Go to Post I personally think that everybody on the team is important. No matter what, every single student, mentor, teacher put their effort all year long to get the team going. So in my opinion, Credit goes to everyone. - Arefin Bari [more]
Unread 06-02-2008, 14:33
Kims Robot's Avatar Unsung FIRST Hero
Kims Robot Kims Robot is offline
Onto a New Chapter...
AKA: Kim O'Toole Eckhardt
Kims Robot has a reputation beyond reputeKims Robot has a reputation beyond reputeKims Robot has a reputation beyond reputeKims Robot has a reputation beyond reputeKims Robot has a reputation beyond reputeKims Robot has a reputation beyond reputeKims Robot has a reputation beyond reputeKims Robot has a reputation beyond reputeKims Robot has a reputation beyond reputeKims Robot has a reputation beyond reputeKims Robot has a reputation beyond repute
Send a message via AIM to Kims Robot
Bending Aluminum Tubing?
Manufacturing Question...
We are trying to figure out a way to give a curved bend to some 1/16" wall 1" diameter aluminum tubing.
Anyone know any good ways to do this??
Thanks!
~kim~
Kimberly O'Toole Eckhardt <3
Principal Systems Engineer & Program Manager
History - Team 176, Team 229, Team 1511, FIRST Volunteer!!
My new FIRST Photography Hobby & Angry Eric's Fan Page
Excellence - is the result of caring more than others think is wise, risking more than others think is safe, dreaming more than others think is practical, and expecting more than others think is possible.
Unread 06-02-2008, 14:38
Rob Rob is offline
AKA: Rob
FRC #0131 (CHAOS)
Rob has a reputation beyond reputeRob has a reputation beyond reputeRob has a reputation beyond reputeRob has a reputation beyond reputeRob has a reputation beyond reputeRob has a reputation beyond reputeRob has a reputation beyond reputeRob has a reputation beyond reputeRob has a reputation beyond reputeRob has a reputation beyond reputeRob has a reputation beyond repute
Send a message via AIM to Rob
Re: Bending Aluminum Tubing?
Hi Kim,
We typically have used a tubing bender in the past that has a die for the size of tube being bent and the desired radius. You can usually find these at local shops, even automotive shops (although they might not have dies for 1" tube).
If you are feeling adventurous you can get a conduit bender from the hardware store and do it by hand.
Due to the fact that we lost much of our round tube bending capabilities between last season and this one, we have had to be a bit more experimental this year. We used a conduit bender on round tube for out prototype, and could have done this for our final parts taking alot of time and caution to get it right. We ended up rolling square tube through a sheet metal roller to get the desired radius, but that only works for very large diameters (Like 40" or so...)
Good luck,
RAZ
Unread 06-02-2008, 14:52
dlavery's Avatar
dlavery dlavery is offline
Curmudgeon
FRC #0116 (Epsilon Delta)
With walls that thin, you will probably also need to reinforce the tubing during the bending process (particularly if you are going to be using a hand bender). The most common way of doing this is to fill the tube with incompressible material to fill the voids. This will prevent the tube from collapsing during the bending process. There are many materials that are suitable for this. The ones most commonly used include low-melting-temperature alloys, sand or even water (if you can completely seal the tube). You can also find special springs that are used to provide the same function (insert them into the tube to the location of the bend, where they support the tubing walls during the bending process).
-dave
Unread 06-02-2008, 17:21
JesseK's Avatar
JesseK JesseK is offline
Expert Flybot Crasher
FRC #1885 (ILITE)
This isn't a suggestion, this is simply how we did it. In hindsight, we probably should have asked for better techniques to aid us in perfection. We decided to bend things for prototyping on the spot, and it worked out so well that we've used the same techniques to do the final product.
For this year, we've bent 3 radii: 20", 13", and 3.5" and none with any typical bending equipment. For the 40" bend we used 1" square tubing, and even though the final product isn't perfect it still works well since it's a low-load/stress piece.
First, we used a 2" sheet of wood at least 40" x 20", a bunch of clamps, and some muscle. Using a pencil/marker tied to one end of a string, we measured out 20" to create a radius. We put the 20" mark of the string down on a point of our 2" sheet and marked out our semi-circle. We used a bandsaw to cut out the semi-circle.
What you do from here depends on whether or not you have a blow torch. The torch is used to heat the metal while it's bent in order to let it settle to its new shape when quenched (cooled). This keeps it from springing out back to a greater radius when the clamps are removed. If you do not have a blow torch, you'll need some extra clamps & time and also to cut another ~38" semi circle from inside your 40" one. You will clamp the metal to the wood to create your bend and let it sit clamped long enough to settle.
We then clamped a scrap piece of wood directly to the right of the semi-circle, about 1 1/4" from it. This gave us something to leverage off of as we bent the tubing around the wood template. We bent the metal around the wood template, gently clamped everything in place, and used the blow torch to heat the metal as evenly as we could. We then used wet cloths to cool the metal, then threw it out in the snow for a few minutes to completely cool it. Now it's as rigid as if we had welded it.
Make sure you have one person designated with a fire extinguisher and that everyone has gloves/eyewear. It took 6 students and 1 mentor about 45 minutes to fully bend three 20" radii pieces.
GitHub
Unread 06-02-2008, 19:51
meaubry meaubry is online now
volunteer helper
FRC #6099 (Knights)
meaubry has a reputation beyond reputemeaubry has a reputation beyond reputemeaubry has a reputation beyond reputemeaubry has a reputation beyond reputemeaubry has a reputation beyond reputemeaubry has a reputation beyond reputemeaubry has a reputation beyond reputemeaubry has a reputation beyond reputemeaubry has a reputation beyond reputemeaubry has a reputation beyond reputemeaubry has a reputation beyond repute
Kim,
Funny you should ask. We are using the same material and I have successfully been able to use the technique that Dave suggested. Taped one end shut, filled with sand, tape the other end, and used a conduit bender.
Just remember to go slow, and keep the bends small - I tried staying under 22 degrees. Do not over bend them as you don't want to straighten them after bending.
Make a template to check against as you bend.
Using that technique, I was able to create bends that pretty closely follow the contour of the ball. I used something like 7 or 8 inch spacing between the bends.
The hard part was trying to keep the sequence of bends for the ones that had multiple directions.
All in all, we are happy with the way they came out.
Mike
Unread 06-02-2008, 20:43
Shivang1923 Shivang1923 is offline
I make robot go VROOM VROOM!
FRC #1923 (MidKnight Inventors)
Shivang1923 has a spectacular aura aboutShivang1923 has a spectacular aura about
If you don't have the materials for that way, you could always use all purpose steel from mcmaster carr. Our claw type thing only weighs 16 pounds, which is really a lot less than you'd think because the claw is made up of about 18 ft of steel.
We have contacts at TCNJ and they said that aluminum folds if it isn't bended properly (wont be a problem if you go with dave's idea), but if you're going to use it in a place where it will probably get hit a lot, the aluminum will get damaged. Also, it is expensive to buy an aluminum welder, so if you need to weld, you will be in for a huge problem. (Again, iff you can find one, then go ahead use aluminum, or if you don't NEED to weld, and you can bend it properly, go for it).
Just my thoughts and my experience.
Unread 07-02-2008, 01:19
Laxphan1525's Avatar
Laxphan1525 Laxphan1525 is offline
AKA: Harrison
FRC #1525 (Warbots)
Laxphan1525 is an unknown quantity at this point
this isnt a real pretty way but if your good at machining you can cut a slot using a mill at the "correct" angle then bend it by hand and weld the joint to restore rigidity. However if you dont have a mill i have in the past cut a slot using an angle grinder and then welded the joint after. Again neither are that pretty but i have done both in the past and it works. It all depends on what angle you need and how accurate you need to be. Obviously they sell cnc benders and several large companies with access to these benders but most people dont have access to this type of equiupment. like people have said before tube benders work extremely well with aluminum and are an excellent tool for such a process.
Unread 07-02-2008, 09:05
Dad1279 Dad1279 is offline
FRC #1279 (Cold Fusion)
For the nicest bends, try an canvas awning manufacturer (commercial or nautical) or a race shop that build roll cages. They both will have a 1" die. We have bent tubing with the benders that electricians use, like sold at home depot. If you use the electrical bender, consider using steel electrical conduit for a nicer bend. It is fairly strong, thin wall, inexpensive and not too heavy.
Unread 07-02-2008, 15:27
colin340 colin340 is offline
human
AKA: Colin Nobles
FRC #0148
colin340 has a reputation beyond reputecolin340 has a reputation beyond reputecolin340 has a reputation beyond reputecolin340 has a reputation beyond reputecolin340 has a reputation beyond reputecolin340 has a reputation beyond reputecolin340 has a reputation beyond reputecolin340 has a reputation beyond reputecolin340 has a reputation beyond reputecolin340 has a reputation beyond reputecolin340 has a reputation beyond repute
Send a message via AIM to colin340
hey kim try freezing it full of ice then bending it that how they bend trumpet parts
61 77 77 20 77 69 74 74 6c 65 20 62 61 62 79 20 63 6f 6e 64 6f 72 20 69 73 20 72 65 61 64 69 6e 67 20 43 44
Unread 07-02-2008, 16:02
Rob Rob is offline
AKA: Rob
FRC #0131 (CHAOS)
Just as an FYI, we have been using bent tubing of various sizes and various bend radii for years, and have never had to heat, cool, or fill it with anything to get good results. The only time you will run into issues is with large tube and tight radii. We have had great success with 1" tubing bent to a radius as small as 3".
The suggestion to find a nautical shop or a race shop that makes roll cages is exactly what you need. The guy who does this for us used to work in a nautical shop, and learned the skills by making roll cages.
You should be ably to use a conduit bender to do what you need providing that you can find one able to accommodate a 1" tube. Using the conduit itself is also a valid option, it is not nearly as heavy as you might expect and makes a god sub for aluminum.
Good luck,
RAZ
Unread 07-02-2008, 21:08
slocynerd's Avatar
slocynerd slocynerd is offline
Slocs
AKA: Sunshine
FRC #1517 (The lumberjacks)
slocynerd is an unknown quantity at this point
Thanks!
use a vice, not the hand ones, one with a crank and just use leverage to your advantage
"The wise speak only of what they know."
"If more of us valued food and cheer and song above hoarded gold, it would be a merrier world." -J.R.R. Tolkien
Unread 08-02-2008, 03:53
Kirk Kirk is offline
FRC #0254
Kirk has much to be proud ofKirk has much to be proud ofKirk has much to be proud ofKirk has much to be proud ofKirk has much to be proud ofKirk has much to be proud ofKirk has much to be proud ofKirk has much to be proud ofKirk has much to be proud of
Send a message via AIM to Kirk
I am not sure if you mentioned whether you are using round or square but go around to shop and ask if they have a "Ring Roller" like this http://www.vansantent.com/bending_machine_z402.htm . Call around and ask if someone has one that can bend the tube for you. If you are using square tube you can also use a large sheet metal roll but it will make the tube a little oval. I have seen both used to bend .062 wall aluminum tube.
Buying Aluminum rectangular tubing AdamHeard Technical Discussion 6 10-01-2007 19:41
Bending 2" diameter pipe/tubing sanddrag Technical Discussion 12 11-05-2006 21:55
[OCCRA]: 2" aluminum square tubing.. mostunsuspected OCCRA 5 13-09-2004 19:08
Aluminum Tubing archiver 2000 2 23-06-2002 22:35
does small parts sell rectangular aluminum tubing mnkysp6353 General Forum 2 09-12-2001 01:28
