Re: Mounting an arm potentiometer
This is kind of a different way to do it, Its not suggested but it is a quick and easy and "relatively" reliable way to do a arm pot. I've used this method on encoders and pots on arms and drivetrains, all you need is a little wheel a bit of apoxy to mount the wheel to the shaft of the pot and a rounded area of whatever your measuring.
A problem with this method however is you have to constantly adjust your pot, every match you have to set it to make sure it didn't move and recalibrate. However if you need a creative solution and can't drill into the end of the shaft or create a special coupler this is a solution we've used in the past and does work, and works well within the 2 minute First matches. http://picasaweb.google.com/DanRRich...04765271712450 |
1126 has used the pneumatic tubing with a little heat to attach it to the pot, haven't had any issues with it.
no we actually use tiagon tubing (not sure if that is spelled right)
In '05, '07, and this year, we've tapped off the first arm reduction sprocket (as seen here - that picture is from '07). Generally we mount an idler sprocket to help tension the chain, then tap the pot sprocket off of the idler. Keeps things simple. Couldn't find any other pictures, but you can try scanning through Joe's website for any that I may have missed.
It was a pain, but i finally got it mounted with a belt drive. Can someone clarify something for me, though? Do all the pots i use have to be 100k, are other pots against the rules?
We used a 1k pot, driven via K'nex gears! its really cool and works very well.
| Human Arm Arm Controller | SgtMillhouse648 | Control System | 5 | 09-01-2008 00:03 |
| 424's 2007 robot arm is very similar to 340's 2004 robot arm. | Ross340 | Robot Showcase | 7 | 19-11-2007 21:11 |
| Arm mounting on moving tracks? | welderman5000 | Technical Discussion | 4 | 10-01-2007 00:16 |
| Potentiometer | Joshua May | Technical Discussion | 8 | 22-05-2004 19:51 |
| Mounting the arm | Jesse | Technical Discussion | 11 | 10-02-2004 23:20 |
