Go to Post Didn't know the details about the battery. In the past it was just a black (grey) box with two terminals...use...recharge...use..recharge. - cbolin [more]
Unread 06-02-2008, 05:04
AmitCarmeli AmitCarmeli is offline
FRC #1943
AmitCarmeli is an unknown quantity at this point
IR board problem
Hello,
We're having problems with our IR board. We ran through the learning process with many different remotes seccesfully. However, after the learning process is finished and we try to press the buttons, there is no response from the board (no LEDs light up).
The weird thing is that about a month ago, we tried the board and it worked perfectly, but now there is no response after the learning phase.
Did anyone encounter this problem before? Is there anything we can do to solve it? and if not, how can we get a new one?
Any help will be appreciated.
Unread 06-02-2008, 18:44
urg8rb8 urg8rb8 is offline
FRC #0108
urg8rb8 is an unknown quantity at this point
Re: IR board problem
Originally Posted by AmitCarmeli View Post
Hello,
Yes, many boards seem to be having this issue. You are not alone.
Unread 06-02-2008, 19:48
Miner Miner is offline
AKA: Jacob Miner
FRC #2077 (Laser Robotics)
Miner is on a distinguished road
I have heard that many teams are having the same problem.
Check and make sure that everything looks nornmal (everything is connected, no weird coloring, metal is all intact, nothing is separated where it doesn't look like it should be.
Also make sure that you aren't unplugging the IR board after the learning phase. That was a problem that we had originally. Now our board is completely fried. Someone messed with it. Follow the wiring and learning directions exactly and see if you can figure it out by trial and error.
Good luck,
Jacob
Do what you like... Like what you do!
Jake, the Life Is Good guy
Unread 09-02-2008, 18:53
AdmiralAllen's Avatar
AdmiralAllen AdmiralAllen is offline
Master of Computers and Robots
AKA: Allen Worcester
FRC #1662 (Raptor Force Engineering)
AdmiralAllen will become famous soon enough
yeah......i'm having the same problem, and i have absolutely no idea how to fix it......it dosen't appear to be fried though....
any help?
Another IR Board Problem C222 Electrical 2 13-01-2008 17:36
IR board joshuamorris Electrical 2 12-01-2008 19:43
Do you have a problem with the IR Board? DonRotolo Control System 5 07-01-2008 23:57
Lights in Joystick board or control board rcubes85 Control System 15 26-02-2005 23:40
Perf Board = BS2-IC Carrier Board? indieFan Electrical 2 16-09-2004 08:28
