Go to Post Just a word of advise dont come running up to someone and say OMG OMG its just remember to introduce yourself first. - Mike Schroeder [more]
Unread 06-02-2008, 14:07
M_dalgashon M_dalgashon is offline
FRC #2230
M_dalgashon is an unknown quantity at this point
We need help with the analog inputs
Hello, I'm from team 2230, and we use potentiometers to check axis. Last year we used one potentiometer, this year we use two of them... But when we connect them both to analog inputs 1 and 2, for example, the rc only reads one of them, the one on analog input 1. We tried switching them, moving them to other pins, no use.
We have another problem, which may be connected... When we write the following piece of code:
temp = Get_Analog_Value(rc_ana_in01);
We get the following error:
M:\FRC2008\Programming\potentiometer\teleop.c:185: Error [1105] symbol 'ADC_CH0' has not been defined
To the best of my knowledge, ADC_CH0 is defined... Can someone help?
Thank you very much
Team 2230
Unread 06-02-2008, 15:19
JimWright949's Avatar
JimWright949 JimWright949 is offline
The Owen Day of Seattle
AKA: Jim Wright
FRC #4542 (Titanium Talons)
JimWright949 is a splendid one to beholdJimWright949 is a splendid one to beholdJimWright949 is a splendid one to beholdJimWright949 is a splendid one to beholdJimWright949 is a splendid one to beholdJimWright949 is a splendid one to beholdJimWright949 is a splendid one to behold
Re: We need help with the analog inputs
ADC_CH0 is defined in adc.h, which should be located in the compiler's directory. mcc18v2 in my case. rc_ana_in01 is defined in ifi_aliases.h which includes adc.h.
If the compiler can't find these .h files I would think that it should have given you an error saying it can't find the .h file.
From teleop.c double check that you have all the .h files included. Look at adc.h to see if there is any problems with it, and that you see ADC_CH0 is defined there.
The only other thing I can think of is check to see if you have selected the correct device. We are using the PIC18F8722. To see if you have it right, select Configure|Select Device... and you should have PIC18F8722.
-jim
Unread 06-02-2008, 15:29
Spider-Man's Avatar
Spider-Man Spider-Man is offline
Curling Rocks
AKA: Adam Jacobson
FRC #0467 (DTB/Shrewsbury Colonials); #0034 (Rocket City Robotics)
Spider-Man has a spectacular aura aboutSpider-Man has a spectacular aura about
Actually, it appears that you are using Kevin Watson's code as your base. His code was recently updated if you want to use the old method of Get_Analog_Value, which does an analog-to-digital conversion when it is called.
Kevin's code comes with replacement code for the analog-to-digital conversion that should reduce computation and has many other benefits. If you read the readme or adc_readme file included in the zip file of the code, you should be able to set up the system and use the Get_Analog_Result function.
Student [2000 - 2001] Team 34 Rocket City Robotics
Plays Well With Others
2000 VA - Delphi "Driving Tomorrow's Technology"
2000 CMP - Top 5 Autodesk Visualization
2001 TX - Regional Finalist
Mentor [2004 - 2005][2007 - ????] Team 467 Shrewsbury Colonials (nee Duct Tape Bandits)
We Not Me
2004 LI - DaimlerChrysler Team Spirit
2004 LI - Website Design
2005 MD - Delphi "Driving Tomorrow's Technology"
2007 MA - Johnson & Johnson Sportsmanship
2008 CT - Judges' Award
2008 PA - Judges' Award
2010 MA - Judge's Award[/size][/font]
2012 DC - Chrysler Team Spirit[/size][/font]
2012 DC - Regional Winners[/size][/font]
2013 MAWO - Engineering Inspiration[/size][/font]
Unread 06-02-2008, 18:14
Kevin Watson's Avatar
La Caņada High School
FRC #2429
Thank you very much
Team 2230
Sorry about the confusion I've created. The Get_Analog_Value() function has been replaced with a version that has the same functionality, but doesn't have any dependancies on external libraries or header files (other than ifi_frc.h). You can get the code here: http://kevin.org/frc/quick_adc.zip.
-Kevin
Kevin Watson
http://kevin.org
Unread 08-02-2008, 17:39
aladrieth aladrieth is offline
FRC #1482
aladrieth is an unknown quantity at this point
To address the defining of ADC_CH0, which my team has been struggling to solve for the past 24 hours, you must put #include <adc.h> into the header file of ifi_frc.h. Be sure to use the <> instead of "" because that <> will call the adc.h file from the compiler, which defines ADC_CH0. The adc.h file in Kevin's code does not, and the "" will call that file instead.
Code to Read the Binary Inputs on Analog Buttons Kingofl337 Control System 5 14-03-2007 11:01
Help! Analog Inputs!! brennerator Programming 7 11-02-2007 15:48
Dashboard with analog and dig inputs Andrew Schreiber National Instruments LabVIEW and Data Acquisition 1 13-02-2006 22:48
Need help with Gyro = Analog Devices ADXRS150EB Jack Jones Technical Discussion 9 18-07-2005 07:00
How do the Analog Inputs work? JBotAlan Electrical 3 07-01-2005 00:11
