Go to Post And the only person who could really save my butt, Brandon Martus... is sitting across the table from me. Laughing. - Amanda Morrison [more]
Unread 06-02-2008, 19:11
sweetie_pi sweetie_pi is offline
AKA: Nica
FRC #2189
sweetie_pi is an unknown quantity at this point
I am going crazy
My team wants me and my other programming buddy to program the arm as a digital so that it moves up and down when you push a button and release. How the heck do I do that????They try telling me to look it up but so far I have not found it.
hi
I am a neomaxizoondweebi and dang proud of it
Unread 06-02-2008, 19:16
psy_wombats's Avatar
psy_wombats psy_wombats is offline
AKA: A. King
FRC #0467 (Duct Tape Bandits)
psy_wombats has a spectacular aura aboutpsy_wombats has a spectacular aura aboutpsy_wombats has a spectacular aura about
Re: I am going crazy
I'm not sure I understand what your team wants you to do... Do you want to make two buttons, one that moves the arm up, and the other to move it down, or are looking for one button to do both...? What will releasing the button do, exactly? Please explain so that everyone can help better.
Unread 06-02-2008, 19:22
pheadxdll pheadxdll is offline
AKA: Alex
FRC #1225 (Amperage Robotics)
pheadxdll has much to be proud ofpheadxdll has much to be proud ofpheadxdll has much to be proud ofpheadxdll has much to be proud ofpheadxdll has much to be proud ofpheadxdll has much to be proud ofpheadxdll has much to be proud ofpheadxdll has much to be proud ofpheadxdll has much to be proud of
Are you programming in MPLAB or easyC?
Amperage Robotics Team 1225
Site under-going revamp. :/
Unread 06-02-2008, 19:37
GGCO's Avatar
GGCO GGCO is offline
AKA: Grant
FRC #3357
GGCO is a splendid one to beholdGGCO is a splendid one to beholdGGCO is a splendid one to beholdGGCO is a splendid one to beholdGGCO is a splendid one to beholdGGCO is a splendid one to beholdGGCO is a splendid one to beholdGGCO is a splendid one to behold
Send a message via AIM to GGCO
Um. Don't you need sensors or something? Maybe a limit switch.
"Great spirits have always encountered violent opposition from mediocre minds" - Albert Einstein
The FIRST Alliance
COMETS Robotics
Website
Unread 06-02-2008, 19:57
wireties's Avatar
wireties wireties is offline
Principal Engineer
AKA: Keith Buchanan
Limit switches are the preferred way to do this. Using simple state machine code is a good way to code the behavior. Check out this simple code from last year, the RunArm function is called each time through the slow loop.
typedef enum
ARM_UNKNOWN,
ARM_EXTENDING,
ARM_RETRACTING,
ARM_EXTENDED,
ARM_RETRACTED,
ARM_LAST
} ARM_STATES;
typedef struct
CLAW_STATES eClawState;
ARM_STATES eArmState;
MAST_STATES eMastState;
} ARM_DATA;
#define ARM_MOTOR_EXTEND_DRIVE 192
#define ARM_MOTOR_RETRACT_DRIVE 64
#define ARM_MOTOR_OFF_DRIVE 128
#define RHS_ARMEXTEND_IN p1_sw_top
#define RHS_ARMRETRACT_IN p1_sw_top
#define RHS_ARM_MOTOR pwm04
#define RHS_ARM_EXTEND_LIMIT rc_dig_in06
#define RHS_ARM_RETRACT_LIMIT rc_dig_in07
static void RunArm(ARM_DATA *pData)
// if we are in an out of range state
if (pData->eArmState >= ARM_LAST)
pData->eArmState = ARM_UNKNOWN;
switch (pData->eArmState)
case ARM_UNKNOWN:
// always extend the arm if in an unknown state
pData->eArmState = ARM_EXTENDING;
break;
case ARM_EXTENDING:
if (RHS_ARM_EXTEND_LIMIT)
// still opening
RHS_ARM_MOTOR = ARM_MOTOR_EXTEND_DRIVE;
else
// we are open
pData->eArmState = ARM_EXTENDED;
break;
case ARM_RETRACTING:
// still closing
RHS_ARM_MOTOR = ARM_MOTOR_RETRACT_DRIVE;
else
// we are closed
pData->eArmState = ARM_RETRACTED;
break;
case ARM_EXTENDED:
RHS_ARM_MOTOR = ARM_MOTOR_OFF_DRIVE;
if (RHS_ARMRETRACT_IN)
// follow command to close
pData->eArmState = ARM_RETRACTING;
break;
case ARM_RETRACTED:
if (RHS_ARMEXTEND_IN)
// follow command to open
break;
break;
default:
break;
HTH
Unread 06-02-2008, 20:12
Laaba 80 Laaba 80 is offline
AKA: Joey
FRC #1714 (MORE Robotics)
Laaba 80 has a reputation beyond reputeLaaba 80 has a reputation beyond reputeLaaba 80 has a reputation beyond reputeLaaba 80 has a reputation beyond reputeLaaba 80 has a reputation beyond reputeLaaba 80 has a reputation beyond reputeLaaba 80 has a reputation beyond reputeLaaba 80 has a reputation beyond reputeLaaba 80 has a reputation beyond reputeLaaba 80 has a reputation beyond reputeLaaba 80 has a reputation beyond repute
Wow, yours seems kind of confusing. Another way of doing it which in my opinion is easier is
unsigned char motorup = TRUE;
unsigned char motordown = TRUE;
if (rc_dig_in01 == 1) //If the limit switch at the top is pressed
motorup = FALSE;
else
motorup = TRUE;
if (rc_dig_in02 == 1) //Limit switch at bottom
motordown = FALSE;
else
motordown = TRUE;
if (p1_sw_trig == TRUE && motorup == TRUE)
pwm01 = 200; //Assuming that a # higher that 127 goes up
if (p1_sw_top == TRUE && motordown == TRUE)
pwm01 = 50; //Assuming lower # goes down
else
pwm01 = 127;
This is how I like to do it. If you think another way is easier go for that. it is all about how you feel comfortable using code. Also I just made up the values and pwm numbers use whatever your motors and sensors are plugged into. Also im sorry about the font. I pressed a button and it changed the font and im not sure how to put it back to normal
Joey
Driving Record - 75-43-8
Coaching Record - 92-65
Unread 06-02-2008, 21:56
neutrino15's Avatar
neutrino15 neutrino15 is offline
plɹoʍ ollǝɥ
AKA: Jordan Perr
FRC #0694 (Stuypulse)
neutrino15 is just really niceneutrino15 is just really niceneutrino15 is just really niceneutrino15 is just really nice
Well, it depends on how your robot is designed, and what your program already has in it.
The button pushing part is easy, just look in dashboard to find the button you want. Something like the following will toggle up/down on press. You don't need to hold the button with this routine either:
//at the top:
#define BUTTON p3_sw_trig
//in the loop:
static char armMove;
if(BUTTON & armMove==0){
     if(the arm is down)
         armMove = 1;
     else
         armMove = 2;
if(armMove){//this uses the fact that both 1 and 2 will be true, while 0 will be false.
    if(moveArm(armMove))
        armMove = 0;
then, down the page (or in another file), you need to have a function that actually moves the arm, and returns true if the arm is done moving.
int moveArm(char way){
    char finished
    if(way == 1){
        //move the arm up, set pwms.
        //you probably want to use a PID loop.
        //return 1 if the arm is there already, and set the pwm to 127.
    } else {
        //move the arm down, set pwms.
   return 0;
Thats the way I would attempt to do it. Depending on your bot, you may have to use some sort of a PID loop to get the arm to the correct position. If you use limit switches instead of a POT, you could probably do it with just a P loop.
Unread 07-02-2008, 10:09
wireties's Avatar
Principal Engineer
AKA: Keith Buchanan
"Wow, yours seems kind of confusing"
Our algorithm is a state machine. If we drew each algorithm on a white board, ours would look much simpler than yours. And ours is more efficient, each time it is called only the code in one case is executed. Yours seems just as complex. You have almost as many 'if' clauses as we have cases. I reckon the use of macros and a switch statement would make it look more complex to a less experienced programmer. But our team has a number of software mentors to help the students.
HTH
Unread 07-02-2008, 10:18
billbo911's Avatar
billbo911 billbo911 is online now
AKA: That's "Mr. Bill"
FRC #2073 (EagleForce)
We are doing exactly as you describe. It takes to simple functions, call the first one then call the second. The first one looks at the button inputs on the console, the second one sends the command to the lift function.
int Get_Oi_Switch (void)
	if (p1_sw_top == 1)
		liftcmd = LOAD;
	if (p1_sw_trig == 1)
		liftcmd = HURDLE;
	if (p1_sw_aux1 == 1)
		liftcmd = PICK;
	if (p1_sw_aux2 == 1)
		liftcmd = PLACE;
	return liftcmd;
int Set_Lift_Height (int pos_demand)
  int liftdrv;
  int liftvel;
	liftpos = ((int)Get_Encoder_5_Count());
	liftposerr = (pos_demand - liftpos);
	liftvel = (liftpos - lastliftpos);
	lastliftpos = liftpos;  // Save position for next loop
	liftdrv = ((liftposerr * LIFT_KP) + (liftvel * LIFT_KD));  // Actual PD equation
	if (liftdrv > LIFT_MAX_V)
		liftdrv = LIFT_MAX_V; // Limit lift speed to defined range
	if (liftdrv < -LIFT_MAX_V)
		liftdrv = -LIFT_MAX_V;
	return (liftdrv + 127);
As you can see, there are some definitions that are set up outside of this file that define the individual heights and velocities. Also included in the Set_Lift_Height function is a PD loop. We are not using the integral function of a PID loop.
EDIT: If it helps, feel free to use this code. Just make sure you understand it and modify it to match your system. All I ask is that you let us know how it works out for you.
Unread 07-02-2008, 18:30
AKA: Nica
FRC #2189
WOW!!! thinks for all the help and sorry I was not to specific with the function but I think my team member and I can put something together now. So Thanks a bunch.
hi
My error derivative is going crazy Nathans Programming 3 19-01-2008 17:56
crazy game Mike Ciance Fantasy FIRST 22 25-05-2004 11:37
Big for Joe! Going....Going..... archiver 2001 9 23-06-2002 23:29
crazy stuff chris144 Chit-Chat 19 08-04-2002 20:13
