Re: Rookie Team - Autonomous Mode Question
It is highly recommended that every team builds a disable switch similar to
http://www.andymark.biz/am-0016.html You can easily switch your robot from manual mode to auto mode. Then if you need to disable your robot without having to fumble with the power cord |
We love our AM selector switch. |
We incorporated disable and auto/teleop switches into our operator console last year. It's very convenient not to have to worry about misplacing a standalone dongle. I'm sure this year's console will have the same feature.
My team (2518) is a rookie team and we decided to use EasyC for the first year
The way I understand what you've said is.... We just put our Autonomous code into the Autonomous(); function, and the OperatorControl into the OperatorControl(); function. And then before the competition the staff attaches a piece of hardware to the Competition port on the Operator Interface board, and they'll call the proper function when it's time to switch states ? Same for the Initialize function I assume. |
If you're using one of the standard code bases out there (either the one from last year on ifi's website or Kevin's from the thread at the top of this forum or easy C), then yup. You just have to fill in your parts. The init functions in both of those bases are called once, then the other portion is called repeatedly every 26.2ms until the state switches. You don't have to worry about the logic to switch between autonomous and user control.
The only thing you got wrong was "And then before the competition the staff attaches a piece of hardware to the Competition port on the Operator Interface board"... They have the cable there in every player station, but you're the one that has to attach it to your OI! |
As stated earlier in this thread, it is recommended that you make a dongle (or buy the one from AndyMark) that contains an autonomous switch and a disable switch (sometimes, you just never know when the robot is going to go haywire when you load in some new code...). Pretty much everything you need can be bought at your beautiful, local RadioShack (or any other similar stores in your area). Either way, a disable button is a must. However, if you do not have a dongle, you can temporarily do call your autonomous function for when a button on the joystick/control system is pushed. We did this to test auto mode when our dongle fell off the bus. If you do this, remember to remove it from your code before the competition. You don't want your robot to start running autonomously should your driver accidentally hit the button on the joystick. I don't recommend doing this unless you absolutely cannot get your hands on a dongle. |
| Team 1574 Autonomous Mode | Guy_E | Robot Showcase | 4 | 01-04-2007 05:08 |
| Question about autonomous mode | itsme | Programming | 12 | 12-01-2007 13:20 |
| Team 81's Autonomous Mode | Eldarion | Programming | 15 | 25-02-2006 00:37 |
| a simple autonomous mode question | chippermonky | Programming | 3 | 18-02-2005 01:54 |
| A little question about the autonomous mode | Anton | Programming | 4 | 18-01-2005 14:08 |
