Go to Post The students who benefit from FIRST are the real "trophies". - David Brinza [more]
Go Back   Chief Delphi > Old Forum Archives > 2000
Unread 23-06-2002, 23:13
archiver archiver is offline
Forum Archival System
#0047 (ChiefDelphi)
Small parts
Posted by Richard Ragunton Jr.
Student on team #359 from Waialua High School.
Posted on 2/20/2000 6:03 PM MST
Hi,
I was wondering, when calculating the amount spent on small parts would we could the full amount purchased or the amout used on the robot.
Example: we purchase the minimum length of akuminim which costs $50 for 10 ft, we only used 5ft for our robot, would we count only $25 because thats all we used for our robot or would we have to count the whole cost?
#0047 (ChiefDelphi)
Re: Small parts
Posted by Nate Smith.
Other on team #66, GM Powertrain/Willow Run HS, from Eastern Michigan University and GM Powertrain.
Posted on 2/20/2000 6:27 PM MST
In Reply to: Small parts posted by Richard Ragunton Jr on 2/20/2000 6:03 PM MST:
As per Rule K1, 'Outside Sources - SPI Catalog', 4th bullet:
If you use only a portion of what you buy from Small Parts, you may prorate the dollar amount used to the smallest quantity listed for purchase in the catalog. For example, if you buy 5' of rod which could have been purchased by the foot, but end up using only 6', you may calculate the amount used as the purchase price for one foot (the minimum amount that you could have purchased in order to build your robot.)
Nate
[IMG] code is Off
Rules on making spare parts fyi DougHogg General Forum 0 02-04-2003 16:18
Small Parts orders archiver 2001 2 23-06-2002 23:50
Re: extruded-aluminum frame as small parts archiver 2001 1 23-06-2002 23:15
Re: extruded-aluminum frame as small parts archiver 2001 2 23-06-2002 23:15
Small Parts Problems archiver 2000 2 23-06-2002 22:48
