Go to Post The students that I have known in FIRST over my 8 years of involvement have been far more inspired by the competition and some of the jaw dropping creations of "elite" teams than by anything that we made ourselves. - MattB703 [more]
Unread 22-01-2008, 18:04
Nathan's Avatar
Nathan Nathan is offline
FRC #1501 (Team T.H.R.U.S.T.)
Nathan has a spectacular aura aboutNathan has a spectacular aura aboutNathan has a spectacular aura about
What's the best ultrasonic?
What is the best ultrasonic sensor? We need to buy some... I've been looking at these:
http://www.maxbotix.com/
http://www.parallax.com/Store/Sensor...me,ProductName
I don't think either of those take interrupt ports, a big plus in my mind.
So what do you guys think the best ultrasonic is? Not limited to the two posted above of course.
TIA,
Nathan
Save money with PriceWombat, a shopping comparison and price tracking tool (that I made!).
Check out my hobby electronics business!
My former robotics team: Huntington County 4-H Robotics
Unread 22-01-2008, 18:43
ubergeek5075's Avatar
ubergeek5075 ubergeek5075 is offline
FRC #0910 (Foley Freeze)
ubergeek5075 is an unknown quantity at this point
Re: What's the best ultrasonic?
We've used the Maxbotix ones without a hitch. Attach +5V, GND and AN to an analog port, and away you go.
Beware of using two at a time facing in the same general direction. The internal logic gets confused and unstable readings follow because they will interfere with each other.
See Maxbotix FAQ for a solution to that problem. If you control them with the RC (and pulse them at the same time), they won't interfere with each other.
We've had success with them, so I hope that you do,
Good Luck
2005 Newton Division Finalists
2006 IRI Champions
2007 Curie Division Champions
2007 MARC Champions
2007 ARC Champions
2007 Capped in autonomous....Twice
Just remember two things: THE Answer is 42, and
DON'T PANIC!
Unread 22-01-2008, 19:31
EHaskins EHaskins is offline
AKA: Eric Haskins
no team (CARD #6 (SCOE))
I tested the Matbotix in 2006. They worked great. If I remember correctly an 8bit ADC the value is almost exactly the distance in inches.
Eric Haskins KC9JVH
Unread 06-02-2008, 12:00
Nathan's Avatar
We bought several of the Maxbotix sensors, but are having some serious issues with them.
Sometimes when we have the sensor hooked up and are reading the value in the terminal window the value will go insanely high, and then when we rotate the sensor the insane value returns to a normal value. By "insane value" I mean it jumps from around 13 to 213.
Has anybody else had this issue? We really want to use these ultrasonic considering we bought like 10 of them!!
Thanks,
Nathan
Unread 06-02-2008, 12:33
nparikh's Avatar
nparikh nparikh is offline
i heart infrared
AKA: Neil Parikh
FRC #0025 (Raider Robotix)
nparikh has a reputation beyond reputenparikh has a reputation beyond reputenparikh has a reputation beyond reputenparikh has a reputation beyond reputenparikh has a reputation beyond reputenparikh has a reputation beyond reputenparikh has a reputation beyond reputenparikh has a reputation beyond reputenparikh has a reputation beyond reputenparikh has a reputation beyond reputenparikh has a reputation beyond repute
Send a message via AIM to nparikh Send a message via MSN to nparikh
Agreed that the Maxbotix ones work! We used them on our 07 robot and have a stock of a few of them in case we want to use IR again!
Doing the right thing is always better than doing the easy thing.
Team 25 Alumnus
Attending: NJ Regional, Boston Regional, the Championship Event
Unread 06-02-2008, 13:02
Nathan's Avatar
Any idea why ours return bad values every once in a while?
-Nathan
Unread 06-02-2008, 13:51
gnormhurst's Avatar
gnormhurst gnormhurst is offline
Norm Hurst
AKA: gnorm
#0381 (The Tornadoes)
gnormhurst will become famous soon enoughgnormhurst will become famous soon enough
We're using a Vex unit. There's driver code available on this forum. Search for "sonar".
What you are seeing does not seem unusual. If there is just one or two bad readings in a row, you can write code to ignore sudden changes.
Also, consider that vibrations from the motors, etc, can confuse the sensor. We were getting mysterious readings but only when the motors were running. Unbolting the sensor from the bot and holding it by hand eliminated the problem. We remounted it using foam.
Note that if you use bolts through the foam to the chassis, the bolts will conduct the vibrations past the foam to the sensor. Mount the sensor to the foam, then the foam to the chassis.
Trenton Tornadoes 381
2004 Philadelphia Regional Winners
2006 Xerox Creativity Award
My corner of the USPTO.
My favorite error message from gcc: main is usually a function
My favorite error message from Windows: There is not enough disk space available to delete this file.
Unread 07-02-2008, 21:05
Nathan's Avatar
Yes, we could ignore the sudden changes, but since we wanted to use these for collision avoidance that wouldn't help us...
Unread 07-02-2008, 21:59
Phalanx's Avatar
Phalanx Phalanx is offline
Formerly Team 1089 (Mercury)
AKA: Michael Reffler
FRC #5431 (Titan Robotics)
Phalanx has a reputation beyond reputePhalanx has a reputation beyond reputePhalanx has a reputation beyond reputePhalanx has a reputation beyond reputePhalanx has a reputation beyond reputePhalanx has a reputation beyond reputePhalanx has a reputation beyond reputePhalanx has a reputation beyond reputePhalanx has a reputation beyond reputePhalanx has a reputation beyond reputePhalanx has a reputation beyond repute
Nathan
We've used them and they work well.
A few things I have found with them in order of significance....
1) On "power-up" they need a large, clear, wide and obstacle free area for self calibration to work well, if they don't calibrate well you will get odd readings.
2) They don't respond well to rapid large change in distance. For example, it's reading an object 10ft away, you put your hand in front of it and quickly remove it, it will take a few cycles to recover from that. Use an averaging routine or similar logic to get several readings before acting.
3) Isolate them from vibrations as much as possible, vibrations will get picked up and misinterpreted.
4) Use RF shielded cabling to eliminate other noise.
Don't just ask the experts, become one!
Leadership is not about ability. It's about responsibility!
Diagonally Parked in a Parallel Universe. It's okay we do Quantum Physics
Unread 07-02-2008, 23:02
Nathan's Avatar
When I've been turning on the RC (thus the ultrasonics) I had the obstacle about 12 inches in front of it. So maybe that is the issue, they aren't "calibrating" correctly?
I'm starting to like our daventechs more and more here...
Thanks,
Nathan
What's the best solution for a homebuilt robot arm? Chriszuma Chit-Chat 11 25-06-2006 01:55
What's the best free photo sharing site? Elgin Clock IT / Communications 7 27-11-2005 01:41
What's the best organizational structure for photos? maikull Chit-Chat 2 17-03-2005 17:47
What's the best free portal software? DCA Fan Website Design/Showcase 7 04-05-2003 17:32
What's the best qualifying rounds strategy? Ken Leung General Forum 24 24-03-2002 18:25
