Go to Post Theory is when you know everything but nothing works. Practice is when everything works but you don't know why. On our team, theory and practice comes together. Nothing works and nobody knows why. - CalTran [more]
Unread 05-02-2008, 19:51
Stillen Stillen is offline
Stillen is just really niceStillen is just really niceStillen is just really niceStillen is just really niceStillen is just really nice
Send a message via ICQ to Stillen
reverse hurdle.
I am STILL unable to post in the Q&A forums, so I need to ask here....
If for some reason, we accidently knock off the other alliances ball off the overpass backwards ( ball goes in the opposite of normal) do they get points as if they hurdled it over the correct way? Our "arm" is slighty spring loaded (within rules) and as we drive under the over pass, it sometimes knocks the ball the opposite direction. If we were to do this I'm assuming this does not qualify as a real hurdle..... One then must push the ball over the line to gain points.....
Unread 05-02-2008, 19:54
Vikesrock's Avatar
Team 2175 Founder
AKA: Kevin O'Connor
Re: reverse hurdle.
This would not be a hurdle as the ball has not passed OVER the overpass. If you do it in hybrid mode however, they will receive the 8 points for the ball being knocked off the overpass, regardless of the fact that you were the one that knocked it down.
Unread 05-02-2008, 20:31
Bob Steele's Avatar
AKA: Bob Steele
Re: reverse hurdle.
The other issue here is which overpass you are talking about.
If the ball is in YOUR homezone overpass... you can knock it off either way... it won't count (except in hybrid)
If you pull it back on your opponent's overpass it will not count unless you knock it across the line when you drop it... then it would be a 2 pointer... I believe... (please correct me if I am wrong)
If you knock it over your opponent's overpass it will score as a hurdle during teleoperated...
Unread 06-02-2008, 18:55
TheNotoriousKid's Avatar
TheNotoriousKid TheNotoriousKid is offline
AKA: Shane O
FRC #0025 (Raider Robotix)
TheNotoriousKid is just really niceTheNotoriousKid is just really niceTheNotoriousKid is just really niceTheNotoriousKid is just really niceTheNotoriousKid is just really nice
Send a message via AIM to TheNotoriousKid
Re: reverse hurdle.
Like others have already said...I don't believe that counts as a hurdle. I actually see it as beneficial especially hybrid mode and the end game.
Unread 06-02-2008, 19:03
Manoel's Avatar
Manoel Manoel is offline
FRC #0383 (Brazilian Machine)
Manoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond repute
Send a message via ICQ to Manoel Send a message via MSN to Manoel
Re: reverse hurdle.
It really depends the direction of the ball and, of course, if you're on your opponent's side.
If you push the ball towards the line, it's a hurdle. Might still be beneficial, trading 12 points for 8. If you push the ball the other way your opponent gets nothing.
Manoel Flores da Cunha
Brazilian Machine
Team # 383
Unread 06-02-2008, 19:59
Laaba 80 Laaba 80 is offline
AKA: Joey
FRC #1714 (MORE Robotics)
Laaba 80 has a reputation beyond reputeLaaba 80 has a reputation beyond reputeLaaba 80 has a reputation beyond reputeLaaba 80 has a reputation beyond reputeLaaba 80 has a reputation beyond reputeLaaba 80 has a reputation beyond reputeLaaba 80 has a reputation beyond reputeLaaba 80 has a reputation beyond reputeLaaba 80 has a reputation beyond reputeLaaba 80 has a reputation beyond reputeLaaba 80 has a reputation beyond repute
Re: reverse hurdle.
No, if you knock the ball off backwards they will not get any points as the ball has not crossed any line. CROSSING is defined as moving in a counterclockwise direction, and an object has crossed once all parts of the object have moved across the plane, so is the ball goes over clockwise it has passed through the line, however it has not crossed it. It also depends on what the scenario is. If you are in teleop and your opponent didnt knock their ball off, you can knock the ball off however you want to because in order for a ball to score the first time it must cross a lane marker or opponents finish line first. If it is at the end of the match and your opponent has previously taken their ball down, then put it back up to try and get the 12 points, if you knock it off in a clockwise direction, then yes they do get the points for the hurdle. If you knock it off backwards (ball moving counterclockwise) then they do not get points because the ball hasnt CROSSED the line. If you dont trust the rules I say because I didnt quote the manual, feel free to look them up they are in there. I just didnt feel like going to the manual to quote them. Hope I helped.
Joey
Driving Record - 75-43-8
Coaching Record - 92-65
How does your robot hurdle? waialua359 Robot Showcase 22 06-02-2008 23:58
Hurdle Question Vanquish General Forum 2 09-01-2008 10:36
Hurdle like Mad Popog Rules/Strategy 5 08-01-2008 02:57
Is this considered a hurdle? chaineezee Rules/Strategy 10 07-01-2008 19:12
What is a hurdle? neutrino15 General Forum 13 05-01-2008 21:02
