Go to Post Successful teams - in almost any aspect of life (i.e. not just robotics) - don't make excuses and assign blame when something goes wrong. They improvise. They adapt. They overcome. They correct the problem and move on. - dlavery [more]
Unread 06-02-2008, 11:39
Generator of Entropy
FRC #2973 (The Mad Rockers)
Orientation of ports on Thomas compressor
I didn't see anything addressing this, either specifically allowing or specifically prohibiting; I just posted a Q&A. The ports on our compressor are side to side; the pictures on page 4 and 14 of the pneumatics manual show them front to back. Are we allowed to remove the 4 bolts on the compressor head and reorient the ports 90 degrees?
Unread 06-02-2008, 11:45
Swampdude's Avatar
Swampdude Swampdude is offline
AKA: Dan Quiggle
FRC #0179 (Children of the Swamp)
Swampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond repute
Re: Orientation of ports on Thomas compressor
We've done it a few times, but never considered it to be questionable. The compressor obviously allows for it.
www.179swampthing.org
Unread 06-02-2008, 12:50
Hmmmmm, maybe that's why ours is rotated; I was looking at last year's compressor and Tytus did the pneumatics layout. If it comes stock front to back then I should be able to rotate it back. Does anyone else have a compressor with ports side to side?
Unread 06-02-2008, 12:52
Drwurm's Avatar
Drwurm Drwurm is offline
Electrical Alumni
AKA: Jason "Powercoach" Osmann
Drwurm is a glorious beacon of lightDrwurm is a glorious beacon of lightDrwurm is a glorious beacon of lightDrwurm is a glorious beacon of lightDrwurm is a glorious beacon of light
Send a message via AIM to Drwurm
I believe it's legal. We're also planning on doing that this year.
Electrical Engineer (in training)
Also grows carnivorous plants.
BEACH CITIES ROBOTICS:
2007 FTC "Quad Quandary" World Champions
Unread 06-02-2008, 15:21
in between teams
AKA: Luke Van Oort
Switching port oreintations on our compressor would free up some space on our robot this year; so, we posted a Q&A last night asking about it. The rules seem kind of iffy on doing it, but it really has no effect on the compressor's function, and seems perfectly safe. I guess we'll see what the Q&A says today or tomorrow.
Team 1219: 2009 - Mentor
Unread 06-02-2008, 16:05
ALIBI's Avatar
ALIBI ALIBI is offline
FRC #0141
Team Role: Parent
ALIBI is a name known to allALIBI is a name known to allALIBI is a name known to allALIBI is a name known to allALIBI is a name known to allALIBI is a name known to all
We have rotated the ports several times in the past and have never had any issues. I am glad you did a Q & A to the GDC to make sure it is legal. We have also removed the the head to install all the brass and then put it back on in the same orientation.
Unread 08-02-2008, 07:42
ALIBI's Avatar
FRC #0141
Team Role: Parent
I stand corrected. The GDC considers this a modification of the compressor:
Q & A 2/7/08: "As delivered from the factory, the ports on the Thomas compressor are oriented along the length of the body of the compressor. Removing the top of the housing and rotating the ports would be a modification of the compressor, and is explicitly prohibited by Rule <R92>."
Please do not rotate the ports. We never intended to violate the robot rules and most certainly will not rotate the ports again. We could have easily rotated the ports back to the original configuration had the compressor failed during the robot inspection. I wonder how many other teams/inspectors missed this in the past?
Unread 08-02-2008, 12:55
I had to hunt for this response; I assumed it would be put in the pneumatics section but it was in the "Material Utilization & Parts Use Flowchart" section. Hopefully teams will see it; I 'm sort of surprised that this is not allowed.
Unread 08-02-2008, 12:57
Drwurm's Avatar
Electrical Alumni
Guess i need to do some electrical rearranging now...
Unread 08-02-2008, 13:38
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
<R92> ......Consider pneumatic components sacred. They must remain in “out of the shipping box” condition.
They really mean this, apparently!
Unread 09-02-2008, 20:43
Tytus Gerrish's Avatar
Tytus Gerrish Tytus Gerrish is offline
IGAB, ADHD, and Dislexic
AKA: Ty
FRC #0179 (SwampThing)
Team Role: Tactician
Tytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond repute
NO! why did you have to stir the Pot? now it's ruined for everybody
Running just the compressor (was: free compressor) sciguy125 Pneumatics 15 06-02-2006 18:23
battery orientation Brawler006 Electrical 8 26-01-2004 08:57
UFH: Thomas Dale Nader CD47-Bot Unsung FIRST Heroes 10 07-11-2003 01:03
Orientation Switch CyberWolf_22 Programming 6 04-02-2003 10:42
Compressor Orientation Suneet Technical Discussion 5 25-01-2002 17:33
