Go to Post A FIRST fanatic who never had any desire to be an engineer. There. I said it. ;) - Katie Reynolds [more]
Unread 06-02-2008, 15:40
sdcantrell56's Avatar
AKA: Sean
FRC #2415 (Wired Cats)
pic: Concept Mecanum Drivetrain
Unread 06-02-2008, 15:41
AndyB's Avatar
AndyB AndyB is offline
Ambitiously Disappointing
AKA: Andy Burchardt
FRC #0171 (Cheese Curd Herd)
AndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond repute
Re: pic: Concept Mecanum Drivetrain
Very nice simple design. How thick are your side plates and what are you using to connect both modules (the long black bars). Are they fabricated or COTS?
Team 171 :: Cheese Curd Herd :: College Mentor, 2008-Present
Team 269 :: CooneyTech Robotics :: Student, 2005-2007
Unread 06-02-2008, 16:05
AKA: Sean
Thank you. The side plates are 3/16" thick Al. The connecting bars are 2x1" channel with the ends folded over and welded and then 2 holes are drilled in the ends to mount into the side plates. This is the same method we're using for our drivetrain this year and it seems to work well.
Mentor 2415
Unread 06-02-2008, 17:52
T3_1565 T3_1565 is offline
AKA: Twitch Drive Designer
FRC #1360
T3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant future
Send a message via MSN to T3_1565
that motor setup is exactly how we are using our omnis this year, those gearboxes are really easy to work with lol
Unread 06-02-2008, 20:19
A holonomic drive really wants all wheels to be making contact with the floor at all times. The way you describe the chassis makes it sound very stiff. Try designing it to be flexible, so irregularities or debris on the floor won't give you problems.
Unread 06-02-2008, 21:50
AndyB's Avatar
AKA: Andy Burchardt
Along with what Alan commented on, I would recommend filleting any of your cutouts you have in your plating. If you don't those will become stress points. With fillets and rounds, you distribute the stress.
Unread 06-02-2008, 22:42
Rupnick's Avatar
Rupnick Rupnick is offline
FRC #1675 (UPS - Ultimate Protection Squad)
Rupnick is on a distinguished road
Send a message via AIM to Rupnick
It may just be the pic but of what I can see your wheels are not in a square which is essential for mec drive. But I may be wrong just looks that way.
Unread 06-02-2008, 22:44
No it isn't. I've seen them done in a rectangle--and work.
Unread 06-02-2008, 23:00
AKA: Sean
Yeah I thought they would work in a rectangle. I've seen many done that were in a rectangle configuration that worked well. Also as for the flex issue I have seen many teams use mecanum without any suspension and it works. That could always be added in a second revision.
Mentor 2415
Unread 07-02-2008, 11:47
bman's Avatar
bman bman is offline
FRC #0548
bman is an unknown quantity at this point
So, do you plan on building this for overdrive?!!
Unread 07-02-2008, 11:56
AKA: Sean
Actually no...We are building a completely custom 6 wheel drive robot. I just got bored and decided to cad up a mecanum.
Mentor 2415
pic: Concept Frame armoredvehicle Extra Discussion 6 16-12-2007 20:55
pic: VEX Mecanum Concept Wheel JesseK Extra Discussion 18 17-05-2007 10:27
Mecanum drivetrain programming problems Mr. Freeman Programming 4 21-03-2007 17:11
pic: Concept Gearbox Bill_Hancoc Extra Discussion 12 17-11-2005 20:54
pic: Claw^2 Concept CD47-Bot Extra Discussion 8 06-02-2004 14:08
