Go to Post You move on because FIRST isn't about the penalty or the un-penalty or whose robot is agressive and who is timid. - Collin Fultz [more]
Unread 06-02-2008, 22:13
tdlrali tdlrali is offline
FRC #0469 (Las Guerrillas)
tdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud of
Re: pic: 461's Drive Pod 2.6.2008
The left chain looks very loose, but it looks like you guys already have a slot cut for attaching an idler/tensioner. Correct?
Unread 06-02-2008, 22:52
Vikesrock's Avatar
Team 2175 Founder
AKA: Kevin O'Connor
You can actually see tensioners installed in the other two slots.
Unread 07-02-2008, 08:40
ducttapedude ducttapedude is offline
AKA: Peter
FRC #0233 (The Pink Team)
ducttapedude has a spectacular aura aboutducttapedude has a spectacular aura aboutducttapedude has a spectacular aura about
Send a message via AIM to ducttapedude
Beautiful machining patters.
Definately like the black tread and black plates.
Those are some nice looking wheels as well.
And what is that other thing in the backround on the table?
Think Poof
Team 007 - 2008: Thunderbot - Drive Kendal Reed Robot Showcase 12 05-02-2008 18:29
2008 Omni Drive Code Help Vasily Zaitsev Technical Discussion 5 27-01-2008 00:57
2008 Over Drive Manual Jaime65 General Forum 22 05-01-2008 21:49
pic: 461's black frame Logan Byers Robot Showcase 11 11-02-2005 22:16
Thank a Team with an i-Pod !!! OZ_341 General Forum 8 20-04-2004 23:57
