Go to Post FIRST is not advanced shop class - KenWittlief [more]
Unread 06-02-2008, 21:01
program1's Avatar
program1 program1 is offline
AKA: RJ
FRC #2441
program1 will become famous soon enough
button control
im trying to activate moters for a certain amount of time with a press of a button on the joystick. how do you make a button code?
ok, who ate my hot pocket?
Unread 06-02-2008, 21:17
eaglesfan10's Avatar
eaglesfan10 eaglesfan10 is offline
FRC #1647 (Iron Devils)
eaglesfan10 is an unknown quantity at this point
Re: button control
You could set a flag and use a counter. It would probably look something like this:
static int flag = 0;
static int counter = 0;
if(button_pressed)
flag = 1;
if(flag && counter < some_number)
//your code
else
flag = 0;
counter = 0;
counter++;
I'm probably missing something, but that's the general idea. I think there are about 40 loop counts in one second.
Unread 06-02-2008, 21:25
Alexa Stott's Avatar
Alexa Stott Alexa Stott is offline
All I do is twin.
AKA: elixir
FRC #0025 (Raider Robotix)
Alexa Stott has a reputation beyond reputeAlexa Stott has a reputation beyond reputeAlexa Stott has a reputation beyond reputeAlexa Stott has a reputation beyond reputeAlexa Stott has a reputation beyond reputeAlexa Stott has a reputation beyond reputeAlexa Stott has a reputation beyond reputeAlexa Stott has a reputation beyond reputeAlexa Stott has a reputation beyond reputeAlexa Stott has a reputation beyond reputeAlexa Stott has a reputation beyond repute
Send a message via AIM to Alexa Stott
Re: button control
For each port on your OI, you have px_sw_top, px_sw_trig, px_sw_aux1, and px_sw_aux2 with "x" being the appropriate port number. Each of these corresponds with a button or a trigger on whatever joystick is plugged into the port (trig and top being the most obvious).
Your code should look something like this when you program the buttons:
if(button)
     doSomething();
...and so on from there.
Remember that buttons are digital devices; they are either on or off (1 or 0, respectively).
To control time, we've always simply defined a static unsigned int to 0 and incremented it for each loop of the processor. It takes a lot of playing around to get the values right. There are other ways to do this, as stated above, but that is one of your options.
Hopefully that helps.
|Email:alexastott[at]gmail.com|Facebook|@zelixir|Google+|
[University of Maryland Computer Science, Psychology]
[Brunswick Eruption]
XBOX button fondyfire12 Programming 8 25-05-2007 15:39
button programming joesmomh00haha Programming 12 10-02-2007 10:36
Sarcasm Button Jessica Boucher CD Forum Support 3 19-03-2006 16:02
Button Making PureMachine4 Rumor Mill 58 16-04-2004 16:00
Button Bar Adrian Wong CD Forum Support 8 04-06-2001 20:27
