Go to Post We may not build the best robots but we're building better students in the long run and means much much more. - Koko Ed [more]
Unread 04-02-2008, 15:31
akash155 akash155 is offline
Akash
FRC #0540 (Team 540 Screaming Eagles)
Team Role: Tactician
akash155 is on a distinguished road
Send a message via AIM to akash155
Fisher Price Gearboxes
What are some small gearboxes that you can add to a fisher price? How do you interface a banebot planetary to a fisherprice and which one would you use? thanx
Unread 04-02-2008, 15:34
AdamHeard's Avatar
Lead Mentor
Re: Fisher Price Gearboxes
To interface the banebots planatery to a FP motor you just press on the appropriate pinion (sold by banebots) and bolt the motor into the gearbox.
For the FP motor, I'd stick to the 42mm gearboxes and stick the 108:1 ratio or less. According to Joe Johnson's calculations and my personal experience, a ratio of 140ish:1 or more is asking for trouble. Some teams have had no problems with the 256:1s, but I'd play it safe and use the lower reductions.
Unread 05-02-2008, 15:30
Rob2713g's Avatar
Rob2713g Rob2713g is offline
FRC #0540 (Screaming Eagles)
Rob2713g has a spectacular aura aboutRob2713g has a spectacular aura aboutRob2713g has a spectacular aura about
What is the gear ratio in the fisher price gearbox if the final reduction is not used?
2007 - NASA/VCU Regional Winners (Thanks 2108 & 843!)
2006 - Championship Curie division
2006 - NASA/VCU Semi-Finalists (Thanks 510 & 587!)
2005 - NASA/VCU Quarter-Finalists (Thanks 388 & 619!)
Unread 05-02-2008, 15:58
AdamHeard's Avatar
Lead Mentor
Count the teeth on the final stage to determine its ratio. The final ratio will be 124:1 divided by that.
Unread 07-02-2008, 22:41
Rob2713g's Avatar
Is it possible to easily attach the fisher price motor to the 25:1, 36mm Planetary Gearmotor, RS-545 Motor? Would there be any problems with this configuration?
Unread 08-02-2008, 01:03
AdamHeard's Avatar
Lead Mentor
In that low of a ratio, the 36mm probably won't be a problem.... But I'd personally go to the 42mm 27:1 just because It is much beefier and more durable.
Also, yes it is possible and easy. Just press the appropriate pinion on, and the correct bolt pattern is already there.
fisher price Futbol.195 Electrical 8 20-01-2008 16:47
Fisher-Price Motors popo308 Motors 11 03-08-2007 22:05
Mounting Fisher Price Gearboxes Bochek Technical Discussion 8 09-02-2007 16:34
Fisher Price Gearboxes Heretic121 Motors 2 30-01-2006 21:38
Fisher Price Gearboxes Nathan Pell Motors 7 06-03-2004 11:29
