Go to Post Multitasking is a myth. - DonRotolo [more]
Unread 06-02-2008, 09:54
Jon Stratis's Avatar
Jon Stratis Jon Stratis is online now
Electrical/Programming Mentor
FRC #2177 (The Robettes)
Re: need help w/ bumper fastner designs
From what i can see, your bumper will fulfill the definition of a standard bumper - You build the standard bumper, and attached it to that metal arm with a secure nut and bolt system. That arm, i believe, needs to also be securely attached to the rest of the robot with nuts and bolts - a pin probably wouldn't suffice. Another team posted a similar question to the GDC:
http://forums.usfirst.org/showthread.php?t=8551
Thank you for pointing out our ambiguous/erroneous language. We will amend the inspection check-list so that bolt and nut fasteners are accepted. In your case, we suggest that the "quick disconnect" pin be a bolt-nut combination. Please be sure that the Bumpers you use are compliant with the rest of Rule <R08>.
Team 1276 Bumper Designs Uncrash Robot Showcase 4 07-02-2007 12:36
Help with designs Packmon_driver Technical Discussion 2 02-02-2006 15:06
Bumper material...Need to know name for price Denman Technical Discussion 1 23-02-2005 11:47
Bumper Sticker Designs Robby O Chit-Chat 11 15-07-2001 11:37
