Go to Post They have a ton of spirit but they are somewhat humble in their application of it. - firstfollower [more]
Unread 06-02-2008, 10:16
MPCG Robotics MPCG Robotics is offline
FRC #2401
MPCG Robotics is an unknown quantity at this point
We Need an IR Sensor!
Does anyone have an extra IR Sensor they can part with. We fried ours. If you can spare one, we would really appreciate it if we could get it. Please help! Thank you.
Unread 06-02-2008, 11:37
Arefin Bari's Avatar
AKA: Ari
FRC #0108 (SigmaC@T)
Re: We Need an IR Sensor!
IFI robotics has them for sale.
Unread 06-02-2008, 11:50
Steve_Alaniz Steve_Alaniz is offline
FRC #2848 (All Sparks)
Steve_Alaniz has a reputation beyond reputeSteve_Alaniz has a reputation beyond reputeSteve_Alaniz has a reputation beyond reputeSteve_Alaniz has a reputation beyond reputeSteve_Alaniz has a reputation beyond reputeSteve_Alaniz has a reputation beyond reputeSteve_Alaniz has a reputation beyond reputeSteve_Alaniz has a reputation beyond reputeSteve_Alaniz has a reputation beyond reputeSteve_Alaniz has a reputation beyond reputeSteve_Alaniz has a reputation beyond repute
IFI is out of sensors. If you reversed + and - You might just have the 5V regulator blown and you can replace that as some other teams have done. I ordered the tinyIR 2 kit but Bob Grieb says the code was modified to work better in the FIRST version. They are similar so I have a schematic of both and having worked component level for many years, there's a good chance the regulator acted like a fuse and blew before anything else could get damaged.
Good luck
Steve
jgannon's Avatar
jgannon jgannon is offline
I ᐸ3 Robots
AKA: Joey Gannon
jgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond repute
Arefin, did you look at the link you posted? IFI says they aren't stocking any more IR boards this year.
Team 1743 - The Short Circuits
2010 Pittsburgh Excellence in Design & Team Spirit Awards
2009 Pittsburgh Regional Champions (thanks to 222 and 1218)
2007 Pittsburgh Website Award
2006 Pittsburgh Regional Champions (thanks to 395 and 1038)
2006 Pittsburgh Rookie Inspiration & Highest Rookie Seed
Team 1388 - Eagle Robotics
2005 Sacramento Engineering Inspiration
2004 Curie Division Champions (thanks to 1038 and 175)
2004 Sacramento Rookie All-Star
_
Unread 06-02-2008, 13:34
FRC #2401
Our sensor still trains to a remote, but after it is trained it will not send a message or light the LEDs when the remote buttons are pressed.
Unread 06-02-2008, 18:37
urg8rb8 urg8rb8 is offline
FRC #0108
urg8rb8 is an unknown quantity at this point
This is the EXACT same thing that happened to us and, apparently, team 180. What is your plan of action? PLEASE PLEASE let us know if you get it to work again. I know that IFI ran out of these boards so I think the best solution is to use another IR sensor from another vendor.
Unread 07-02-2008, 10:32
FRC #2401
We are looking at getting the IR Sensor repaired.
Unread 14-02-2008, 21:08
phittman phittman is offline
Mentor Extraordinaire
FRC #1652 (Lakeview Legends)
phittman is an unknown quantity at this point
We have the same problem. It's going to be a mad scramble to get this fixed or to get a new one.
Unread 14-02-2008, 21:25
kevin.li.rit's Avatar
Imaginary Friend
AKA: Kevin Li
FRC #0596 (SciClones)
Team Role: Student
Does it respond when you try and retrain it? maybe it's not broken and your remote isn't using the 38khz frequency.
Kevin Li
596 - Sciclones
1405 - Finney Falcons
2262 - Holliston Panthers
Unread 14-02-2008, 21:45
jktheta's Avatar
jktheta jktheta is offline
AKA: Justin
FRC #1370 (Blue Charge)
jktheta is an unknown quantity at this point
Our board also fried. We tried replacing the 5v regulator. Nothing. We're trying to find another board but time is running out.
Unread 15-02-2008, 17:26
kylelanman's Avatar
kylelanman kylelanman is offline
Programming Mentor
AKA: Kyle
FRC #2481 (Roboteers)
kylelanman is a name known to allkylelanman is a name known to allkylelanman is a name known to allkylelanman is a name known to allkylelanman is a name known to allkylelanman is a name known to all
Our board is fried to. Would it kill them to give teams that fried there board a way to order new ones?? Or possibly let us have a four button handheld controller that talks to the robot through the io radio trasmitter??
Unread 15-02-2008, 17:46
robbrad robbrad is offline
FRC #1875 (Autonomato Autonomatons)
Team Role: Electrical
robbrad is an unknown quantity at this point
Can we come up with a failure list so we know what can go wrong and what we need to fix it when it happens? So far, I have "blown regulator" and, "won't learn". I ordered many replacement TO-92 voltage regulators and IR recievers from Digikey to cover us from those? Any other board problems/solutions?
IR Sensor fabalafae Programming 1 19-01-2008 16:53
Sensor Molten Programming 3 17-02-2007 17:43
tracking sensor need help dbhellmith Chit-Chat 0 08-02-2007 12:25
Need help with Sensor Hop_of_752 Programming 5 06-02-2004 23:43
Sensor or no Sensor For Autonomous mode Kyle1010 Programming 14 22-01-2003 13:10
