Go to Post Whatever you do though, don't get into an "us versus them" mentality with your mentors. They are there to help. - Bongle [more]
Unread 07-02-2008, 17:38
Kevin Watson's Avatar
La Caņada High School
FRC #2429
Re: How many interrupts is too many interrupts?
Originally Posted by dcbrown View Post
Quad encoders represent 1 interrupt, the phase b line is polled during the interrupt caused by a phase a transition. The phase b is used to determine direction but shouldn't be tied to another interrupt line.
This is the case with interrupts 1 and 2, but 3 through 6 generate two interrupts per quadrature cycle.
-Kevin
Kevin Watson
http://kevin.org
Unread 08-02-2008, 12:09
dcbrown dcbrown is offline
AKA: Bud
dcbrown has much to be proud ofdcbrown has much to be proud ofdcbrown has much to be proud ofdcbrown has much to be proud ofdcbrown has much to be proud ofdcbrown has much to be proud ofdcbrown has much to be proud ofdcbrown has much to be proud ofdcbrown has much to be proud ofdcbrown has much to be proud of
-Kevin
True. I forgot that PORTB<4:7> aren't edge triggered, just change triggered.
This thread is rapidly disappearing into the tech rat-hole that the original posted requested it not. So backing up a couple levels. I've run IFI default code with ~8500 interrupts/sec without any issue. The code should be able to handle upwards of 20,000 interrupts/sec based upon the typical interrupt handlers I've seen. But...
There are tech gotchas that start coming into play above 10,000 interrupts per second with the standard IFI robot code framework. But those are best left for another thread. Maybe we should start a separate tech thread on the subject.
Too many R/C commands in a loop? ManicMechanic VEX 1 02-07-2007 00:52
3 Teams Per Side Too Many? ben281 FRC Game Design 65 15-05-2005 18:24
pic: TOO MANY TETRAS!!!! Ali Ahmed Extra Discussion 12 22-01-2005 10:06
