Go to Post [Don't] celebrate mediocrity and want the losers to have an equal chance? Please. Work your butt off for six weeks, keep doing it until you have taught yourself how to be excellent, and go and instead of waiting for a handout. - DonRotolo [more]
Unread 06-02-2008, 17:27
jc4p jc4p is offline
AKA: Kasra Rahjerdi
FRC #2412 (Robototes)
jc4p is an unknown quantity at this point
Problem with Kevin's 2008 code
Hello,
We used to have the 2007 code from IFI's site in our controller, and it worked fine. Now, I have upgraded to Kevin's 2008 code, along with upgrading our MPLAB (7.21), and MCC (3.1). When we put the compiled version of the 2008 code in the controller, all the code we have works except the controller code.
Meaning when we make code in our autonomous.c be "pwmwhatever = 255", it works, but the p1_y = pwmwhatever code does not.
The controller code works if we use the old compiled hex of the 2007 code, so it can't really be a hardware problem.
Has anyone encountered this before, or does anyone have any suggestions?
Unread 06-02-2008, 17:31
DanDon's Avatar
DanDon DanDon is offline
ohhh MY god
AKA: Dan Hoizner
FRC #0375 (The Robotic Plague)
DanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond repute
Send a message via ICQ to DanDon Send a message via AIM to DanDon Send a message via MSN to DanDon
Re: Problem with Kevin's 2008 code
Assignments in C work from right to left (i.e. take the value on the right side of the '=' and store it into the variable on the left of the '=').
In which case your code should look like
pwmXX = pX_y;
Unread 06-02-2008, 17:38
Kevin Watson's Avatar
La Caņada High School
FRC #2429
Originally Posted by jc4p View Post
...but the p1_y = pwmwhatever code does not. ...anyone have any suggestions?
Yes, it should be "pwmwhatever = p1_y". I maybe wrong, but I don't think this has anything to do with my code .
-Kevin
Kevin Watson
http://kevin.org
Unread 06-02-2008, 17:40
AKA: Kasra Rahjerdi
edit:
Turned out I had something commented out in the teleop.c and now that I uncommented it works perfectly.
Thanks Kevin, you're magic
Unread 06-02-2008, 17:48
FRC #2429
I was reading the giant thread and realized I need to enable one of the encoders, now that I have enabled channel 4 in ifi_frc.h and enabled the Initalization in teleop.c...
You forgot to read the readme.txt file, which tells you to also enable the call to the ISR in ifi_frc.h .
-Kevin
Kevin Watson
http://kevin.org
Problem with 2008 gear tooth sensor Larry R Sensors 27 18-02-2008 11:39
Need help in Kevin's 2008 default code robotrobot2 Programming 5 20-01-2008 14:36
Problem with Kevin's code Tottanka Programming 5 04-11-2007 13:32
Problems with Kevin's 2007 default code bruss6 Programming 8 19-01-2007 15:42
What are with the Ls in Kevin's code??!!! HELP!!! RbtGal1351 Programming 2 18-02-2005 16:57
