Re: mounting relief valve
I always consider your advise and rule quoting to be definative but don't see a clear or even a lawyered stretching of the rules to disallow what was suggested above in <R95> Quote:
-dave . |
Well the GDC reply to the posting makes a very clear statement that I still don't see in <R95>.
Interesting note, if one doesn't use the compressor, the size of the of the port to which you are attaching relief valve to does not matter. |
You can use the compressor, but have it "off board", ie not mounted to the robot. This way you can charge up the tank(s) with air pressure before a match, and not have to carry the compressor's weight on the robot. This only works for limited air use, such as shifting or running a small cylinder to do some infrequent task.
If you do this, you need two relief valves, one directly connected to the off-board compressor, and another on the robot plumbed to the storage tank side of the regulator. (clarification welcome...this is just an example) |
ya doing that is perfect for teams that have 2 speed transmissions and only switch gears once a match , its saves some weight.
I know a few teams that did that in AIM HIGH |
| Norgen Relief Valve | enpurx | Pneumatics | 9 | 07-02-2008 22:32 |
| Calibration of pressure relief valve | d235j | Pneumatics | 3 | 16-01-2008 14:12 |
| where do i place the norgen relief valve? | Reaper40 | Pneumatics | 1 | 25-01-2007 18:25 |
| Where do we get a relief valve? | P1d40n3 | Pneumatics | 4 | 17-01-2007 10:04 |
| Need the number for the Norgren Pressure relief valve | Jack21 | Pneumatics | 0 | 23-01-2004 16:32 |
