Go to Post No one ever said that this was easy. - Jaine Perotti [more]
Unread 06-02-2008, 19:46
Redbull2486 Redbull2486 is offline
FRC #2012
Redbull2486 is an unknown quantity at this point
mounting relief valve
just a question do you have to mount the relief valve on a certain side of the compressor
Unread 06-02-2008, 20:06
Miner Miner is offline
AKA: Jacob Miner
FRC #2077 (Laser Robotics)
Miner is on a distinguished road
Re: mounting relief valve
I dont think so.
Do what you like... Like what you do!
Jake, the Life Is Good guy
Unread 06-02-2008, 21:27
KTorak's Avatar
KTorak KTorak is offline
Fire Rescue 47
AKA: Kyle Dersch
FRC #1023 (Bedford Express)
Team Role: Driver
KTorak has a reputation beyond reputeKTorak has a reputation beyond reputeKTorak has a reputation beyond reputeKTorak has a reputation beyond reputeKTorak has a reputation beyond reputeKTorak has a reputation beyond reputeKTorak has a reputation beyond reputeKTorak has a reputation beyond reputeKTorak has a reputation beyond reputeKTorak has a reputation beyond reputeKTorak has a reputation beyond repute
Send a message via AIM to KTorak
No, you can mount it any where easily accessible. We mounted ours on the boom last year so we didnt have to reach inside the chasis to get to it.
Kyle D- Myspace - Facebook
2008 Bedford Express Driver & Build & Design (Team) Co-Leader
2007 Bedford Express Driver & Build & Design (Team) Leader
2006 Bedford Express Driver, Build Team Member, & Board of Directors
2005 Bedford Express Rookie, Build Team Member & Robot Operator
2008 - GLR Quarter Finalist
2007 - GLR Finalist & Boilermaker Finalist & MARC Off Season Event Winner
2006 - GLR Johnson & Johnson Sportsmanship Award & Archimedes 7th Seed Quarter Finalist
2005 - GLR Finalist & Judges Award.
2004 - GLR Semi Finalist.
2003 - GLR/DTR Quarter Finalist & GLR/NAT'L Rookie All Star.
Unread 06-02-2008, 21:29
usbcd36's Avatar
usbcd36 usbcd36 is offline
AKA: "DOS"
FRC #2399 (The Fighting Unicorns)
usbcd36 is a jewel in the roughusbcd36 is a jewel in the roughusbcd36 is a jewel in the rough
The two outlets on the compressor are different sizes. The emergency relief valve will only fit in the larger of the two, so I guess the answer is that yes, you do have to mount it on a specific side.
Unread 06-02-2008, 21:37
kevin.li.rit's Avatar
Imaginary Friend
AKA: Kevin Li
FRC #0596 (SciClones)
Team Role: Student
Not unless you put an adapter on the smaller end or pipe it somewhere else.
Kevin Li
596 - Sciclones
1405 - Finney Falcons
2262 - Holliston Panthers
Unread 07-02-2008, 00:01
dlavery's Avatar
dlavery dlavery is offline
Curmudgeon
FRC #0116 (Epsilon Delta)
Which you are not allowed to do. See Rule <R95>.
Unread 07-02-2008, 00:40
Andrew Schuetze's Avatar
Andrew Schuetze Andrew Schuetze is offline
499 Founder / Alamo FTC &amp;amp; FLL AP
Andrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond repute
I always consider your advise and rule quoting to be definative but don't see a clear or even a lawyered stretching of the rules to disallow what was suggested above in <R95>
<R95> Teams are not allowed to adjust the 125-psi relief valve. The valve has been calibrated
prior to shipping. The relief valve must be attached to the compressor. If the compressor is
not used on the ROBOT, then an additional relief valve must be obtained and included in the
primary pneumatic circuit on the ROBOT (see Rule <R91>).
As long as one doesn't adjust the lock nut thereby adjusting the calibration, isn't it legal to mount it anywhere in the primary pneumatic circiut? The text of <R91> follows.
<R91> If pneumatic components are used on the ROBOT, the pneumatic system on the ROBOT
must contain as a minimum the following components, connected in accordance with this
section.
 Pressure gauges to display the “working” and “stored” air pressure.
 An easily visible and accessible pressure vent valve to manually relieve the stored
pressure.
 A pressure relief valve, calibrated and set to release at 125psi.
 A pressure switch, calibrated and connected to the Robot Controller.
When we mounted this year's compresser it didn't have the relief valve mounted on it from the factory so we used an adaptor and put it on the side that allowed us more room for the rest of the fixutures. I'll change it if need be but need someone to point out my mis-reading of the quoted rules
APS
Founder FRC 499
Parent alumni FRC 2745 & 4219
Co-Coach FTC 4549 & 6407
Alamo FTC Affiliate Partner
Alamo FLL Affiliate Partner
Unread 07-02-2008, 01:02
dlavery's Avatar
Curmudgeon
You provided the answer in your own citation. Specifically, see the third sentence of Rule <R95>:
<R95> Teams are not allowed to adjust the 125-psi relief valve. The valve has been calibrated prior to shipping. The relief valve must be attached to the compressor. If the compressor is not used on the ROBOT, then an additional relief valve must be obtained and included in the primary pneumatic circuit on the ROBOT (see Rule <R91>).
To me, that makes it very clear that you can not take the relief valve and "pipe it somewhere else." In addition, this exact topic has also been addressed in this Q&A system answer.
-dave
Unread 07-02-2008, 08:29
Well the GDC reply to the posting makes a very clear statement that I still don't see in <R95>.
The pressure relief valve must be connected directly to the Thomas compressor. No intermediate connectors are permitted. This is required by Rule <R95>.
This would disallow adding an adapter so that one can mount it on the opposite side of the compressor. Not being a lawyer with the rules, I read
as being able to add an adapter to mount it to the compressor but can now see a literal meaning that the valve must be directly connected to the compressor via the GDC clarification. I post this response only to provide insight into future definitions in the robot design document.
Interesting note, if one doesn't use the compressor, the size of the of the port to which you are attaching relief valve to does not matter.
APS
Founder FRC 499
Unread 07-02-2008, 10:09
MrForbes's Avatar
AKA: Jim
FRC #1726 (N.E.R.D.S.)
You can use the compressor, but have it "off board", ie not mounted to the robot. This way you can charge up the tank(s) with air pressure before a match, and not have to carry the compressor's weight on the robot. This only works for limited air use, such as shifting or running a small cylinder to do some infrequent task.
If you do this, you need two relief valves, one directly connected to the off-board compressor, and another on the robot plumbed to the storage tank side of the regulator.
(clarification welcome...this is just an example)
Unread 07-02-2008, 10:59
sporno's Avatar
sporno sporno is offline
AKA: David
FRC #0540 (Talon)
sporno will become famous soon enoughsporno will become famous soon enough
Send a message via AIM to sporno
ya doing that is perfect for teams that have 2 speed transmissions and only switch gears once a match , its saves some weight.
I know a few teams that did that in AIM HIGH
2005 NASA/VCU Quarter-finalist
2006 NASA/VCU regional-Semi-finalist
2006 FIRST Robot Rumble-Quarter-finalist
2006 FIRST Robot Rumble-Most Promosing Rookie Drive team.
2006 Championship-Curie
2007 NASA/VCU- Regional Winner
2007 Championship-Galileo
2007 FIRST Robot Rumble-Semi-finalist
80+ matches on the field
Norgen Relief Valve enpurx Pneumatics 9 07-02-2008 22:32
Calibration of pressure relief valve d235j Pneumatics 3 16-01-2008 14:12
where do i place the norgen relief valve? Reaper40 Pneumatics 1 25-01-2007 18:25
Where do we get a relief valve? P1d40n3 Pneumatics 4 17-01-2007 10:04
Need the number for the Norgren Pressure relief valve Jack21 Pneumatics 0 23-01-2004 16:32
