Go to Post I need to start using "ThunderChickens!" as an exclamation - Jessica Boucher [more]
Unread 06-02-2008, 10:46
Manoel's Avatar
Manoel Manoel is offline
FRC #0383 (Brazilian Machine)
Manoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond repute
Send a message via ICQ to Manoel Send a message via MSN to Manoel
Re: Mounting an arm potentiometer
Originally Posted by squirrel View Post
Here is another method.
Dead axle, right? I'm looking at our options for this year (too much torque to use a live axle) and yours seems like a good one. Did you have problems side loading the potentiometer? Is the pot shaft pinned against the aluminum channel or is it a simple interference fit or what?
Thanks!
Manoel Flores da Cunha
Brazilian Machine
Team # 383
Unread 06-02-2008, 10:50
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
The little arm has a clamp screw, and a slot that you can't see that lets it compress and clamp onto the pot shaft. Very little side load, notice the slot where the nylon screw contacts the little arm. Worked fine all season, and we took it off and used it on a different type of prototype robot this year.
Unread 06-02-2008, 11:33
Dan Richardson's Avatar
Dan Richardson Dan Richardson is offline
iR3 Creative
AKA: Dan Richardson
Dan Richardson has a reputation beyond reputeDan Richardson has a reputation beyond reputeDan Richardson has a reputation beyond reputeDan Richardson has a reputation beyond reputeDan Richardson has a reputation beyond reputeDan Richardson has a reputation beyond reputeDan Richardson has a reputation beyond reputeDan Richardson has a reputation beyond reputeDan Richardson has a reputation beyond reputeDan Richardson has a reputation beyond reputeDan Richardson has a reputation beyond repute
This is kind of a different way to do it, Its not suggested but it is a quick and easy and "relatively" reliable way to do a arm pot. I've used this method on encoders and pots on arms and drivetrains, all you need is a little wheel a bit of apoxy to mount the wheel to the shaft of the pot and a rounded area of whatever your measuring.
A problem with this method however is you have to constantly adjust your pot, every match you have to set it to make sure it didn't move and recalibrate.
However if you need a creative solution and can't drill into the end of the shaft or create a special coupler this is a solution we've used in the past and does work, and works well within the 2 minute First matches.
http://picasaweb.google.com/DanRRich...04765271712450
CO-Founder of Robot in 3 Days and the Robot in 3 Day Challenge.
Unread 06-02-2008, 11:58
Alex Cormier's Avatar
Alex Cormier Alex Cormier is offline
www.TwoPencilDesigns.com
AKA: Grizz, Twinkletoes, PitBull1126
FRC #1405
Alex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond repute
1126 has used the pneumatic tubing with a little heat to attach it to the pot, haven't had any issues with it.
Two Pencil Designs - Vinyl Graphics, Bumper Numbers, and Strategy Items!
Like us on Facebook & follow us on Twitter
Facebook.com/TwoPencilDesigns & TwoPencilDesign
Unread 08-02-2008, 13:02
jagman2882 jagman2882 is offline
former driver, now mentor
AKA: Cory Gramlich
FRC #1126 (SparX)
jagman2882 has a spectacular aura aboutjagman2882 has a spectacular aura aboutjagman2882 has a spectacular aura about
Send a message via AIM to jagman2882
no we actually use tiagon tubing (not sure if that is spelled right)
2003-2008 Match record 132-59-1
'04 Newton Division Champ, '06 Galileo Division Champ
'03, '04, '08 Buckeye Champs, '07 Finalist
'06 Finger Lakes Champs, '08 Finalists
'08 Buckeye Motorola Quality Award
'07 Buckeye General Motors Industrial Design Award
'05 Buckeye Radioshack Inovation in Control award, '06, '07 Finger Lakes Rockwell Automation Innovation in Control Award
Unread 08-02-2008, 13:32
TD78 TD78 is offline
AKA: Tom Dolan
FRC #0078 (AIR Strike)
TD78 has a brilliant futureTD78 has a brilliant futureTD78 has a brilliant futureTD78 has a brilliant futureTD78 has a brilliant futureTD78 has a brilliant futureTD78 has a brilliant futureTD78 has a brilliant futureTD78 has a brilliant futureTD78 has a brilliant futureTD78 has a brilliant future
In '05, '07, and this year, we've tapped off the first arm reduction sprocket (as seen here - that picture is from '07). Generally we mount an idler sprocket to help tension the chain, then tap the pot sprocket off of the idler. Keeps things simple. Couldn't find any other pictures, but you can try scanning through Joe's website for any that I may have missed.
FRC78: 2010-Present
FRC121: 2002-2009
Unread 12-02-2008, 21:48
Hazmatt's Avatar
Hazmatt Hazmatt is offline
AKA: Matt
FRC #2645 (PowerSurge)
Hazmatt will become famous soon enoughHazmatt will become famous soon enough
It was a pain, but i finally got it mounted with a belt drive. Can someone clarify something for me, though? Do all the pots i use have to be 100k, are other pots against the rules?
Unread 12-02-2008, 21:53
Bochek's Avatar
Bochek Bochek is offline
AKA: Adam Bochek
FRC #2200 (MMRambotics)
Bochek has much to be proud ofBochek has much to be proud ofBochek has much to be proud ofBochek has much to be proud ofBochek has much to be proud ofBochek has much to be proud ofBochek has much to be proud ofBochek has much to be proud ofBochek has much to be proud ofBochek has much to be proud of
We used a 1k pot, driven via K'nex gears! its really cool and works very well.
Adam Bochek - FRC 2200
http://www.mmrambotics.com
http://www.watchfirstnow.com
Human Arm Arm Controller SgtMillhouse648 Control System 5 09-01-2008 00:03
424's 2007 robot arm is very similar to 340's 2004 robot arm. Ross340 Robot Showcase 7 19-11-2007 21:11
Arm mounting on moving tracks? welderman5000 Technical Discussion 4 10-01-2007 00:16
Potentiometer Joshua May Technical Discussion 8 22-05-2004 19:51
Mounting the arm Jesse Technical Discussion 11 10-02-2004 23:20
