Go to Post In racing, speed is measured in cubic dollars. In FIRST, success is measured in cubic skill. - Billfred [more]
Unread 01-02-2008, 17:27
Bruceb's Avatar
Bruceb Bruceb is offline
FRC #0706 (Cyberhawks)
Bruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to behold
Slowing a piston with full power
Is there a way to make a piston travel slower but with full power?? Like some kind of flow restrictor?
Thanks
Bruce
Unread 01-02-2008, 17:32
Re: Slowing a piston with full power
Thanks
Bruce
Yes. There are some right angle turns (threaded on one side) in the KOP that have a small white knob on one side. The knob is a flow controller.
Unread 01-02-2008, 17:40
IndySam's Avatar
IndySam IndySam is offline
FRC #0829 (Digital Goats)
Unread 01-02-2008, 17:44
AndyH's Avatar
AndyH AndyH is offline
FRC #1098 (Rockwood Robotics)
AndyH has much to be proud ofAndyH has much to be proud ofAndyH has much to be proud ofAndyH has much to be proud ofAndyH has much to be proud ofAndyH has much to be proud ofAndyH has much to be proud ofAndyH has much to be proud ofAndyH has much to be proud of
You can also try getting a pipe plug and drilling a small hole in the plug and screw it in the exhaust port of the air valve. This will slow the exhaust and therefore slow the piston. It works well and you simply keep drilling out the hole till the desired piston speed is achieved. You can also get adjustable flow control valves. I like the pipe plug trick because once it is correct it can not be adjusted and messed up. I use this in industrial applications all the time.
Unread 01-02-2008, 18:01
dlavery's Avatar
dlavery dlavery is offline
Curmudgeon
FRC #0116 (Epsilon Delta)
Do not do this. While it may be acceptable in some industrial applications, it is not acceptable on an FRC robot. Read the rules in Section 8.3.4 very carefully.
Just stick with the suggestion to use the flow control valves provided in the Kit Of Parts. They are provided for just this purpose.
-dave
Unread 04-02-2008, 11:34
Brian C's Avatar
Brian C Brian C is offline
Doer of Whatever
AKA: Brian Cholerton
FRC #1468 (J-Birds)
Brian C has a brilliant futureBrian C has a brilliant futureBrian C has a brilliant futureBrian C has a brilliant futureBrian C has a brilliant futureBrian C has a brilliant futureBrian C has a brilliant futureBrian C has a brilliant futureBrian C has a brilliant futureBrian C has a brilliant futureBrian C has a brilliant future
One thing to remember about these flow control valves. They control the flow of air LEAVING the cylinder. They do not limit the flow of air entering the cylinder.
2017 Season; Game Announcer at
SBPLI Long Island Regional
Unread 04-02-2008, 12:04
dlavery's Avatar
Curmudgeon
That is not automatically true. It all depends on how you use them, and how you place them in the pneumatic circuit.
-dave
Unread 07-02-2008, 22:40
Andrew Schuetze's Avatar
Andrew Schuetze Andrew Schuetze is offline
499 Founder / Alamo FTC & FLL AP
Andrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond repute
A quick study would seem to indicate that one would only need to constrict the flow of air entering the piston on the stroke one wants to limit the speed as the other side is open the atmosphere and just vents. However, taking this to an extreme limit though, if you completely or nearly completely close the needle valve on the vent side then is will limit the flow significantly and slow things down.
So here is my question, is it possible to use various settings on valves on both ends such that on the out stroke you have one speed and then on the in stroke a significantly different speed. a.ka. out - slow .... in - faster
Thanks,
APS
APS
Founder FRC 499
Parent alumni FRC 2745 & 4219
Co-Coach FTC 4549 & 6407
Alamo FTC Affiliate Partner
Alamo FLL Affiliate Partner
Unread 08-02-2008, 00:41
TubaMorg TubaMorg is offline
Programmermechanicalelect ricalcoach
AKA: Dan
FRC #1480 (Robatos Locos)
TubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond repute
Thanks,
APS
This would be possible, but you would need to mount the needle valves at the solenoid exhaust ports to be effective. If you mount the needle valves on the cylinders, air flow will be throttled in both directions which would prevent varying the speed per cylinder direction.
Unread 08-02-2008, 02:13
Jeff K.'s Avatar
Jeff K. Jeff K. is offline
Hmm..now what?
FRC #1138 (Eagle Engineering)
Jeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond repute
Send a message via AIM to Jeff K. Send a message via MSN to Jeff K.
We did this last year by putting one on each end of the piston, and adjusting each one accordingly. The best way to find out how it affects it is by adjusting one side a little, and then firing it back and forth and seeing how it reacts.
You can get them pretty different, just try and see what works best for your application.
You can have them on either the solenoid portion or the piston portion, won't really affect it that much since the air flow is mostly controlled by the small diameter of the adapters and plugs more than anything.
need some help with piston coolguybigt Chit-Chat 1 03-04-2007 15:22
Tagging Pictures with Full Names Jaine Perotti CD Forum Support 3 06-04-2006 09:35
Is FIRST slowing down with it's updates! mtaman02 Regional Competitions 8 15-03-2004 23:25
how do i control a piston with a joystick Ryan Foley Programming 2 27-05-2003 17:13
Piston power? archiver 2001 2 23-06-2002 22:51
