Go to Post Good story telling and animation know no age limits. - BMiller2559 [more]
  #91   Spotlight this post!
Unread 28-01-2008, 13:04
Guy Davidson Guy Davidson is offline
AKA: formerly sumadin
FRC #0008 (Paly Robotics)
Guy Davidson is a splendid one to beholdGuy Davidson is a splendid one to beholdGuy Davidson is a splendid one to beholdGuy Davidson is a splendid one to beholdGuy Davidson is a splendid one to beholdGuy Davidson is a splendid one to beholdGuy Davidson is a splendid one to beholdGuy Davidson is a splendid one to behold
Send a message via ICQ to Guy Davidson Send a message via AIM to Guy Davidson Send a message via MSN to Guy Davidson
Re: Are any teams planning on shooting the ball?
Originally Posted by Qbranch View Post
FYI I used a little calculus to figure out a way to calculate trajectories. If you know how far down range and how far up you want the apex of the ball will be, my equations will tell you how fast and at what angle you have to shoot the ball. If you all are interested, I'll post a scan of my piece of notebook paper.
-q
I'd be interested in seeing those equations. Math is always fun, especially when it's useful.
  #92   Spotlight this post!
Unread 30-01-2008, 12:00
Tytus Gerrish's Avatar
Tytus Gerrish Tytus Gerrish is offline
IGAB, ADHD, and Dislexic
AKA: Ty
FRC #0179 (SwampThing)
Team Role: Tactician
Tytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond repute
Originally Posted by cgredalertcc View Post
We are capturing the ball using a vacuum lifting the ball so that our arm is slightly below the rack and firing the ball over using two back to back 3/4 inch bore by 10 inch stroke cylinders we've had success with shorter stroke but we want to be sure we get it over so we opted for the longest ones. The funny thing is the 3/4's extend way faster than the 1&1/2's and the ball really doesn't require that kind of force so we get a pretty good shot out of it.
Please elaborate on your vacuum.
Are you pulling a vacuum inside the air cylinder by extending it, then plugging the compressed end, and then cocking the piston my some mechanical means?
  #93   Spotlight this post!
Unread 31-01-2008, 12:03
cgredalertcc cgredalertcc is offline
AKA: Charlie Baxter
FRC #1747 (Harrison Boiler Robotics)
cgredalertcc is a name known to allcgredalertcc is a name known to allcgredalertcc is a name known to allcgredalertcc is a name known to allcgredalertcc is a name known to allcgredalertcc is a name known to all
Send a message via AIM to cgredalertcc
we are generating a vacuum by the same means a shop vac would. We have been able to generate a vacuum of 26 inches of water using a multistage fan with the Fischer Price minus the gearbox. The conversion factor for vacuum is about 24 inches to 1 psi and based on the area of the cup we are using thats over 100 lbs of force on the ball. The rules specifically state that vacuums of this nature are permitted. I guess I wasn't clear in my explanation the cylinders are only for shooting the ball not pulling a vacuum. As of last night we decided to use three of the 3/4' bore cylinders to fire the ball.
  #94   Spotlight this post!
Unread 31-01-2008, 14:39
Furrah!! Furrah!! is offline
FRC #1425
Furrah!! is an unknown quantity at this point
our team has decided to go with a "flinging plank" powered by surgical tubing. Our test have it flinging the ball around 8-10 feet in the air. We plan on using the momentum of the robot moving forward to create out trajectory. This launcher can also place the ball for end game consistently.
  #95   Spotlight this post!
Unread 31-01-2008, 16:24
Asiatique296's Avatar
Asiatique296 Asiatique296 is offline
AKA: caro
FRC #0296 (Northern Knights)
Asiatique296 will become famous soon enough
Oui. L'équipe 296 de Montreal est entrain de fabriquer une catapulte pour lancer la balle par dessus la barre. On a deja lancé 9 pieds dans l'air plusieurs fois.
Les photos seront disponibles plus tard, car notre catapulte est top secret.
(Sorry about the french but i had to prove my Quebecness to my teammates. I know, its a horrible excuse, but it all makes sense to me.)
  #96   Spotlight this post!
Unread 31-01-2008, 21:58
Qbranch Qbranch is offline
wow college goes fast.
AKA: Alex
FRC #1024 (Kil-A-Bytes)
Qbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond repute
Ok, here's the (now well worn) piece of notebook paper that I did it on it Economics. Let's face it, the opportunity costs of doing it were very friendly since everyone can use a review of their calculus.
I'm sorry it's kind of hard to read in places, as i mentioned before it's not in the best shape anymore (has a few holes in it from folding/unfolding while we were designing our shooter). But, these equations have been empirically validated as accurate, so here you are. I know it got cut off but the top says "g should be put in negative" but you can see that in the test case down below anyhow.
Thankfully, the two really really important equations are clear and pretty easy to read Lymax is the Y location at which the trajectory peaks. Lx@ymax is the X location (how far down range) at which this Y peak (maximum height) occurs. The "test case" in the bottom 1/3 of the page shows an example using these equations.
If you have questions, please post. I realize it's hard to read, but it's also thankfully pretty high resolution, so just zoom in.
Click here to see the page (768k, png)
-q
Electrical Engineer Illini
1024 | Programmer '06, '07, '08 | Driver '08
  #97   Spotlight this post!
Unread 02-02-2008, 22:42
EZE115's Avatar
Happy Birthday! EZE115 EZE115 is offline
AKA: Estil Montero
FRC #1660 (Harlem Knights)
EZE115 is an unknown quantity at this point
We Are and it works MUHAHAHA
  #98   Spotlight this post!
Unread 02-02-2008, 23:27
Captain Sugar Captain Sugar is offline
AKA: Ben Cassidy
FRC #2354 (Wheelie Bots)
Captain Sugar is an unknown quantity at this point
Our launcher is spring-loaded and can fire the ball upwards about 8 feet. This is after 3 other failed designs ("Wow! We got nearly a foot that run!").
  #99   Spotlight this post!
Unread 02-02-2008, 23:56
Kevin.Core's Avatar
Kevin.Core Kevin.Core is offline
Head Mechanical
AKA: Kevin Meyer
FRC #2062 (C.O.R.E. (Community of Robotic Engineers)
Kevin.Core is an unknown quantity at this point
our primary focus is to make it around the field rather quickly while reserving the capability of lifting, and hurdling. A quick picture is posted in our showcase thread here. Should be a great game this year!
good luck!!
Team #2062 'Community Of Robotic Engineers' : GE, NASA, Rockwell Automation, School District of Waukesha, Marquette University, H&K Systems.
Rookie Year 2007
2007 Wisconsin All-Star Rookie Award, 2007 Nationals Quarter Finalist, 2008 St. Louis Kleiner Perkins Caufield & Byers Entrepreneurship Award, 2008 St. Louis Underwriters Laboratory Industrial Safety Award, 2008 St. Louis Website Award.
Waukesha, WI
Good luck to all in the 2008 Competitions!
  #100   Spotlight this post!
Unread 03-02-2008, 00:01
Chaos in a Can Chaos in a Can is offline
Joel Spadin
FRC #1736 (Robot Casserole)
Chaos in a Can is an unknown quantity at this point
Send a message via MSN to Chaos in a Can
We have a motor powered launcher.
It's basically one of the ever popular chain-driven elevated arms, but on steriods. And those steroid... they're on steroids too.
Due to what I'm assuming was a lack of decent squishy objects, our catapult's positive stop is currently cushioned with pink pencil erasers and duct tape.
During testing today, we could consistenly put the ball ~2 feet over the overpass.
2006 Xerox Creativity Award
2007 General Motors Industrial Design Award
2008 Judges' Award
2009 Chrysler Team Spirit Award
  #101   Spotlight this post!
Unread 06-02-2008, 19:14
TheNotoriousKid's Avatar
TheNotoriousKid TheNotoriousKid is offline
AKA: Shane O
FRC #0025 (Raider Robotix)
TheNotoriousKid is just really niceTheNotoriousKid is just really niceTheNotoriousKid is just really niceTheNotoriousKid is just really niceTheNotoriousKid is just really nice
Send a message via AIM to TheNotoriousKid
I see every team at the "finish lines" crankin up a catapult to launch a 7.3lbs ball, and it actually scares me.
  #102   Spotlight this post!
Unread 06-02-2008, 20:04
ChrisMcK2186's Avatar
ChrisMcK2186 ChrisMcK2186 is offline
Typer of doom
AKA: Chris McKenzie
FRC #2186 (Westfield Robotics)
ChrisMcK2186 is a glorious beacon of lightChrisMcK2186 is a glorious beacon of lightChrisMcK2186 is a glorious beacon of lightChrisMcK2186 is a glorious beacon of lightChrisMcK2186 is a glorious beacon of lightChrisMcK2186 is a glorious beacon of light
Send a message via AIM to ChrisMcK2186
Our ball recently got rabies, so I have to take it out back and shoot it
He don't actually plan to hurdle it, but our "manipulator type thingy" will make the ball pop up at some point in the game.
Chris McKenzie
2186
Working on Robotic Eagles group(PM for info)
Stephen Colbert-"Please tell me this leads to robot
battles."
Dean Kamen-"It does lead to kids building robots, and they do compete in the sport but we also teach the kids gracious proffesionalism, so while the robots are competing, they do it in a very, very gracious way."
Darn, I got into this for the battles!
  #103   Spotlight this post!
Unread 07-02-2008, 07:09
martin417's Avatar
Opinionated old goat
AKA: Martin Wilson
We are also using a vacuum manipulator to control the ball, and Bimba cylinders to shoot. We have found several important things:
Leave the vacuum on to shoot, you get better distance (if your cylinders can overcome the vacuum)
Ball inflation makes a huge difference in ball travel! Soft balls don't shoot very well!
  #104   Spotlight this post!
Unread 08-02-2008, 13:17
feliks_rosenber's Avatar
feliks_rosenber feliks_rosenber is offline
Félix
AKA: Mentor of Teams #2217 & #2669
FRC #2217 (FOMHA & KY Bots)
feliks_rosenber is a jewel in the roughfeliks_rosenber is a jewel in the roughfeliks_rosenber is a jewel in the rough
Send a message via MSN to feliks_rosenber
To all the teams which plan on shooting the ball:
Team 2669 KY Bots from Kiryat Yam, Israel has prepared a simple presentation with suggestions from FIRST on how to insure safety when building a launching mechanism.
It is called "Safe Shooter"
You can download the presentation from here:
http://www.chiefdelphi.com/media/papers/2082
And remember, safety FIRST!
Visit team 2217 channel:
http://www.youtube.com/profile?user=team2217
2007 Israel Regional GM/Technion Rookie All Stars
Participated in 2007 Atlanta World Championships (Newton Division)
______________________________________________
Visit team 2669 channel at:
http://www.youtube.com/user/team2669
  #105   Spotlight this post!
Unread 14-02-2008, 12:01
AHepperla's Avatar
AHepperla AHepperla is offline
Oh yeah, you know it...
AKA: Wheels
FRC #2202 (B'East Robotics)
AHepperla is an unknown quantity at this point
our initial design went bust so we are now lifting it and then launching it (our initial design would've flipped the robot...)
Are you allowed to herd another Teams Ball kE7JLM Rules/Strategy 8 06-01-2008 01:17
CVT, which teams are planning on using them for next year? Jeff K. Technical Discussion 51 28-08-2005 00:08
Are there any teams staying in the Marriott for Alanta? Atasuke768 Chit-Chat 6 15-04-2005 23:59
Are your teams offering any help at the UTC & NJ regional cyberknights195 Regional Competitions 4 01-03-2004 10:03
Ball Shooting Rookie000 General Forum 4 12-01-2004 10:33
