Go to Post I love the dedication of Robotics kids. :) - Danielle H [more]
Unread 07-02-2008, 08:29
Andrew Schuetze's Avatar
Andrew Schuetze Andrew Schuetze is offline
499 Founder / Alamo FTC & FLL AP
Andrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond repute
Re: mounting relief valve
Well the GDC reply to the posting makes a very clear statement that I still don't see in <R95>.
The pressure relief valve must be connected directly to the Thomas compressor. No intermediate connectors are permitted. This is required by Rule <R95>.
This would disallow adding an adapter so that one can mount it on the opposite side of the compressor. Not being a lawyer with the rules, I read
The relief valve must be attached to the compressor. If the compressor is not used on the ROBOT, then an additional relief valve must be obtained and included in the primary pneumatic circuit on the ROBOT
as being able to add an adapter to mount it to the compressor but can now see a literal meaning that the valve must be directly connected to the compressor via the GDC clarification. I post this response only to provide insight into future definitions in the robot design document.
Interesting note, if one doesn't use the compressor, the size of the of the port to which you are attaching relief valve to does not matter.
APS
Founder FRC 499
Parent alumni FRC 2745 & 4219
Co-Coach FTC 4549 & 6407
Alamo FTC Affiliate Partner
Alamo FLL Affiliate Partner
Norgen Relief Valve enpurx Pneumatics 9 07-02-2008 22:32
Calibration of pressure relief valve d235j Pneumatics 3 16-01-2008 14:12
where do i place the norgen relief valve? Reaper40 Pneumatics 1 25-01-2007 18:25
Where do we get a relief valve? P1d40n3 Pneumatics 4 17-01-2007 10:04
Need the number for the Norgren Pressure relief valve Jack21 Pneumatics 0 23-01-2004 16:32
