Go to Post If this thread isn't a sign that CD is going through some serious withdrawals, I don't know what is. - Ty Tremblay [more]
Unread 07-02-2008, 18:44
Sqwigy Sqwigy is offline
AKA: Erik
FRC #1591 (Greece Gladiators)
Sqwigy is an unknown quantity at this point
Inspection question
I was wondering if anyone knew if, while during inspection can we have a piston actuated so that we can keep our claw closed? Or could we use a piece of rubber or something to tie it with? basically what do we have to do?
Unread 07-02-2008, 18:48
jgannon's Avatar
jgannon jgannon is offline
I ᐸ3 Robots
AKA: Joey Gannon
jgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond repute
Re: Inspection question
If you're talking about the sizing part of inspection, then you need to do whatever you'll be doing to make your bot fit within the sizing envelope at the start of each match. Tying down your claw is probably not an option.
Team 1743 - The Short Circuits
2010 Pittsburgh Excellence in Design & Team Spirit Awards
2009 Pittsburgh Regional Champions (thanks to 222 and 1218)
2007 Pittsburgh Website Award
2006 Pittsburgh Regional Champions (thanks to 395 and 1038)
2006 Pittsburgh Rookie Inspiration & Highest Rookie Seed
Team 1388 - Eagle Robotics
2005 Sacramento Engineering Inspiration
2004 Curie Division Champions (thanks to 1038 and 175)
2004 Sacramento Rookie All-Star
_
Unread 07-02-2008, 19:25
Liz Smith's Avatar
Liz Smith Liz Smith is offline
believes in robots
AKA: Pika1579
FRC #3940
Liz Smith has a reputation beyond reputeLiz Smith has a reputation beyond reputeLiz Smith has a reputation beyond reputeLiz Smith has a reputation beyond reputeLiz Smith has a reputation beyond reputeLiz Smith has a reputation beyond reputeLiz Smith has a reputation beyond reputeLiz Smith has a reputation beyond reputeLiz Smith has a reputation beyond reputeLiz Smith has a reputation beyond reputeLiz Smith has a reputation beyond repute
Send a message via AIM to Liz Smith
Right. The most important thing is that you have to fit in the sizing box during inspection as well as at the start of each match. Whatever solution taken for inspection must also be used at the beginning of each match.
Alumna of 555 Mentor of 3940
Volunteering since 2004: Say hi to me at events!
Applications Engineer
AndyMark, Inc.
Unread 07-02-2008, 19:29
AKA: Erik
Well when our robot is on it fits within the size constraints, but when it's off it does not.
Unread 07-02-2008, 19:52
jgannon's Avatar
I ᐸ3 Robots
AKA: Joey Gannon
When you put your robot on the field, it will initially be disabled, which means no power to Spikes or Victors. If your robot does not fit into the starting envelope in this state, you will not be permitted to compete.
_
Unread 07-02-2008, 19:59
seanl's Avatar
seanl seanl is offline
"The Everything person"
FRC #0867 (Absolute Value)
seanl will become famous soon enoughseanl will become famous soon enough
but since its a pneumatic were talking about cant you have the tanks filled to have the piston pulled in or out to meet the size constrains.
, Sean
TEAM 867
-electrical
-pneumatics
-programming
2008 Autodesk Visualization Grand Prize Winner
Unread 07-02-2008, 20:40
ay2b's Avatar
ay2b ay2b is offline
AKA: Andy
FRC #2928
Rookie Year: 1994
ay2b has a brilliant futureay2b has a brilliant futureay2b has a brilliant futureay2b has a brilliant futureay2b has a brilliant futureay2b has a brilliant futureay2b has a brilliant futureay2b has a brilliant futureay2b has a brilliant futureay2b has a brilliant futureay2b has a brilliant future
Yes, you can have your pneumatic system charged at the beginning of the match. In fact, it's generally recommended that you do so; otherwise you'll be spending the first 15-30 seconds of the match charging up.
2011 - SD Quarterfinalists (980), LA Quarterfinalists (980)
2010 - LA (2404) Finalists (980), AZ Motorola Quality (980)
2009 - LA Semifinalists (980); Las Vegas Quarterfinalists (980); SD (2404); IRI #1 Seed, Finalist (980)
2008 - SD Quarterfinalists (980), LA Champions (980), LA Rookie Inspiration Award (2404); CalGames Finalists
2007 - So.Cal Finalists (980), SD Quarterfinalists (980); CalGames Finalists
2006 - So.Cal Regional Champion (4), Toronto Judge's Award Day 1 (4)
2005 - SVR Champions, Delphi "Driving Tomorrow's Technology" (980); AZ Xerox Creativity (980); So.Cal Finalists, RadioShack Innovation in Control (980); Championship Archimedes Division Semifinalists; IRI Finalists (980)
2004 - So.Cal Regional Champions, Leadership in Controls (980); AZ GM Industrial Design (980); Championship Galileo Division #2 Seed; IRI Champions
2003 - PNW Semi-finalists (488)
2002 - PNW Finalists (488)
2000 - X-bot / 488 - Mentor / Founder
1994 - Sunny Delight - Driver - champion
Unread 07-02-2008, 18:49
seanl's Avatar
actually this was the case with our bot last year. the inspector let us just hold the piston with out hands while they put it into the sizing box. im not sure if they let you have the bot on because we havent tried that.
, Sean
TEAM 867
-electrical
-pneumatics
-programming
Unread 07-02-2008, 20:06
D_Price's Avatar
D_Price D_Price is offline
Engineer/Mentor
AKA: Derek
FRC #1708 (Amp'd Robotics (formally Natural Selection))
D_Price has much to be proud ofD_Price has much to be proud ofD_Price has much to be proud ofD_Price has much to be proud ofD_Price has much to be proud ofD_Price has much to be proud ofD_Price has much to be proud ofD_Price has much to be proud ofD_Price has much to be proud of
I think it would be better to actually tie the piston down instead of initiating the actuator.
Unread 07-02-2008, 20:07
in between teams
AKA: Luke Van Oort
Why?
Team 1219: 2009 - Mentor
Unread 07-02-2008, 21:02
comphappy comphappy is offline
AKA: Brennan Ashton
FRC #2605 (A2D_16)
comphappy is a splendid one to beholdcomphappy is a splendid one to beholdcomphappy is a splendid one to beholdcomphappy is a splendid one to beholdcomphappy is a splendid one to beholdcomphappy is a splendid one to beholdcomphappy is a splendid one to behold
Send a message via AIM to comphappy
<R11>
Any restraints (elastic bands, springs, etc.) that are used to restrain the ROBOT in its STARTING CONFIGURATION must remain attached to the ROBOT for the duration of the MATCH.
</R11>
So i would say it has to be held in that position by itself, as I understand it you can charge the cylinders and then activate the piston to raise it. For inspection i bet you could just push it up an tighten the valves.
A2D Solving the Imaginary Error Function...
Unread 07-02-2008, 21:11
AKA: Erik
Well we have the means to keep it closed. we just needed to know what we would do for inspection. Thanks guys!
Unread 08-02-2008, 02:00
dtengineering's Avatar
AKA: Jason Brett
If you use a double-acting solenoid valve you can put the cylinder into position and have it remain in position even when the spikes and victors are disabled.
If you use a single acting valve then it will depend on how you have it hooked up.
Either way, it shouldn't be a big problem for you.
Jason
[OCCRA]: Inspection Mike Martus OCCRA Q&A 0 13-10-2006 14:56
Inspection Guide Noah Melamed General Forum 2 09-02-2006 09:34
Inspection willross General Forum 4 25-02-2004 18:28
Inspection Sheet Mike Norton Rules/Strategy 3 12-02-2003 15:55
Inspection Mike Martus OCCRA 0 29-10-2001 21:45
