Go to Post Students learn from, are inspired by, and emulate their mentors. A team with a solid mentor base helps to create a productive, inspired, and ultimately successful group of students. - Jared Russell [more]
Unread 06-02-2008, 14:04
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
Re: Gearbox efficiency??
That's a good explation of how to estimate the efficiency of the gearbox/drivetrain. And the accuracy of your estimate may or may not be very important, depending on what it is you're trying to figure out using the calculator. You could plug in some different numbers such as 85%, 90%, and 95% and see what difference it makes.
Fuel efficiency or home efficiency contest John Gutmann Technical Discussion 12 07-08-2007 21:59
Plantery Gearbox Efficiency Leo Motors 5 05-08-2007 14:40
code efficiency Anton Programming 4 13-02-2005 15:24
gearbox efficiency hi_im_sean Motors 1 26-01-2003 21:29
Motor efficiency archiver 2001 1 23-06-2002 23:30
