Go to Post One of these years, the game piece will be an actual red herring. - Taylor [more]
Unread 07-02-2008, 11:31
hinewwiner hinewwiner is offline
hinewwiner is an unknown quantity at this point
ADXRS150 Gyro Yaw Sensor sensitivity?
Hello.
I am trying to use ADXRS150 sensor but I am not sure the sensitivity of the sensor. How many volts does it go up(or down) with one degree rotated? Is this on the spec sheet? (I can't find this...)
Thank you
Unread 07-02-2008, 11:53
TubaMorg TubaMorg is offline
Programmermechanicalelect ricalcoach
AKA: Dan
FRC #1480 (Robatos Locos)
TubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond repute
Re: ADXRS150 Gyro Yaw Sensor sensitivity?
Spec sheet says: 12.5 mV/deg/sec
Remember it is a yaw RATE gyro which means voltage changes from 2.5 V nominal proportional to how fast the turn is as opposed to how far it turns.
Unread 07-02-2008, 16:29
marccenter's Avatar
marccenter marccenter is offline
FRC #3548 (RoboRavens2)
marccenter has a spectacular aura aboutmarccenter has a spectacular aura about
This means that in order to test the signal by yourself you have to spin the sensor and read it at the same time. When it operates properly,if you spin it in one direction (your choice), the voltage either climb to nearly 4.375 volts or fall to nearly 0.625 volts. When you spin the gyro in the opposite direction (your choice), the voltage climb/fall will be opposite before. This is a very simple test to make sure your sensor is operational. When stationary, the gryo will read about 2. 5 (+/- 0.1 volts).
Hope this helps. - Voltage correction added after comment by Alan Anderson - 02-08-08 MBC
Marc Center
FIRST FRC Mentor/Coach - Team 3548 Royal Oak RoboRavens#2 - on Sabbatical 2017 season
marc.center@gmail.com
Mobile: 248-255-7377
Last edited by marccenter : 08-02-2008 at 09:21. Reason: Critique by Alan Anderson
Unread 07-02-2008, 22:48
Originally Posted by marccenter View Post
When it operates properly,if you spin it in one direction (your choice), the voltage either climb to nearly 5.0 volts or fall to nearly 0.0 volts.
The sensitivity is 12.5 millivolts per degree/second. The maximum rate is 150 degrees/second. That means the maximum deviation from neutral is 1875 millivolts, yielding an output that ranges from .625 volts to 4.375 volts. It's nit-picking, I know, but I wouldn't call that "nearly 0.0" or "nearly 5.0" volts.
Unread 08-02-2008, 07:02
chris31 chris31 is offline
Team 2021 Captain
AKA: Chris Davidson
FRC #2021 (FA Robotics)
chris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond repute
Send a message via AIM to chris31
If I am reading the rules correctly, you cannot use the ADXRS150 from the 2007 KOP. Is this correct?
Unread 08-02-2008, 09:20
marccenter's Avatar
Thanks Alan for catching my "goof". It would have been more accurate for me to say something like "rising in the direction towards 5V" or "falling in the direction towards 0V" rather than assigning an absolute value. I will update my original post with your values of 0.625 volts and 4.375 volts.
Marc Center
Yaw Rate Gyro Problems RetroKamikaze Programming 3 27-01-2006 20:55
ADXRS150 gyro yaw rate sensor Brian M. Electrical 13 17-10-2004 02:28
ADXRS150/300 Sensor m0rph3us Electrical 2 06-02-2004 22:37
Yaw rate sensor (gyro for the layperson) Kris Verdeyen Rules/Strategy 4 14-01-2002 00:41
