Go to Post To me, as a student, it doesn't really matter how old the RoboCoach is. My only concern is that they don't get ape-crazy when the game starts. - AZNkommander [more]
Unread 07-02-2008, 14:16
Doug Leppard's Avatar
Doug Leppard Doug Leppard is offline
FRC #1902 (Exploding Bacon)
Doug Leppard has a reputation beyond reputeDoug Leppard has a reputation beyond reputeDoug Leppard has a reputation beyond reputeDoug Leppard has a reputation beyond reputeDoug Leppard has a reputation beyond reputeDoug Leppard has a reputation beyond reputeDoug Leppard has a reputation beyond reputeDoug Leppard has a reputation beyond reputeDoug Leppard has a reputation beyond reputeDoug Leppard has a reputation beyond reputeDoug Leppard has a reputation beyond repute
Send a message via AIM to Doug Leppard
Re: PID Troubleshooting
We use PD of PID for the turn. We might add I later but it turns well now.
We use wheel encoders.
P = (left wheel count)*turnratio - right wheel encoder count
Turnratio = the ratio of the radius of the inside and outside turns. Smaller the ratio the larger the turns.
Then practice doing that with just P before you do move onto ID.
BTW to know when a turn is done, if you subtract one wheel count from the other it will give you the difference and that will give you the number of degrees no matter how large or small the turn is. For instance an 180 turn on our bot is about 600 encoder clicks diference between wheels or about 3.3 clicks per degree difference.
Doug Leppard
Operator Interface Troubleshooting DavidGitz Control System 7 13-11-2007 14:02
Firefox troubleshooting. Madison IT / Communications 11 17-09-2006 01:28
PID Troubleshooting Disar Programming 4 13-09-2006 15:27
Troubleshooting - 783 lee87 Website Design/Showcase 2 13-02-2005 20:15
Troubleshooting System SilverStar Technical Discussion 0 23-01-2004 21:22
