Go to Post Remember the volunteering is not mandatory for the people to do it. It IS mandatory if FIRST is to survive and the regionals to leave a positive impact on everybody. - Alavinus [more]
Unread 05-02-2008, 20:36
borabora borabora is offline
FRC #0334
borabora will become famous soon enoughborabora will become famous soon enough
xbox controller
Hey,
My team wants to use an xbox controller. I know we have to use the usb chicklet. We have one already, but there is one problem.
The chicklet does not allow you to use all of the buttons and the two axis on the controller all at the same time. Is there a way we can use them?
I was thinking of splicing the wire for the xbox controller and finding out which wires are used for which button. Then just take a 15 pin connector and solder them onto the proper ports that the oi board will recognize and attach that to a different com port.
Will this work? We dont want to ruin a controller over this...
thanks!
Unread 05-02-2008, 20:42
Miner Miner is offline
AKA: Jacob Miner
FRC #2077 (Laser Robotics)
Miner is on a distinguished road
Re: xbox controller
I actually have no idea, but it might be risky. If I remember correctly, you can change settings in the programming code that work specifically for the OI. There are also settings if you use IFI Dashboard, which is available at the IFI website.
http://www.ifirobotics.com/dashboard_viewer.shtml
It is a great program that will tell you what buttons are doing what, which axis are controlling what, battery levels, and other helpful things. I highly suggest it.
Good luck,
Jacob
Do what you like... Like what you do!
Jake, the Life Is Good guy
Unread 05-02-2008, 22:10
Binome's Avatar
Binome Binome is offline
Programmer/Electronics/CAD
AKA: Patrick
FRC #2273 (SHIM)
Binome is a glorious beacon of lightBinome is a glorious beacon of lightBinome is a glorious beacon of lightBinome is a glorious beacon of lightBinome is a glorious beacon of light
Re: xbox controller
You can configure it to a variety of modes using the process explained in the datasheet, located at http://www.ifirobotics.com/docs/usbc...ual-rev1-2.pdf
Unread 05-02-2008, 22:24
65_Xero_Huskie's Avatar
65_Xero_Huskie 65_Xero_Huskie is offline
One T
AKA: Mat
65_Xero_Huskie has a reputation beyond repute65_Xero_Huskie has a reputation beyond repute65_Xero_Huskie has a reputation beyond repute65_Xero_Huskie has a reputation beyond repute65_Xero_Huskie has a reputation beyond repute65_Xero_Huskie has a reputation beyond repute65_Xero_Huskie has a reputation beyond repute65_Xero_Huskie has a reputation beyond repute65_Xero_Huskie has a reputation beyond repute65_Xero_Huskie has a reputation beyond repute65_Xero_Huskie has a reputation beyond repute
Re: xbox controller
Yep. Our team used both sticks last year for 2 different motions.
Min-Max to the Max!
Unread 05-02-2008, 23:37
FRC #0334
Re: xbox controller
I understand the different modes, but each mode does not include every button and analog stick there is.
For our drive train we need them all. Is there any way i can use them all?
Unread 05-02-2008, 23:54
Re: xbox controller
A joystick port has four analog inputs and four switch inputs. The Chicklet can repurpose analog inputs to encode four more switches. So far as I can tell, supporting more than two analogs and twelve switches simultaneously is simply not possible. It's a hardware limitation of the OI's joystick ports.
Unread 06-02-2008, 19:43
FRC #0334
Re: xbox controller
what if we were to take out one of the analog wires and wire them to another com port?
Would it then be possible to use everything on that xbox controller?
Unread 06-02-2008, 20:48
Re: xbox controller
Take out one of what analog wires? Take it out from where?
Wire them to what other com port? And what "them" are you talking about?
I don't understand the question.
If you're talking about gutting the controller and wiring it directly to the OI, it could work, but I think the xbox controler's innards are not very easy to connect to. The analog controllers in particular are a very poor match for what the OI joystick inputs expect.
Unread 06-02-2008, 21:52
FRC #0334
Re: xbox controller
Sorry for the sloppy question.
But you still understood correctly. We opened up an xbox controller today and saw how the analog is wired and compared it to the joysticks first provides. It seems like exactly the same thing, but on a smaller scale.
I guess we will try to connect them and see if it works. I was wondering if it was possible and i guess it is. We will test the "poor match."
Ill put up the results once we are done.
Thanks.
Xbox Controller? ScottieDo555 Technical Discussion 24 29-01-2008 16:24
xbox 360 controller installation kuelin Technical Discussion 17 07-01-2008 19:43
Chicklet with MS XBOX 360 controller 354.FIRST Control System 2 19-04-2007 16:29
Regular Xbox Controller...HELP! lostandconfused Control System 1 13-02-2007 14:29
chicklet USB/xbox 360 controller spsteam1512 Control System 1 10-01-2007 23:14
