Go to Post We also have a CNC mill and CNC lathe, but we're interested in doing this only if we can do it quickly. Milling anything takes too long for my MTV-generation attention span. :) - Madison [more]
Unread 07-02-2008, 08:28
GaryVoshol's Avatar
Cogito ergo arbitro
Re: Team 935 Electronics
Originally Posted by sdcantrell56 View Post
Also you can only use 1 van door motor. Maybe you are talking about the window motors.
Originally Posted by DustinB_3 View Post
Could you please quote the rule. I looked but couldn't find the restriction.
<R59> Additional motors specifically permitted on 2008 FRC ROBOTS include:
All motors, actuators, and servos provided in the 2008 Kit Of Parts,
HITEC HS-322HD servos,
FIRST Tech Challenge (FTC) servos (Innovation First part number 276-2162),
FIRST Tech Challenge (FTC) motors (Innovation First part number 276-2163),
One or two additional 2-1/2” CIM motors (part #FR801-001 and/or M4-R0062-12 in addition
to those provided in the Kit Of Parts. This means that up to four, and no more, 2-1/2” CIM
motors can be used on the ROBOT.
This is the only rule I could find and it says that you can buy additional motors as long as they are the same as what's in the kit of parts.
So close. Look here:
<R58> Motors, pumps, and, Robot Controllers from previous robots shall not be used in addition to
those provided in the 2008 Kit Of Parts. They may be used as direct one-to-one SPARE
PARTS
for those provided if the provided part fails or is damaged. They can only be used if
they are identical to the part being replaced.
(emphasis mine)
<R59> should not have used the first word "Additional" as it misleads people. "Additional" should have been only in the CIM bullet point.
The first bullet point says you can use motors found in the KoP. It does not say that you can use extra copies of those motors. One van door motor was given in the kit; one may be used.
(since 2004)
Team 935 as of 2-2-2008 DustinB_3 Robot Showcase 19 04-02-2008 17:19
Vid: Team 935 07 Bot JoelGoering Robot Showcase 12 24-02-2007 20:33
pic: 935 RaileRobotics robot on ship day railerobotics Extra Discussion 5 20-02-2007 15:18
935 as of last night railerobotics Robot Showcase 51 03-01-2007 14:09
thanks 118 and 935 at denver Masterfork Thanks and/or Congrats 4 28-03-2005 01:14
