Go to Post P.S. could we get Kanagasabapathy added to the spell check? or will it not handle words that big? :) - Holtzman [more]
Unread 06-02-2008, 16:44
greendog99's Avatar
greendog99 greendog99 is offline
FRC #0388 (Maximum OZ)
greendog99 is on a distinguished road
Need help with Wiring
Hi!
Our team is needing help on what gauge of wiring for our Board????
Ready to take on the next challenge!
Unread 06-02-2008, 16:49
GrammarNazi GrammarNazi is offline
FRC #2952
GrammarNazi is on a distinguished road
Send a message via AIM to GrammarNazi
Re: Need help with Wiring
8.3.6
section<R47>
in the robot manual
also use the biggest wire you can spare for everything. Trust me it will work so much better.
I used 6awg for power distribution and 10 12 and 18 for everything else. More amps bigger wire.
smaller the awg number the bigger the wire.
hope that helps
First one to reply gets a cookie!!!
Unread 06-02-2008, 16:51
in between teams
AKA: Luke Van Oort
The answer is: it depends. Read the sections in the rules to found out the legal requirements. To save some time, this is the breakdown:
Main power distro (battery to main breaker, main breaker to distro block, distro block to circuit breaker blocks): 6AWG or larger
Circuits powered by 40A breakers: 12AWG or larger (my team prefers to use 10AWG on our robots)
Circuits powered by a 30A breaker: 14AWG or larger
Circuits powered by a 20A breaker: 18AWG or larger
Pneumatic solenoid valves: 24AWG or larger
Team 1219: 2009 - Mentor
Unread 06-02-2008, 16:54
greendog99's Avatar
So is there any limits on the gauge of wire you can use on certain parts?
Unread 06-02-2008, 16:57
FRC #2952
lukevanoort just posted what was inthe manual so you dont have too look now. the only thing you cant do is go smaller that the ones in the manual. But if you go too big you might not be able to find correct connectors
Unread 06-02-2008, 16:59
Drwurm's Avatar
Drwurm Drwurm is offline
Electrical Alumni
AKA: Jason "Powercoach" Osmann
Drwurm is a glorious beacon of lightDrwurm is a glorious beacon of lightDrwurm is a glorious beacon of lightDrwurm is a glorious beacon of lightDrwurm is a glorious beacon of light
Send a message via AIM to Drwurm
Well, luke basically just said that....
Electrical Engineer (in training)
Also grows carnivorous plants.
BEACH CITIES ROBOTICS:
2007 FTC "Quad Quandary" World Champions
Unread 06-02-2008, 17:01
greendog99's Avatar
I hadn't seen that post!
HELP! We need pneumatic wiring help! BrittanyV Pneumatics 13 10-03-2006 09:26
Need help Programming and wiring camera! Amisca Programming 1 14-02-2006 18:37
need some help with the OI, and wiring a display pryoplasm Control System 8 10-03-2004 20:46
hey need some help with writing a code please help me here magical hands Programming 9 01-01-2004 21:46
Good with Audio Wiring? Help me please. Rick Technical Discussion 10 04-11-2002 21:41
