Go to Post FIRST is good for us. It is good for our own Children. Don't give up, even if you are as tired as I am! - Kyle Hughes [more]
Unread 05-02-2008, 19:37
bronxbomber92 bronxbomber92 is offline
FRC #1551 (Grapes of Wrath)
bronxbomber92 is an unknown quantity at this point
Pointer to pwm
I just wanted to make sure this was safe to do.
typedef struct
     // stuff
     unsigned char* pwm;
} Motor;
void InitMotor( Motor* motor, unsigned char* pwm, /* more parameters */ )
     // stuff
     motor->pwm = pwm;
then if I want to change the motor speed
Motor myMotor; InitMotor( myMoter, pwm10 );
myMotor.pwm = 127; // set it to nuetral
Is that all right to do? I assume it is, but just want to make sure.
Thanks
Unread 05-02-2008, 19:56
dcbrown dcbrown is offline
AKA: Bud
dcbrown has much to be proud ofdcbrown has much to be proud ofdcbrown has much to be proud ofdcbrown has much to be proud ofdcbrown has much to be proud ofdcbrown has much to be proud ofdcbrown has much to be proud ofdcbrown has much to be proud ofdcbrown has much to be proud ofdcbrown has much to be proud of
Re: Pointer to pwm
typedef struct
     // stuff
     unsigned char* pwm;
} Motor;
     // stuff
     motor->pwm = pwm;
Motor myMotor; InitMotor( &myMotor, &pwm10 );
*myMotor.pwm = 127; // set it to nuetral
need * to dereference the pointer and & to pass a pointer in the places shown
Unread 05-02-2008, 20:03
Re: Pointer to pwm
Nope, you're right!
Thanks
Unread 05-02-2008, 23:36
Jon Stratis's Avatar
Mentor, LRI, MN RPC
FRC #2177 (The Robettes)
Re: Pointer to pwm
that seems like an OK way to do it... what might end up being easier, though, is to just do something like:
#define leftMotor pwm01
#define rightMotor pwm02
then you can use your left and right motors wherever you want, and if someone plugs something in backwards and doesn't want to unplug it you just have to change it in the one location in the header file. Just another option to consider!
Unread 06-02-2008, 00:24
JohnC's Avatar
JohnC JohnC is offline
my other name is nigel
FRC #0360 (360 Revolution)
JohnC is a jewel in the roughJohnC is a jewel in the roughJohnC is a jewel in the roughJohnC is a jewel in the rough
Send a message via AIM to JohnC
Re: Pointer to pwm
We use Left(int) and Right(int)
void Left(int speed) {
  pwm01 = speed;
  if(pwm01 > 254) {
    pwm01 = 254;
  } else if(pwm01 < 1) {
    pwm01 = 1;
And the right one assigns 254-speed. Just yet another form of abstraction
What place are we at? ... TODAI!
Unread 07-02-2008, 15:57
Re: Pointer to pwm
That's what I have currently, and I've debating if I should use a more OO approach, which I'm still not sure of. Just brain storming
Suspicious pointer conversion ebowla Programming 2 26-01-2008 12:13
laser pointer 1574aviad Technical Discussion 9 20-02-2005 20:25
pwm 13-15 wayne 05 Programming 2 04-10-2003 12:08
PWM Antonio Technical Discussion 21 06-01-2003 14:44
Pwm VanWEric Programming 17 01-11-2002 16:07
