Go to Post The 2016 Palmetto regional will be the most watched regional during week 0.5. - Procolsaurus [more]
Unread 07-02-2008, 10:14
jonboy jonboy is offline
Engineer/Mentor
FRC #0885 (The Green Team)
jonboy is an unknown quantity at this point
Controller Configuration reuse?
How can I use the same Controller Configuration that was entered in Project A when I start a new Project B using the same HW setup?
... jon
Unread 07-02-2008, 11:37
Re: Controller Configuration reuse?
I didn't see any options for saving/exporting that information. To use an already-entered configuration, I would copy the old project in its entirety, then delete the code that I didn't want to keep.
Unread 07-02-2008, 14:09
Kingofl337's Avatar
You didn't see anything....
AKA: Adam
FRC #0501 (Power Knights)
Under the options menu -> Import Controller Configuration
Select the project you wish to import your configuration from.
wheel configuration Buildteam2450 Technical Discussion 2 15-01-2008 10:43
Code Reuse - consider code as COTS parts? ericand Programming 6 17-01-2007 00:23
Belt Configuration Hadi379 Technical Discussion 8 10-01-2007 02:57
Configuration File? FFnut Programming 2 03-02-2006 17:38
Reuse Robot RudimentaryPeni General Forum 2 19-01-2006 22:00
