Go to Post We can still do better, even if we've come a long way. - cadandcookies [more]
Unread 07-02-2008, 22:57
manderson5192 manderson5192 is offline
AKA: Matt Anderson
FRC #0948 (Newport Robotics Group: NRG (pronounced eNeRGy))
manderson5192 is on a distinguished road
What's Wrong with our Gyro???
Hey guys,
We have hooked up our gyro properly (found out about the weird naming convention for TW vs. RW the hard way) and have the gyro code working in what seems to be the right way. What we have seen is that the gyro will detect the angular velocity in one direction the proper way but spit out random numbers for the other direction. When we flip the gyro upside down the results are the same but, as expected, the working direction is the other one. My question is: how do we make the gyro give reliable results in both directions? We are using the 2008 KOP gyro.
Thanks,
Matt
Unread 08-02-2008, 00:31
TubaMorg TubaMorg is offline
Programmermechanicalelect ricalcoach
AKA: Dan
FRC #1480 (Robatos Locos)
TubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond repute
Re: What's Wrong with our Gyro???
Could you post your gyro code? I'm guessing you are having a type over flow problem. For example you may be assigning a negative value to an unsigned int which will give you nutty output in that direction.
Unread 08-02-2008, 00:40
AKA: Matt Anderson
The code we are using is exactly what is in Kevin Watson's latest C18 3.0 code. The gyros are fully enabled and we are using his code for outputting the gyro_rate to the terminal window.
Unread 08-02-2008, 01:51
Kevin Watson's Avatar
La Caņada High School
FRC #2429
When you do a bias calibration, what value do you get?
-Kevin
Kevin Watson
http://kevin.org
Unread 08-02-2008, 09:08
Bluefire66's Avatar
Bluefire66 Bluefire66 is offline
AKA: Alex Girard
FRC #0843 (The Wildcats)
Team Role: Electrical
Bluefire66 is an unknown quantity at this point
i think my team is having the same problem with it spitting out randon numbers(im not the programing team) so ill ask them tomorrow
2007 VCU Regional CHAMPIONS
pic: What's wrong here? Branden Ghena Extra Discussion 15 30-03-2007 11:20
Something Wrong with usfirst! Eric W. Jones General Forum 5 09-01-2007 02:01
You cant go wrong with charitys! A.Lathrop Fundraising 0 20-02-2006 19:16
pic: What's wrong with this picture - Why were we shut off? CD47-Bot Extra Discussion 12 04-10-2004 19:16
Whats wrong with this code? Morgoth Programming 4 19-01-2003 11:45
