Go to Post I would proudly put an AndyMark sticker on our robot any day! - Andy Grady [more]
Unread 20-01-2007, 12:25
arabsponsor arabsponsor is offline
AKA: Barbara Boyles
FRC #0538 (Dragonslayers)
arabsponsor will become famous soon enough
plug in for window motor
I searched to see if there was any topic such as this I could not find any for this year.
How are we supposed to wire in the window motor for this year? There is black plug in on the motor but, we can seem to find anything that plugs into it. Has one else came across this problem.
Unread 20-01-2007, 12:33
jgannon's Avatar
jgannon jgannon is offline
I ᐸ3 Robots
AKA: Joey Gannon
jgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond repute
Re: plug in for window motor
The kit does not come with a wiring harness for the window motors. I'm not sure if the connector is the same as in past years (I don't have one in front of me right now), but in the past I've used insulated female quick-connect crimp terminals to slide onto the window motor pins. Give the non-crimp end of the connector a little squeeze with pliers first to make the opening more narrow narrow so it will stick on the pin better.
Team 1743 - The Short Circuits
2010 Pittsburgh Excellence in Design & Team Spirit Awards
2009 Pittsburgh Regional Champions (thanks to 222 and 1218)
2007 Pittsburgh Website Award
2006 Pittsburgh Regional Champions (thanks to 395 and 1038)
2006 Pittsburgh Rookie Inspiration & Highest Rookie Seed
Team 1388 - Eagle Robotics
2005 Sacramento Engineering Inspiration
2004 Curie Division Champions (thanks to 1038 and 175)
2004 Sacramento Rookie All-Star
_
Unread 20-01-2007, 12:47
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
I seem to recall that this issue is addressed in the Guidelines, Tips, and Good Practices manual.
it is recommended reading even if it doesn't answer your question....
Unread 20-01-2007, 13:27
AKA: Barbara Boyles
G.5.3.4 Keyang window motors
Both left hand and right hand versions of the Keyang Window
motors are supplied in the KOP. These motor/gearbox
assemblies have an automotive quick-connect 2-piece electrical
connector supplied in the Terminal bag.
The kit includes (2 ea.) couplings to mate the output gears of
the Keyang window motors to drive various mechanisms.
Check your couplers! The window motor output gear on the
İFIRST 2007 FIRST Guidelines, Tips, & Good Practices, Rev A Page 11 of 43
Keyang motor is also 9-toothed, but it is not identical with the Nippon Denso motor.
We found the connecter do we soldering in the wires??
Unread 20-01-2007, 14:15
jgannon's Avatar
I ᐸ3 Robots
AKA: Joey Gannon
I forget that there are two different kinds of window motors this year. My advice was for the Nippon-Denso motor... I haven't taken a look at the Keyang connector yet. That would explain what the weird connector in the terminal bag was, though.
_
Unread 14-02-2007, 19:43
ChrisMcK2186's Avatar
ChrisMcK2186 ChrisMcK2186 is offline
Typer of doom
AKA: Chris McKenzie
FRC #2186 (Westfield Robotics)
ChrisMcK2186 is a glorious beacon of lightChrisMcK2186 is a glorious beacon of lightChrisMcK2186 is a glorious beacon of lightChrisMcK2186 is a glorious beacon of lightChrisMcK2186 is a glorious beacon of lightChrisMcK2186 is a glorious beacon of light
Send a message via AIM to ChrisMcK2186
how would we wire it to the connector? We are in dire need of advice here, being <1 week till ship.
Chris
Working on Robotic Eagles group(PM for info)
Stephen Colbert-"Please tell me this leads to robot
battles."
Dean Kamen-"It does lead to kids building robots, and they do compete in the sport but we also teach the kids gracious proffesionalism, so while the robots are competing, they do it in a very, very gracious way."
Darn, I got into this for the battles!
Unread 19-02-2007, 13:01
NeedMoreEngines's Avatar
NeedMoreEngines NeedMoreEngines is offline
AKA: Mike
FRC #1279 (Cold Fusion)
Team Role: Driver
NeedMoreEngines has a spectacular aura aboutNeedMoreEngines has a spectacular aura about
Send a message via AIM to NeedMoreEngines
I'm gonna solder the wires, but which is positive and which is negative? lol we cut off the plastic outer connector and i think it may have had the symbols on it.
or does it not matter?
can someone reply ASAP?!?!
"There is only one solution to this problem- We need more engines."
The good thing about the YMCA is if you can spell, you can dance.
Proud Eagle Scout
Unread 19-02-2007, 13:10
tdlrali tdlrali is offline
FRC #0469 (Las Guerrillas)
tdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud of
The polarity is not important. Wire it either way, and adjust the direction it is turning through programming (or switch the wires on the victor output).
We just connected it with female spade connectors.
Unread 07-02-2008, 20:56
Stillen Stillen is offline
Stillen is just really niceStillen is just really niceStillen is just really niceStillen is just really niceStillen is just really nice
Send a message via ICQ to Stillen
my question/comment concerns the G.5.3.4 Keyang window motors..... We received two.... One has the GM typre connector, which we did receive in the kit of parts. The second motor has a different type of connector looks to be the same type from a nissan or honda vehicle
Mike
TEAM 549
Unread 16-02-2008, 18:33
The_Ravioli_Man's Avatar
The_Ravioli_Man The_Ravioli_Man is offline
is A Dew Drinker for Life! Woot!
AKA: Justin
FRC #2028
The_Ravioli_Man will become famous soon enoughThe_Ravioli_Man will become famous soon enough
Send a message via AIM to The_Ravioli_Man Send a message via MSN to The_Ravioli_Man
Thumbs up Re: plug in for window motor
a mentor and I just went to some local autopart stores to see if we could find the right hook-up for the -023 motor and we believe we found a match. If you all still need to find this part, go to your local autopart store and tell them part number EC86, it looks very, very, very close to the hook-up required for it.
Just thought I would let everyone else know in good sportsmanship
Representin that 116 Clique & The Salvation Squad til the day I die!
{116 Clique} I am not ashamed of the gospel, because it is the power of God for the salvation of everyone who believes. (Romans 1:16)
But He was pierced for our transgressions,
He was crushed for our iniquities;
the punishment that brought us peace was upon Him,
and by His wounds we are healed.
Isaiah 53:5
Do not let any unwholesome talk come out of your mouths, but only what is helpful for building others up according to their needs, that it may benefit those who listen.
Ephesians 4:29
NOTW = Not of This World
I wanna finish last,
last in the world's eyes.
no matter what I do,
I will be first in Your eyes
Finish Last - Stellar Kart
pic: Sprocket mounting for window motor team222badbrad Extra Discussion 3 22-02-2005 03:06
Gear Coupling for Jideco Window Motor hayakuneko Motors 4 30-01-2005 18:35
Mating gear for the window motor? nwbutterfly Motors 2 24-01-2005 10:53
Please help asap.. Where do the victor motor 3 pin wires plug into 1166 Electrical 10 16-02-2004 12:07
Plug for the big yellow ball wun Kit & Additional Hardware 22 15-01-2004 14:54
