Go to Post Not even close to ready...can we delay it till like...January 2010? - Cory [more]
Unread 06-02-2008, 08:07
Qbranch Qbranch is offline
wow college goes fast.
AKA: Alex
FRC #1024 (Kil-A-Bytes)
Qbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond repute
pic: Secondary Pneumatic Reservoir Array
Unread 06-02-2008, 08:08
Tytus Gerrish's Avatar
Tytus Gerrish Tytus Gerrish is offline
IGAB, ADHD, and Dislexic
AKA: Ty
FRC #0179 (SwampThing)
Team Role: Tactician
Tytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond repute
Re: pic: Secondary Pneumatic Reservoir Array
are those mounted on the back of a stolen street sign?
Unread 06-02-2008, 10:58
spazdemon548's Avatar
spazdemon548 spazdemon548 is offline
FRC #0548
spazdemon548 has a spectacular aura aboutspazdemon548 has a spectacular aura about
According to the Q and A forums, only 1 120 to 60 psi regulator is allowed between the compressor and your working side of the pneumatic.
It is permissible to use multiple Norgren regulators. But under Rule <R98>, and for the purposes of a predictable and reasonable inspection process, all regulators, valves, cylinders, and other elements of the "working system" must be located downstream from the (one) primary regulator. Any additional regulators (Norgren or otherwise) must be located downstream from this one primary regulator.
The answers to the other questions have been clarified to make sure this is understood.
http://forums.usfirst.org/showthread.php?t=8424
Unread 06-02-2008, 11:03
Matt C's Avatar
Matt C Matt C is offline
FRC #1468 (J-Birds)
Matt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond repute
Send a message via AIM to Matt C
Maybe they are running their tanks at 60 psi?
Unread 06-02-2008, 13:44
Mike AA's Avatar
Mike AA Mike AA is offline
Programmer and Mentor
AKA: Mike Aalderink
FRC #3458 (Code Blue)
Mike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to behold
Send a message via MSN to Mike AA
I honestly need to ask why have so many pressure guages and regulators? It doesn't make sense to regulate pressure to the tanks down lower but to regulate pressure to other items.
-Mike
EDIT: I see their ridea may be to allow more air flow (CFM) to the cylinders. Problem is that the primary regulator would still be the limiting factor.
Unread 06-02-2008, 13:57
Matt C's Avatar
FRC #1468 (J-Birds)
Not if their primary regulator is upstream of their tanks, and their tanks are running at 60 psi. If they are doing this, and regulating their secondaries to say, 30psi, they will get the airflow to allow the pistons to actuate faster without completely emptying their system every time.
I'm assuming that they are using 4 cylinders, each part of it's own leg off of the primary system, with only the output of the compressor flowing into the primary regulator.
Unread 06-02-2008, 19:23
TheNotoriousKid's Avatar
TheNotoriousKid TheNotoriousKid is offline
AKA: Shane O
FRC #0025 (Raider Robotix)
TheNotoriousKid is just really niceTheNotoriousKid is just really niceTheNotoriousKid is just really niceTheNotoriousKid is just really niceTheNotoriousKid is just really nice
Send a message via AIM to TheNotoriousKid
I don't know about it's legality, but it is neat.
Unread 06-02-2008, 20:58
AKA: Alex
Well, much as it bothers me... thanks for the rules update. We're currently working on some way of modifying our robot's launching system. Much better to find this out now rather than find out at a regional.
No, this is not the back of a stop sign, its just sanded aluminum. I think it'd be bad ju ju to use a stop sign anyways (perhaps a go sign... )
We will be removing the extra regulators but keeping the gauges (because it looks so neat!)
The regulator is the most limiting factor, so this was our way around it.
Aha! Late breaking news! They've just come in and said that it works even without the extra regulators, though it isn't as spectacular as it was before, still very serviceable.
Thanks guys,
-q
Electrical Engineer Illini
1024 | Programmer '06, '07, '08 | Driver '08
Unread 06-02-2008, 22:11
DonRotolo's Avatar
Back to humble
FRC #0832
Maybe you can paste photos of a bunch of regulators, just so it looks cool...
Unread 07-02-2008, 11:01
sporno's Avatar
sporno sporno is offline
AKA: David
FRC #0540 (Talon)
sporno will become famous soon enoughsporno will become famous soon enough
Send a message via AIM to sporno
ive heard of a wire tuck , but a tube tuck .. jeez that thing is clean man, cant wait to see more pictures of it ... giving me some ideas for my P-board.
2005 NASA/VCU Quarter-finalist
2006 NASA/VCU regional-Semi-finalist
2006 FIRST Robot Rumble-Quarter-finalist
2006 FIRST Robot Rumble-Most Promosing Rookie Drive team.
2006 Championship-Curie
2007 NASA/VCU- Regional Winner
2007 Championship-Galileo
2007 FIRST Robot Rumble-Semi-finalist
80+ matches on the field
Unread 09-02-2008, 21:19
martin417's Avatar
Opinionated old goat
AKA: Martin Wilson
We had the same problem, and found out that if you use two reservoirs at 120 PSI, go through the regulator, then use two reservoirs at 60 PSI to feed the valves, it works almost as well as multi regulators.
pic: 696 - Array of wheels sanddrag Extra Discussion 6 28-01-2007 13:54
array problems p1r0o2g7 Programming 2 27-01-2006 15:43
White Oaks Secondary School Little Lee132 Chit-Chat 0 08-04-2002 21:51
Secondary Robots K. Skontrianos General Forum 1 26-03-2002 23:36
polar array in 3ds Ghetto_Child 3D Animation and Competition 6 12-01-2002 18:55
