Go to Post Winning is an outcome, not the whole point. - StephLee [more]
Unread 06-02-2008, 19:26
CuriousGeorge CuriousGeorge is offline
CuriousGeorge is an unknown quantity at this point
quick question to all about why using KOP metal.
i dont really understand as to why i see most teams use the KOP metal to make a robot.. its not very reliable/strong and u cant make a very strong structural frame (i have seen some KOP bots bend)
now in my exp. i have seen robots break KOP robots to the point of rebuilding.
why not just buy stock and weld?
i noticed some robots who weld never tend to have structural damage and have a really strong frame not held together by bolts and nuts.
so.. why are YOU using it? easy to put together? no money? explain..
im just curious, im not trying to make fun of anyone.. i just see and ask.
Unread 06-02-2008, 19:32
Joe G.'s Avatar
Joe G. Joe G. is online now
AKA: Josepher
no team (Formerly 1687, 5400)
Re: quick question to all about why using KOP metal.
-Cheap
-No fancy machining, which we can't do, required.
-Faster to put together.
-I have tried and failed to break it.
-easy to adapt to.
We are welding the joints of it instead of bolts this year, but it held up through 2 events last year with no bumpers and bolts with no problem.
In general (there are many exceptions) teams using the Kitbot are somewhat lacking in the resource department, and without welding, precise machining, etc. their robots are more likely to break. Teams with these resources can build stronger robots easier, and also tend to use these resources to make their own chassis to fit their needs better.
Unread 06-02-2008, 19:59
kmcclary's Avatar
kmcclary kmcclary is offline
Founder 830/1015;Mentor 66/470/1502
FRC #0470 (Alpha Omega Robotics)
Rookie Year: 1994
kmcclary has a reputation beyond reputekmcclary has a reputation beyond reputekmcclary has a reputation beyond reputekmcclary has a reputation beyond reputekmcclary has a reputation beyond reputekmcclary has a reputation beyond reputekmcclary has a reputation beyond reputekmcclary has a reputation beyond reputekmcclary has a reputation beyond reputekmcclary has a reputation beyond reputekmcclary has a reputation beyond repute
Originally Posted by CuriousGeorge View Post
i dont really understand as to why i see most teams use the KOP metal to make a robot.. [...] why not just buy stock and weld?[...]
I personally love the frame kit. We did some analysis of the frame kit. Our conclusions:
1) To our surprise, it turns out that the question mark shape has similar (though not identical) structural properties as the same sized box extrusion. That is close enough for us.
2) Due to the hole pattern, it is actually lighter per unit length to build using the frame kit than using equivalent box extrusion. (IOW, it's "pre-cheesed" for you!)
3) The hole pattern and tab on one side are very convenient for mounting accessories. This saves a LOT of time.
4) It helps us standardize on one bolt type (1/4-20, of various lengths) for almost EVERYTHING.
5) You're given parts already precut to roughly the basic drive train frame dimension limits. (FYI, we always cut off 1" per edge, to allow for bolt head thickness to stick out on all sides. Otherwise, it often won't fit into the FIRST sizing box at a regional! ...Duh... However, if you're welding it, and NO bolts stick out around the perimeter, that may not be a problem for your team.)
6) If you don't have aluminum welding available at your school (yes, that's a totally different discussion), then the frame kit is definitely a godsend to your team.
7) ...and lastly, we'd rather focus our student workforce on the game payload problem, than spend a large chunk of it on the basic framework.
So, overall, it hasn't been WORTH our time and effort to translate the frame kit into welded frame. As stated, a welded frame of the same box dimension and thickness is always heavier per unit length, AND we'd then have to drill mounting holes all over it anyway. That's not the best use of our manpower.
(Does that make sense to you?) I hope this helped!
- Keith
Chief Engineer, Team 1502 "Technical Difficulties"
Keith McClary - Organizer/Mentor/Sponsor - Ann Arbor MI area FIRST teams
ACTI - Automation Computer Technologies, Inc. (Sponsoring FIRST teams since 2001!)
MI Robot Club (Trainer) / GO-Tech Maker's Club / RepRap-Michigan) / SEMI CNC Club
"Certifiably Insane": Started FIVE FRC teams & many robot clubs (so far)!
2002: 830 "Rat Pack" | 2003-5;14: 1015;1076 "Pi Hi Samurai" | 2005-6: 1549 "Washtenuts"/"Fire Traxx"
2005-(on): 1502 "Technical Difficulties" | 2006-(on): FIRST Volunteer!
2009-(on): 470 "Alpha Omega" | WAFL | Sponsor & "Floating Engineer" for MI Dist 13 (Washtenaw Cnty)
2011: 3638 "Tigertrons" | 2013-(on): 4395 "ViBots" | 2014-(on) 66 "Grizzlies"
"Home" Teams: 66, 470, 1076, 1502, 4395
Local FIRST alumni at or coming to Ann Arbor (UM/EMU/WCC/Cleary)?
...We Want YOU as a Mentor! Please email me for info!
Support CDF Reputation - If a posting helped, thank 'em with rep points!
"It must be FRC build season when your spouse and children become 'Action Items 8 & 9'..."
Unread 06-02-2008, 20:07
but i wouldnt wanna risk my robot breaking just because its somewhat lighter (the team i was with always used a welding frame) and the robot i built broke KOP bots frequently.
now if i knew this would happen (even a slim chance) i would change my gameplan quite quickly.
so why do teams risk it? (i understand if u cant due to not having some resources.. but if you DO have them.. why arent u using them?)
Unread 06-02-2008, 20:13
chris31 chris31 is offline
Team 2021 Captain
AKA: Chris Davidson
FRC #2021 (FA Robotics)
chris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond repute
Send a message via AIM to chris31
Really? How often would you "break" KOP frames? Its not really that easy if you have bumpers and its built right.
Unread 06-02-2008, 20:18
Alex Cormier's Avatar
Alex Cormier Alex Cormier is offline
www.TwoPencilDesigns.com
AKA: Grizz, Twinkletoes, PitBull1126
FRC #1405
Alex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond repute
now if i knew this would happen (even a slim chance) i would change my game plan quite quickly.
so why do teams risk it? (i understand if u cant due to not having some resources.. but if you DO have them.. why aren't u using them?)
What do yo mean broke KOP frame teams?
what is the goal you are trying to get at with this thread, and what team were you on previously?
Why don't you ask some of these teams who have used the KOP chassis...
121, 148, 229, 2056....
so in the end it has been tested by some of the top teams and have been used by so many others, why waste time and man power and cost? the KOP chassis is something that is in the kit and can be assembled in ONE meeting, the day of kickoff. it's an excellent frame for teams with a low budget, not many engineers or any of that, and in the end it's given to you!
Two Pencil Designs - Vinyl Graphics, Bumper Numbers, and Strategy Items!
Like us on Facebook & follow us on Twitter
Facebook.com/TwoPencilDesigns & TwoPencilDesign
Last edited by Alex Cormier : 06-02-2008 at 21:17. Reason: sorry, misinformed about 330 using KOP chassis
Unread 06-02-2008, 20:30
Vikesrock's Avatar
Team 2175 Founder
AKA: Kevin O'Connor
As one of one of the rougher "enforcer bots" at the Wisconsin regional last year, I can say that our KOP from shows no signs of being worse for the wear. This is despite running with no bumpers for a few matches and running without the endcaps (clearance was too low to climb ramps) for all of the elim matches.
We through everything I thought the KOP frame would handle at it, plus quite a bit more and I don't see any signs of budging an inch.
Having said that, the reason we use it is that it is cheap (free) and easy to machine (it already has many holes in it) for a team without complex machining and welding capabilities.
Unread 06-02-2008, 20:32
well if u have one high torqued robot pressing against a KOP bot (which happened in 06 for me) it could break, i did it myself.. i drove the robot.
ive also see some KOP robots run str8 into walls and fall apart
what im trying to figure out with this thread is why people use KOP bots.. i personally dot understand it
Unread 06-02-2008, 20:35
Joe G.'s Avatar
AKA: Josepher
I personally have never seen a kitbot fall apart, and I have seen multiple welds break under situations like those you have described. The kit metal itself is more than strong enough. Loose bolts due to lack of loctite, etc, might cause problems, but I have seen no evidence that there are unavoidable flaws in the basic concept/structure of the kitbot. Until I see this, our team will probably continue using it in some form, and encourage others to do the same.
Unread 06-02-2008, 20:41
in between teams
AKA: Luke Van Oort
I have never seen a kitbot frame fail. We have defended and been defended using a kitbot chassis without any noticeable problems. It is pretty light, it does what we need, it is strong enough, and it is easy to work with.
Team 1219: 2009 - Mentor
Unread 06-02-2008, 20:48
ChrisMcK2186's Avatar
ChrisMcK2186 ChrisMcK2186 is offline
Typer of doom
AKA: Chris McKenzie
FRC #2186 (Westfield Robotics)
ChrisMcK2186 is a glorious beacon of lightChrisMcK2186 is a glorious beacon of lightChrisMcK2186 is a glorious beacon of lightChrisMcK2186 is a glorious beacon of lightChrisMcK2186 is a glorious beacon of lightChrisMcK2186 is a glorious beacon of light
Send a message via AIM to ChrisMcK2186
Wow, interesting thread.
We used the KOP last year and had good results. It survived being run full speed into the opposite wall during every match, our programmers are still puzzled.
Why do people use it?
1)Free
2)easy to use
3)easy to access nuts/bolts for it
4)it is easy to maintain
5)no machining required
6)no welding required
7)not made of unobtainium
Any more questions?
Chris McKenzie
2186
Working on Robotic Eagles group(PM for info)
Stephen Colbert-"Please tell me this leads to robot
battles."
Dean Kamen-"It does lead to kids building robots, and they do compete in the sport but we also teach the kids gracious proffesionalism, so while the robots are competing, they do it in a very, very gracious way."
Darn, I got into this for the battles!
Unread 06-02-2008, 21:05
IntensifiedAmp's Avatar
IntensifiedAmp IntensifiedAmp is offline
AKA: Muny Tram
FRC #3683 (Team Dave)
IntensifiedAmp has much to be proud ofIntensifiedAmp has much to be proud ofIntensifiedAmp has much to be proud ofIntensifiedAmp has much to be proud ofIntensifiedAmp has much to be proud ofIntensifiedAmp has much to be proud ofIntensifiedAmp has much to be proud ofIntensifiedAmp has much to be proud ofIntensifiedAmp has much to be proud of
Well, I can tell you, that most teams not here on Chief Delphi, and some teams here on Chief Delphi as well have two common reasons why to you the KOP Metal.
1) Like my team, we have no access to any welding, or huge machinery. Yes, our whole robot is made from hacksaw, hammers, drills, and the usual tools (regular hand tools). Unfortunately, we can not get access to any at the moment. No lathing, CNC machines, nothing. It's unfortunate but people can work around so, and thus using the KOP to make life much, MUCH easier.
So it isn't so much about, "Why use it?", it's about, "Why do we NEED it?". Sure we can use Extrusion, but here's the second part.
2) Money. Some teams, unfortunately, don't have sufficient funds to have a custom built chassis. I say, saving money, time, and I admit, the Kit bot is awesome for a provided standard part.
Yet I haven't seen any kit bot break. Sure it may bend, or warp, but I don't think the degree of it is large at all in a competition.
May I ask where in the kit bot does it break? If it's the joints, than its a simple problem of screws and nuts. However, if its the metal itself...
wow.
Unread 06-02-2008, 21:06
Evert Evert is offline
FRC #2185
Evert is an unknown quantity at this point
we used the KOP frame last year and our using it again this year.
Last year, our robot defended without bumpers and we had no problems with the frame. I've seen in run into a wall at full speed with no problems.
It also doesn't cost us anything which is good.
Unread 06-02-2008, 21:09
we broke one robot at the joints (this i know was bolts and such)
and one robot snapped at the front KOP bar trying to run into us as we ran into them
also made one robots side KOP bar bend severly from the side
Unread 06-02-2008, 21:10
Vikesrock's Avatar
Team 2175 Founder
AKA: Kevin O'Connor
Here's a good thread from the "debut" of the kitbot. Specifically the post by Paul Copioli about the strength of the kitbot frame. If it is good enough for Paul and JVN it's good enough for me.
Quick question about the bumpers iPilipino General Forum 3 23-01-2008 18:05
quick question [about Halo ce]...... Devastater Chit-Chat 0 04-04-2005 20:15
Quick question about the ramp archiver 2001 1 23-06-2002 22:51
Quick question about the ramp archiver 2001 5 23-06-2002 22:45
quick question about qualifying points Hymnson General Forum 4 25-09-2001 21:19
