroxextreme Electrical 4 11-02-2005 08:51
What do you think about openFIRST? blueWarrior FIRST-related Organizations 6 28-09-2003 17:31
What do YOU think about making agreements? punarhero General Forum 11 18-03-2003 19:56
What do you think about NEXT YEAR's GAME? Digo General Forum 20 17-04-2002 14:09
ANNOUNCEMENT: what do you think about IT? (tigerbolt chat) Joe Ross Dean Kamen's Inventions 3 02-12-2001 22:38
