Go to Post You should always do CAD no matter how you plan on having parts made. - Garret [more]
Unread 06-02-2008, 06:57
EE_I_B EE_I_B is offline
AKA: Scott Johnson
FRC #2469 (Idabel)
EE_I_B is infamous around these partsEE_I_B is infamous around these partsEE_I_B is infamous around these parts
Rookie Team - Autonomous Mode Question
Help!, From reading the docs I see where the competition port pins 5-to-8 "allows" the autonomous_mode to be entered. From what I see, it "forces" the variable autonomous_mode.
From searching all the posts here, I can't seem to find any post that confirms what I am seeing.
The actual question is, "Do I have to do anything, or do I just place code in the "user_autonomous" part of the user fast c file. THEN, during competition, the system will close pins 5 to 8 for the first 15 seconds?
THANKS!!
Scott
Unread 06-02-2008, 07:33
sloteera's Avatar
sloteera sloteera is offline
AKA: Rafa
FRC #1860 (Cephatron)
sloteera has much to be proud ofsloteera has much to be proud ofsloteera has much to be proud ofsloteera has much to be proud ofsloteera has much to be proud ofsloteera has much to be proud ofsloteera has much to be proud ofsloteera has much to be proud ofsloteera has much to be proud ofsloteera has much to be proud of
Re: Rookie Team - Autonomous Mode Question
If you want to test your autonomous, you just need place a wire in pin 8 and pin 5 (Pin 8 is a GND and Pin 5 is AUTONOMOUS MODE, active in nivel logic 0)
When you place the wire, automatically the routine of autonomous mode will start.
Good luck =)
Unread 06-02-2008, 09:45
Jon Stratis's Avatar
Mentor, LRI, MN RPC
FRC #2177 (The Robettes)
In addition to what was already posted, during the competition you don't need to do anything to put the robot into autonomous mode - they have a hook up for the competition port, and they'll put your robot into autonomous mode, so any code you put in user_autonomous will execute until they switch it into the user operated mode.
Unread 06-02-2008, 10:14
Gamer930's Avatar
Gamer930 Gamer930 is offline
Team 930 and 171 Alumni
AKA: Justin
Gamer930 is a splendid one to beholdGamer930 is a splendid one to beholdGamer930 is a splendid one to beholdGamer930 is a splendid one to beholdGamer930 is a splendid one to beholdGamer930 is a splendid one to beholdGamer930 is a splendid one to beholdGamer930 is a splendid one to behold
It is highly recommended that every team builds a disable switch similar to
http://www.andymark.biz/am-0016.html
You can easily switch your robot from manual mode to auto mode. Then if you need to disable your robot without having to fumble with the power cord
2010 to Present, Scorekeeper/Field Power Volunteer for FRC/FTC/FLL
2005 - 2010, Team 171 College Mentor
2002 - 2005, Team 930 Student
Unread 06-02-2008, 10:37
IndySam's Avatar
IndySam IndySam is offline
FRC #0829 (Digital Goats)
Not only that but the emergency stop switch is great to have while testing autonomous.
We love our AM selector switch.
Unread 06-02-2008, 10:48
It is highly recommended that every team builds a disable switch...
We incorporated disable and auto/teleop switches into our operator console last year. It's very convenient not to have to worry about misplacing a standalone dongle. I'm sure this year's console will have the same feature.
Unread 06-02-2008, 12:16
DayZiro DayZiro is offline
FRC #2518
DayZiro is an unknown quantity at this point
My team (2518) is a rookie team and we decided to use EasyC for the first year
The way I understand what you've said is....
We just put our Autonomous code into the Autonomous(); function, and the OperatorControl into the OperatorControl(); function. And then before the competition the staff attaches a piece of hardware to the Competition port on the Operator Interface board, and they'll call the proper function when it's time to switch states ?
Same for the Initialize function I assume.
Unread 06-02-2008, 12:22
Mentor, LRI, MN RPC
If you're using one of the standard code bases out there (either the one from last year on ifi's website or Kevin's from the thread at the top of this forum or easy C), then yup. You just have to fill in your parts. The init functions in both of those bases are called once, then the other portion is called repeatedly every 26.2ms until the state switches. You don't have to worry about the logic to switch between autonomous and user control.
The only thing you got wrong was "And then before the competition the staff attaches a piece of hardware to the Competition port on the Operator Interface board"... They have the cable there in every player station, but you're the one that has to attach it to your OI!
Unread 06-02-2008, 16:17
Alexa Stott's Avatar
Alexa Stott Alexa Stott is offline
All I do is twin.
AKA: elixir
FRC #0025 (Raider Robotix)
Alexa Stott has a reputation beyond reputeAlexa Stott has a reputation beyond reputeAlexa Stott has a reputation beyond reputeAlexa Stott has a reputation beyond reputeAlexa Stott has a reputation beyond reputeAlexa Stott has a reputation beyond reputeAlexa Stott has a reputation beyond reputeAlexa Stott has a reputation beyond reputeAlexa Stott has a reputation beyond reputeAlexa Stott has a reputation beyond reputeAlexa Stott has a reputation beyond repute
Send a message via AIM to Alexa Stott
Yes, it is very important to remember to plug in the competition port!
As stated earlier in this thread, it is recommended that you make a dongle (or buy the one from AndyMark) that contains an autonomous switch and a disable switch (sometimes, you just never know when the robot is going to go haywire when you load in some new code...). Pretty much everything you need can be bought at your beautiful, local RadioShack (or any other similar stores in your area). Either way, a disable button is a must.
However, if you do not have a dongle, you can temporarily do call your autonomous function for when a button on the joystick/control system is pushed. We did this to test auto mode when our dongle fell off the bus. If you do this, remember to remove it from your code before the competition. You don't want your robot to start running autonomously should your driver accidentally hit the button on the joystick. I don't recommend doing this unless you absolutely cannot get your hands on a dongle.
|Email:alexastott[at]gmail.com|Facebook|@zelixir|Google+|
[University of Maryland Computer Science, Psychology]
[Brunswick Eruption]
Team 1574 Autonomous Mode Guy_E Robot Showcase 4 01-04-2007 05:08
Question about autonomous mode itsme Programming 12 12-01-2007 13:20
Team 81's Autonomous Mode Eldarion Programming 15 25-02-2006 00:37
a simple autonomous mode question chippermonky Programming 3 18-02-2005 01:54
A little question about the autonomous mode Anton Programming 4 18-01-2005 14:08
