Go to Post There's "FIRST the organization" and then there's "FIRST the vision for the future through a set of ideals". I've grown somewhat skeptical of the former in recent years, but, after 10 years, I'd still throw myself in front of a bus for the latter. - Rich Kressly [more]
Unread 07-02-2008, 10:54
LaurenH's Avatar
LaurenH LaurenH is offline
FRC #2404 (TNT)
LaurenH is on a distinguished road
Send a message via AIM to LaurenH
pic: Team 2404 (TNT) Omni Drive System
Unread 07-02-2008, 10:59
T3_1565 T3_1565 is offline
AKA: Twitch Drive Designer
FRC #1360
T3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant future
Send a message via MSN to T3_1565
Re: pic: Team 2404 (TNT) Omni Drive System
Thats a pretty crazy design!!! Any reason why you didn't do a standard omni system?? It seems like you strafing abilities are going to be much slower than your foreward and backward. And it also seems to cost alot more than a standard omni drive system.
What made you decide this?? It is very neat!!
Unread 07-02-2008, 12:25
diesel's Avatar
diesel diesel is offline
FRC #2077
diesel has a spectacular aura aboutdiesel has a spectacular aura about
I can see why you built the omni drive this way.
Most of the game is driving forward, not much 'straffing' has to be done.
The four wheels in the regular position will help more than just two driving forward.
My concern, which you probably thought about.
-If you are on the bump a 'straffing' wheel might not be on the ground, and the robot would just spin.
Are there little 'shocks' on the wheels??
Design. Build. Dew.
Unread 07-02-2008, 13:10
jax1488's Avatar
jax1488 jax1488 is offline
The Northern Chicken Wizards
AKA: jack stone
FRC #0522 (Robo Wizards)
jax1488 is a name known to alljax1488 is a name known to alljax1488 is a name known to alljax1488 is a name known to alljax1488 is a name known to alljax1488 is a name known to all
Send a message via AIM to jax1488 Send a message via MSN to jax1488 Send a message via Yahoo to jax1488
chain tension?
"i dont like it, but i cant tell u why!" -"Dearrin"
2006 "aim high" national championship champions. (ty 296 and 217, NOTHERN CHICKEN WIZARDS... UNITE!)
2006 Greater Toronto Regional Chairman's Award
2004 N.Y.C. Regional Champion
2004 N.Y.C. GM Industrial Design
2004 N.Y.C. Daimler Chrysler Team Spirit
2003 N.Y.C. Regional Champion
Unread 07-02-2008, 15:03
GaryVoshol's Avatar
Cogito ergo arbitro
Wheels aside, I presume the C-channel things sticking up on all 4 sides are for bumper attachments? You would have a bolt of some form that comes out of the bumper and fits the slot on the channel, and then is tightened down.
My question is if you've checked the size of the frame. The channel adds a bit of width I think (can't tell for sure, but it looks wider than the end pieces of the kit frame). Beside that, there are bolt heads sticking out. A kit frame doesn't give you much leeway with the 28 inches - 3/8 or 5/8" as I recall. Check if you'll still fit in the box.
(since 2004)
Unread 07-02-2008, 15:22
Jim Meyer's Avatar
Jim Meyer Jim Meyer is offline
Engineering Mentor
None #0067 (HOT)
Jim Meyer has a reputation beyond reputeJim Meyer has a reputation beyond reputeJim Meyer has a reputation beyond reputeJim Meyer has a reputation beyond reputeJim Meyer has a reputation beyond reputeJim Meyer has a reputation beyond reputeJim Meyer has a reputation beyond reputeJim Meyer has a reputation beyond reputeJim Meyer has a reputation beyond reputeJim Meyer has a reputation beyond reputeJim Meyer has a reputation beyond repute
We talked pretty extensively about a drive system just like this for this year. In the end we chose a different direction, but I'm anxious to see how it works for you.
T3, what do you mean by a "standard" omni system? Are you referring to the holomonics?
Unread 07-02-2008, 15:42
vivek16's Avatar
vivek16 vivek16 is offline
Whoa! college pilot.
AKA: vivek
FRC #2264 (trojan robotics)
vivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond repute
Send a message via AIM to vivek16 Send a message via MSN to vivek16
Wow, this was almost exactly our setup! Will you be coming to the Minneapolis regional? We have the same omni wheel setup. But, each side is powered by a CIM motor in our design.
Hoping to see more, Vivek
"we don't build robots, we build people"
Unread 07-02-2008, 16:25
LaurenH's Avatar
FRC #2404 (TNT)
Last night after its first test run, we talked about adding shocks to the 5th and 6th wheel. Do you have any suggestions for shocks? Is there anything to watch out for?
Currently, we know that the four standard wheels (forward/backward driving) work excellent, so if the 5th and 6th wheels need to be remove it would not cause a functional problem. These wheels are for strafing which we would like to have for strategy and alignment purposes. In all truth we should have used mecanum drive system, but either one of these drive systems will achieve basically the same thing.
jax1488 - I’m not sure what kind of question you have about chain tension. The gearboxes are slotted and use to tight one chain, while we use a free spinning sprocket (as seen to the left of the gearbox) to tension the other chain.
GaryVoshol - Yes, the C-channel is for the bumper mounts and yes the bolts will be designed into the bumpers so that they will slide on and quickly tighten in place. We are approximately 26.5 x 36 inches as we cut our chassis for leeway.
As soon as we get the 5th and 6th wheel touching the ground properly, we’ll post a video (if anyone is interest I can also post a video of my other teams (FTC 25) 8 wheel omni drive system where one set of four wheels are used for speed while the second set was used for torque – it was amazing and work better than we ever taught it would).
vivek16 - I would love to see pictures. Currently we are only registered for the LA regional. Now that the teachers and students have been bit by the FIRST bug, everyone is hoping to earn a spot in Atlanta.
Thanks for all the comments.
Unread 07-02-2008, 19:14
ay2b's Avatar
ay2b ay2b is offline
AKA: Andy
FRC #2928
Rookie Year: 1994
ay2b has a brilliant futureay2b has a brilliant futureay2b has a brilliant futureay2b has a brilliant futureay2b has a brilliant futureay2b has a brilliant futureay2b has a brilliant futureay2b has a brilliant futureay2b has a brilliant futureay2b has a brilliant futureay2b has a brilliant future
Nice job! When do we get to see the videos?
2011 - SD Quarterfinalists (980), LA Quarterfinalists (980)
2010 - LA (2404) Finalists (980), AZ Motorola Quality (980)
2009 - LA Semifinalists (980); Las Vegas Quarterfinalists (980); SD (2404); IRI #1 Seed, Finalist (980)
2008 - SD Quarterfinalists (980), LA Champions (980), LA Rookie Inspiration Award (2404); CalGames Finalists
2007 - So.Cal Finalists (980), SD Quarterfinalists (980); CalGames Finalists
2006 - So.Cal Regional Champion (4), Toronto Judge's Award Day 1 (4)
2005 - SVR Champions, Delphi "Driving Tomorrow's Technology" (980); AZ Xerox Creativity (980); So.Cal Finalists, RadioShack Innovation in Control (980); Championship Archimedes Division Semifinalists; IRI Finalists (980)
2004 - So.Cal Regional Champions, Leadership in Controls (980); AZ GM Industrial Design (980); Championship Galileo Division #2 Seed; IRI Champions
2003 - PNW Semi-finalists (488)
2002 - PNW Finalists (488)
2000 - X-bot / 488 - Mentor / Founder
1994 - Sunny Delight - Driver - champion
Unread 07-02-2008, 20:16
FRC #1360
I definatly was referring to holonomic lol sorry for the confusion
Unread 07-02-2008, 21:56
team1203 4life's Avatar
team1203 4life team1203 4life is offline
President
FRC #1203 (Pandemonium)
team1203 4life is a jewel in the roughteam1203 4life is a jewel in the roughteam1203 4life is a jewel in the rough
Send a message via AIM to team1203 4life
that was intresting how you guys used t a set of wheels on the front and back good luck
if it is on one of my posts it is propbly spelt wrong
Why drive around somthing when you can drive through it
Unread 11-02-2008, 13:50
LaurenH's Avatar
FRC #2404 (TNT)
Any suggestions for adding shocks? How have you gone about it? Overall the drive system works, but a shock system would help quite a bit. We also bought 8" Mecanum wheels last night, just in case we feel like a new challenge.
Unread 11-02-2008, 17:22
LaurenH's Avatar
FRC #2404 (TNT)
Diagonal driving, strafing, and zero point turns:
http://www.youtube.com/watch?v=JqJK0E9Jpmk
Driving in an arch:
http://www.youtube.com/watch?v=b8jtsSxePME
First time driving the 6 wheel omni drive system (get an idea of the acceleration):
http://youtube.com/watch?v=pZf1-6wyOgA
Currently our best lap time was 13 seconds.
Prototype work:
Launch the ball over the overpass and lane divider:
http://youtube.com/watch?v=cUI9pu7VLD8&feature=related
Knocking the ball off the overpass:
http://youtube.com/watch?v=JsE634kwVSQ&feature=related
What drive system is your team using? dpick1055 Technical Discussion 22 27-01-2007 23:29
pic: One Omni wheel drive done falconmaster Extra Discussion 2 11-01-2007 19:26
pic: vex omni drive 1902_Battery_SGT FIRST Tech Challenge 6 28-05-2006 17:55
pic: Team 612 Drive System RoboMadi Robot Showcase 7 08-02-2006 16:38
pic: Omni Wheel Drive -- Top Richard Wallace Extra Discussion 4 05-12-2005 18:55
