Go to Post I never had any doubt; good people who do good quality work will always prosper. - Gary Dillard [more]
Unread 07-02-2008, 01:37
Mr. Freeman Mr. Freeman is offline
Put better title here.
AKA: Kellan
no team (CSM Robotics)
Mr. Freeman is a splendid one to beholdMr. Freeman is a splendid one to beholdMr. Freeman is a splendid one to beholdMr. Freeman is a splendid one to beholdMr. Freeman is a splendid one to beholdMr. Freeman is a splendid one to beholdMr. Freeman is a splendid one to behold
Interesting victor failure
Today was going to be our first day for driving practice on the robot (which we have somehow managed to finish before ship date). Previous to today, the robot was complete enough to drive, operate pneumatics, etc. The electronics functioned correctly.
Well, we take the robot to an open area and get it there by pushing it. I turn the robot on and push the joysticks forward. It drives about 5 feet and then we hear POP! POP! and see 2 bright flashes. I hit the E-stop button but it doesn't kill the right-side track. (Good thing we mounted the main breaker in an accessible place).
Long story short, one of the victors got fried and always supplied power to the drive motor it was connected to even when it had no signal from the RC. I unplugged the power to the RC and turned the robot on, the right side track still spun. ALL of the victors had the flashing yellow LED indicating that they had no signal.
After analysis, we find that 3 of the black things with the 3 leads coming out of them attached to the victor (are they called mosfets?) blew holes in themselves.
Has anyone heard of a victor failing this way? I was under the impression that the victors would supply no electricity if they were damaged and not working. Also, is it possible that pushing the robot (and thus supplying electricity back to the victors) caused this one to fail? We've never had problems with this in the past.
EDIT: We did double-check that everything was wired correctly both before and after this happened.
"Time is an illusion, lunchtime doubly so."
-Douglas Adams
“Why is it that I can walk into Wal-Mart and buy boxes of bullets and black powder, but I can’t buy potassium perchlorate to do science because it can also be used to make explosives?”
-Theodore Gray
Unread 07-02-2008, 01:47
dtengineering's Avatar
AKA: Jason Brett
Re: Interesting victor failure
Wow! Although we let the magic smoke out of a Victor in our first year (late night, hooked the input leads up backwards) we've used... well... a couple of dozen of them by now and never had anything like what you have described happen.
I've heard of them blowing when metal shavings fall into them from above during repairs and aren't noticed before power-up (hint: cover your Victors when working from above) but have not heard of the "locked on" state that you describe.
I guess that given that something like 6,000 victors were sent to teams all over the world this year that it is possible that you got a bad one, but I wouldn't be surprised if IFI wanted to take a look at the dead one to figure out how it ended up in such a dangerous failure mode.
I hope you are able to replace it and carry on with your testing without too much lost progress.
Jason
Unread 07-02-2008, 02:52
Eldarion's Avatar
Eldarion Eldarion is offline
Electrical Engineer / Computer Geek
AKA: Eldarion Telcontar
no team (Teamless Orphan)
Eldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond repute
Send a message via AIM to Eldarion Send a message via Yahoo to Eldarion
If you are interested in the exact cause of the MOSFET failure, take a look at this Web page: http://www.4qd.co.uk/serv/MOSFETfail.html
Especially look under the section entitled dV/dt failure--it probably describes your situation perfectly.
Also, while most MOSFETs fail open, occasionally one can fail shorted, which would apply continuous power to your motor. Because the motor was not drawing enough current to either burn out the shorted MOSFET or trip the circuit breaker, the motor continued to operate.
Eldarion
CMUCam not working? Tracks sporadically? Try this instead: http://www.falconir.com!
PM me for more information if you are interested (it's open source!).
Want the FIRST Email blasts? See here: http://www.chiefdelphi.com/forums/sh...ad.php?t=50809
"The harder the conflict, the more glorious the triumph. What we obtain too cheaply, we esteem too lightly; it is dearness only that gives everything its value."
-- Thomas Paine
If it's falling apart it's a mechanical problem. If it's spewing smoke it's a electrical problem.
If it's rampaging around destroying things it's a programming problem.
"All technology is run on 'Magic Smoke' contained within the device. As everyone knows, whenever the magic smoke is released, the device ceases to function."
-- Anonymous
I currently speak: English, some German, Verilog, x86 and 8051 Assembler, C, C++, VB, VB.NET, ASP, PHP, HTML, UNIX and SQL
Unread 07-02-2008, 06:50
tdlrali tdlrali is offline
FRC #0469 (Las Guerrillas)
tdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud of
If dynamic breaking was on, and you pushed hard enough, that might have been the cause.
Unread 07-02-2008, 07:31
rees2001 rees2001 is offline
AKA: Rees
FRC #0340 (Greater Rochester Robotics)
rees2001 has a reputation beyond reputerees2001 has a reputation beyond reputerees2001 has a reputation beyond reputerees2001 has a reputation beyond reputerees2001 has a reputation beyond reputerees2001 has a reputation beyond reputerees2001 has a reputation beyond reputerees2001 has a reputation beyond reputerees2001 has a reputation beyond reputerees2001 has a reputation beyond reputerees2001 has a reputation beyond repute
We had a speed controller blow like that last fall. We ran a demo over the summer at a local fairgrounds where we ran on the grass. After a full weekend of driving the grass had worn away & we were running on dirt. Needless to say everything on the robot was covered in dirt. We tried to blow everything out with some compressed air. I guess we didn't clean out the speed controllers well enough. We then were showing the robot at our school open house in the fall & POP & spin happened. We hit the disable switch but the same thing happened, it just kept going. After we took the speed controller apart we discovered that it was still filled with dirt & had over heated.
Unread 07-02-2008, 12:28
I had a Victor fail that way on our 2005 robot the day it went into the crate.
I had just opened the robotics room and had just powered up the system to check on work the kids had finished late the night before (okay, a couple of hours earlier).
It controlled a telescoping arm, so POP and the arm began extending on it's own.
Hit the Kill switch..it kept going.
Pulled the tether...it kept going.
Pulled the battery connection just in case the main breaker decided to fail on me too.
Unread 07-02-2008, 12:34
D_Price's Avatar
D_Price D_Price is offline
Engineer/Mentor
AKA: Derek
FRC #1708 (Amp'd Robotics (formally Natural Selection))
D_Price has a brilliant futureD_Price has a brilliant futureD_Price has a brilliant futureD_Price has a brilliant futureD_Price has a brilliant futureD_Price has a brilliant futureD_Price has a brilliant futureD_Price has a brilliant futureD_Price has a brilliant futureD_Price has a brilliant futureD_Price has a brilliant future
That really is not good at all.. We ran the electronics board through a series of tests to make sure the victors and main boards are working.
Compile failure darkChozo Programming 8 06-02-2008 20:49
Victor failure question--Can power from motors cause them? Kit Gerhart Electrical 6 13-12-2007 17:56
motor failure redbarron Electrical 5 22-02-2006 10:52
Robot Test - Failure Fixen Rumor Mill 34 07-02-2005 23:20
Victor 884's not behaving the same as Victor 883's programmer1 Programming 13 10-03-2004 21:51
