Go to Post Just that the robot battery wont catch fire if you drop it the wrong way. Those LiPos pack quite a punch. - dellagd [more]
Unread 07-02-2008, 14:31
de_ de_ is offline
AKA: Dave Edwards
FRC #1310 (Runnymede Robotics)
de_ is a jewel in the roughde_ is a jewel in the roughde_ is a jewel in the roughde_ is a jewel in the rough
IR Sensor: Does Slow Loop Polling Work.
The IR specs say the IR sensor outputs 100MS pulses. The RC slow loop is ~26ms (unless your code takes longer than 26ms!) which means you should easily be able to catch IR sensor outputs without interrupts. Our quick test a few weeks ago did not catch IR outputs though maybe we did something wrong.
Anyone successfully using standard slow loop polling (ie NOT non-interrupt driven, NOT high speed CPU timer based polling) successfully with the IR Sensor ?
If doesn't work, do we know why not ? Has anyone actually measured the pulse width ?
Unread 07-02-2008, 14:50
Re: IR Sensor: Does Slow Loop Polling Work.
I've done it without problems. You get 3 to 4 hits.
I've got some FRC example code here that does everything in Default_Routine().
Unread 07-02-2008, 23:49
JonathanLKS JonathanLKS is offline
Code::Blocks
FRC #0610 (The Coyotes)
JonathanLKS will become famous soon enough
Send a message via MSN to JonathanLKS
I've also gotten the IR sensor to work fine in the slow loop. All I did was just a simple if statement like this
if(rc_dig_in01 == 1)
button_pressed = 1;
Team 610 [ Co-Leader | Head Programmer | Webmaster ]
We're attending: Greater Toronto Regional, San Diego Regional, Championship
How does it work? Ryan O Control System 5 12-03-2006 19:15
Does easy c work in nt? Bob22341 Programming 2 12-01-2006 22:11
How slow is too slow? Joe Ross Rules/Strategy 23 12-10-2004 20:23
How do light sensor(Banner) work? roberthan Programming 9 25-02-2004 14:05
sensor doesn't work PBoss Programming 7 29-01-2003 18:39
