Go to Post We are different, on purpose, for a reason. No one in FIRST should EVER forget that. - Rich Kressly [more]
Unread 02-02-2008, 21:55
Fastnate's Avatar
Fastnate Fastnate is offline
AKA: Nathan Gray
FRC #1519 (Mechanical Mayhem)
Fastnate will become famous soon enough
Send a message via AIM to Fastnate
Re: Team #405
Wow, that looks really nice.
Good luck!
Unread 06-02-2008, 09:57
corcarter's Avatar
corcarter corcarter is offline
AKA: Corey
FRC #2620 (TBA)
Team Role: Electrical
corcarter will become famous soon enough
Send a message via AIM to corcarter
Re: Team #405
you have some messy electrical work >.<
good year fellas and ladies, good year
Unread 06-02-2008, 13:12
iwashere1990's Avatar
iwashere1990 iwashere1990 is offline
Team 1389's Everything
AKA: Jason
FRC #1389 (The Stig)
iwashere1990 is an unknown quantity at this point
Re: Team #405
Whats the turning radius of those wheels? Seems short imo...Then again, it looks very fast. Good luck.
"Achievement is not always success while reputed failure often is. It is honest endeavor, persistent effort to do the best possible under any and all circumstances."
Team Number:1389
My Job on the Team:Everything but Programing
My Rookie Year:2007
My Team's Rookie Year:2004
Awards: Zero
Number of Members: 7-9
Number of Mentors: 1 (more like zero)
Our Current Budget for the Team: -6,000$
Number of Headaches this Year: 4
Number of Colds: 1
Number of PHAILS: > 10
Unread 06-02-2008, 16:57
JesseK's Avatar
JesseK JesseK is offline
Expert Flybot Crasher
FRC #1885 (ILITE)
Re: Team #405
For your stationary turning issues, I'd like to point you to this thread:
http://www.chiefdelphi.com/forums/sh...hlight=current
Note the posts by Dave Lavery on the total current available to the servos. It's only 1 amp . When you're stationary, you have evidence that your servos have trouble manipulating the steering. I'd be weary about this, as the mechanical stresses combined with current pull could be the cause of servos burning out. I'd have plenty of spares if I were you.
Also, I'd recommend putting some sort of support going from the main drive base to right next to the front wheels, or enclose the whole front. At the moment, a high speed off-centered frontal crash will knock your steering out of alignment, regardless of where you mount a front bumper to the current design.
Otherwise, this looks like a fantastic drive train!
GitHub
Unread 07-02-2008, 21:29
slocynerd's Avatar
slocynerd slocynerd is offline
Slocs
AKA: Sunshine
FRC #1517 (The lumberjacks)
slocynerd is an unknown quantity at this point
Re: Team #405
dang, this suckers a tank, 4 cims on 1 axle, holy crap lol, got some serious torquage goin on here
"The wise speak only of what they know."
"If more of us valued food and cheer and song above hoarded gold, it would be a merrier world." -J.R.R. Tolkien
Unread 09-02-2008, 12:08
bobzdar bobzdar is offline
FRC #0405
bobzdar is an unknown quantity at this point
Re: Team #405
Thanks for all the comments, we switched to a globe motor on the front with a pot and now have around 55 degrees of steering lock (on the inside wheel, it's ackerman so around 40 deg on the outside) and no issues with power. The wheels won't be exposed, we're going to run bumpers all the way around and nothing is going to be attached to the front or rear end so that they aren't stressed in an accident and are easy to remove for repairs if need be. The robot is pretty much finished now (except for the bumpers), I have a couple of pics of it, see below:
Total weight as shown is 84lbs. We figure we might get it up to 90lbs with bumper mounting brackets and the cage around the front and rear wheels, so still 30lbs under weight.
Thank you Team 179, team 237, team 269, team 303, team 1065, and team 1251 Arefin Bari Thanks and/or Congrats 13 16-03-2006 20:52
Team in a Box V. 2 : Featuring Team 67 and Team 103 OZ_341 General Forum 7 30-01-2006 16:53
