Go to Post "The reason we struggle with insecurity is because we compare our behind-the-scenes with everyone else's highlight reel." - davidthefat [more]
Unread 07-02-2008, 05:39
windell747 windell747 is offline
FRC #2477
windell747 will become famous soon enoughwindell747 will become famous soon enough
encoder suggestions
I'm looking for a low cost encoder to use to track position. That will be easy to interface with the RC. I dont need high resolution. I was wondering if anyone has any good suggestions that are tried and true and compatible with Kevin's code. Thanks!
Windell
#2477
Unread 07-02-2008, 07:49
Qbranch Qbranch is offline
wow college goes fast.
AKA: Alex
FRC #1024 (Kil-A-Bytes)
Qbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond repute
Re: encoder suggestions
Well if you look at my post on this thread I have a suggested encoder. Provided you've been using good ISR code practices, this should work at an absolute maximum freqency of 12.5KHz for two channels (aka 3,000RPM) but will not quadrature decode properly at this speed. You'll have to find out what your specific code can handle, unfortunately I can't tell you exaclty how it will perform on your code.
Although, I have no idea what you're mounting this to. Custom transmission? Something AndyMark? Bane Bots?
If you have any other/further questions, post.
-q
Electrical Engineer Illini
1024 | Programmer '06, '07, '08 | Driver '08
Unread 07-02-2008, 07:55
FRC #2477
This encoder will keep track of rotation of a wheel in the center of our robot that will just drag along and not serve as a drive wheel.I was thinking about using one of the anymark wheels that came with the kit and mount an aluminum plate to the hub mounting holes in which will mount to the encoder shaft. I don't need high resolution. Mostly I need simplicity, reliability, and ease of interface.
Thanks,
Windell
Encoder help E_Unit Electrical 5 16-02-2007 11:02
Encoder Death rfolea Programming 8 14-02-2007 14:06
Encoder Wiring! RKElectricalman Electrical 2 10-02-2007 23:15
encoder wiring karin l. Motors 3 07-02-2007 00:14
encoder.c Gary Bonner Programming 2 14-01-2005 13:41
