Go to Post "One man's trash is our robotics team's fundraiser" (We have an aluminum can drive to raise money) - bombadier337 [more]
Unread 06-02-2008, 21:49
DustinB_3 DustinB_3 is offline
FRC #0935 (Railerobotics)
DustinB_3 is an unknown quantity at this point
Team 935 Electronics
Unread 06-02-2008, 21:56
Jaybee1405
Posts: n/a
Re: Team 935 Electronics
Nice. Very organized, I like how you hide all the wires.
No spikes? I assmued there was at least one cylinder on that manipulator you guys have.
Unread 06-02-2008, 21:59
DarkFlame145 DarkFlame145 is offline
That guy
AKA: Dennis
no team (None this season)
DarkFlame145 has much to be proud ofDarkFlame145 has much to be proud ofDarkFlame145 has much to be proud ofDarkFlame145 has much to be proud ofDarkFlame145 has much to be proud ofDarkFlame145 has much to be proud ofDarkFlame145 has much to be proud ofDarkFlame145 has much to be proud ofDarkFlame145 has much to be proud ofDarkFlame145 has much to be proud of
Send a message via AIM to DarkFlame145
dang, 2 maxy blocks?
TR-X 145 of Norwich, NY: Student 2005-2008
Exploding Bacon 1902 of Winter Park, FL: Mentor 2009
US Navy Corpsman 2011-????
Unread 06-02-2008, 22:03
vhcook's Avatar
vhcook vhcook is online now
Reader of Things
AKA: Victoria
FRC #1939 (Kuh-nig-its)
vhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond repute
That second Maxi block needs to be directly connected to the Rockwell PDB. (See the sixth bullet on <R50>)
Apart from that, it looks great.
Unread 06-02-2008, 22:10
ea6b607 ea6b607 is offline
FRC #2044
ea6b607 is an unknown quantity at this point
very nice organization.....wish we could afford garolite.
Unread 06-02-2008, 22:34
OOps, thanks for that catch. I'll be sure to change that tomorrow.
We aren't using spikes. We are using a motor and soon to be motors to lift our elevator. The van door motor doesn't have enough torque to lift our mechanism and the ball so we are going to try 2 van door motors and see if that works.
Unread 06-02-2008, 22:35
I don't know what garolite even is. The plate is aluminum with carbon fiber backing.
Unread 06-02-2008, 23:04
divergentdave divergentdave is offline
FRC #1816 (Green Machine)
divergentdave is a jewel in the roughdivergentdave is a jewel in the roughdivergentdave is a jewel in the rough
Send a message via AIM to divergentdave
The ATC fuse panel should also be directly connected to the PDB. In this photo, it looks like it is connected to one of the two Maxi blocks. Furthermore, are you using red wire for that? It's hard to tell, but it looks black in the picture.
Besides these little nit-picks, very nice board. It looks really neat, no rat's nest of cables.
Team 1816 - The Green Machine
Unread 06-02-2008, 23:27
Wow I totally missed that. I didn't even realize I made that mistake. That's also something I am going to have to fix tomorrow. I connect the black wire where the red should have gone and forgot to put the other wire on altogether. The ATC is connected to the PDB, I just connected it wrong. Thanks for catching all of my stupid mistakes
Unread 07-02-2008, 00:07
sdcantrell56's Avatar
AKA: Sean
FRC #2415 (Wired Cats)
Also you can only use 1 van door motor. Maybe you are talking about the window motors.
Mentor 2415
Unread 07-02-2008, 08:22
Could you please quote the rule. I looked but couldn't find the restriction.
<R59> Additional motors specifically permitted on 2008 FRC ROBOTS include:
All motors, actuators, and servos provided in the 2008 Kit Of Parts,
HITEC HS-322HD servos,
FIRST Tech Challenge (FTC) servos (Innovation First part number 276-2162),
FIRST Tech Challenge (FTC) motors (Innovation First part number 276-2163),
One or two additional 2-1/2” CIM motors (part #FR801-001 and/or M4-R0062-12 in addition
to those provided in the Kit Of Parts. This means that up to four, and no more, 2-1/2” CIM
motors can be used on the ROBOT.
This is the only rule I could find and it says that you can buy additional motors as long as they are the same as what's in the kit of parts.
Unread 07-02-2008, 08:28
GaryVoshol's Avatar
Cogito ergo arbitro
So close. Look here:
<R58> Motors, pumps, and, Robot Controllers from previous robots shall not be used in addition to
those provided in the 2008 Kit Of Parts. They may be used as direct one-to-one SPARE
PARTS
for those provided if the provided part fails or is damaged. They can only be used if
they are identical to the part being replaced.
(emphasis mine)
<R59> should not have used the first word "Additional" as it misleads people. "Additional" should have been only in the CIM bullet point.
The first bullet point says you can use motors found in the KoP. It does not say that you can use extra copies of those motors. One van door motor was given in the kit; one may be used.
(since 2004)
Unread 07-02-2008, 08:33
Wow, your right I must be as blind as a bat. I skipped right over that rule. Thanks for your help. Looks like we're stuck using 2 FP motors. Has anyone had any experience with them. Do they have sufficient torque and are they robust enough? Any suggestions?
Unread 07-02-2008, 08:45
GaryVoshol's Avatar
Cogito ergo arbitro
Also see this Q&A: http://forums.usfirst.org/showthread.php?t=8568
And this: http://forums.usfirst.org/showthread.php?t=8142
(since 2004)
Unread 07-02-2008, 08:59
Post Re: Team 935 Electronics
Originally Posted by GaryVoshol View Post
We're probably going to use 2 FP motors and gearboxes not window motors.
Team 935 as of 2-2-2008 DustinB_3 Robot Showcase 19 04-02-2008 17:19
Vid: Team 935 07 Bot JoelGoering Robot Showcase 12 24-02-2007 20:33
pic: 935 RaileRobotics robot on ship day railerobotics Extra Discussion 5 20-02-2007 15:18
935 as of last night railerobotics Robot Showcase 51 03-01-2007 14:09
thanks 118 and 935 at denver Masterfork Thanks and/or Congrats 4 28-03-2005 01:14
