Go to Post There MUST BE room for mistakes. That’s one of the best ways to learn. - Ken Leung [more]
Unread 25-01-2008, 17:18
Neil [Coconuts] Neil [Coconuts] is offline
FRC #2486
Neil [Coconuts] is an unknown quantity at this point
Exclamation An Issue with downloading the Master Code.
My team and I seem to be having an issue with updating the master code on the "brain." When we try to download the program, we get an error message stating that we should check our connection and make sure that the programming state light is orange (which it was). Regarding the connection: when we try to download a program that we wrote ourselves, it downloads just fine. It just doesn't work.
We've already tried calling Intelitik's support line, but all we got was an answering machine.
Any input would be appreciated.
Thanks in advance.
Unread 27-01-2008, 17:53
FRC #2486
Re: An Issue with downloading the Master Code.
We're also unable to download the online window code.
Unread 28-01-2008, 16:32
Kingofl337's Avatar
You didn't see anything....
AKA: Adam
FRC #0501 (Power Knights)
What are using for a programming cable? Is it a real RS-232 or USB?
Unread 28-01-2008, 21:23
BornaE's Avatar
BornaE BornaE is offline
FRC #0842 (Formerly 39)
BornaE has a brilliant futureBornaE has a brilliant futureBornaE has a brilliant futureBornaE has a brilliant futureBornaE has a brilliant futureBornaE has a brilliant futureBornaE has a brilliant futureBornaE has a brilliant futureBornaE has a brilliant futureBornaE has a brilliant futureBornaE has a brilliant future
usb, but i can use it fo dashboard, and i get the terminal info, but can't program
-Borna Emami
Team 0x27
Unread 29-01-2008, 09:31
Kingofl337's Avatar
AKA: Adam
Do you have access to either the Vex USB to Serial Cable or a Real Serial Port.
Are you able to get the IFI Loader to work? Have you checked loader setup
to check the correct serial port? PM me a phone number and I can give you a
call.
Unread 07-02-2008, 12:43
erikstotle's Avatar
erikstotle erikstotle is offline
Quendi
AKA: Erik
FRC #0107
erikstotle is an unknown quantity at this point
Send a message via MSN to erikstotle
I'm having the same exact problem, except that absolutely nothing downloads. I'm using a real rs-232 cable, and I've tried several of them, even a new one. It is using the correct com port, as the code downloads without a hitch on the 2007 rc. Any help would be greatly appreciated.
Unread 07-02-2008, 14:03
Kingofl337's Avatar
AKA: Adam
If you can download code to your 2007 RC and the 2008 RC won't accept code call IFI has you may have a defective controller.
Interrupt issue with new code EHaskins Programming 6 05-01-2008 00:27
Issue with downloading code to the 2007 RC thefro526 Programming 3 10-02-2007 17:26
Problems with Updating VEX Controller Master Code tinderfitles VEX 3 20-11-2006 17:16
Downloading Code with new Editor gburlison Programming 4 17-01-2003 01:10
