Go to Post Before you fix something, it's worthwhile to make a concerted effort to figure out why it failed. - Ether [more]
Unread 08-02-2008, 00:15
seanwitte seanwitte is offline
None #0116
seanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant future
Send a message via AIM to seanwitte
Re: White Paper Discuss: .NET (2.0) Composite Dashboard Viewer
The 2008 Control Library has a few .NET 2.0 dashboard controls. All controls are updated using the Value property. The controls will render themselves to fill space provided. If the size is invalid it may display an exception in the designer. You can clear the exception in the designer by resizing the control to valid dimensions and reopening the designer. The compass will always render as a square and the gyro will render as a rectangle with 2:1 aspect ratio.
1) CompassControl - displays a heading value. Use the MinValue and MaxValue properties to set the upper and lower bounds. Use ArrowDirection to adjust for clockwise/counter-clockwise rotation (value is 1 or -1). Use ArrowOffset property to adjust where the min value is rendered.
2) PwmControl - displays PWM value as a double-headed arrow.
3) GyroControl - displays an analog value that has a zero value centered in the total range. Use the MinValue and MaxValue properties to set the range displayed.
4) RangeControl - displays range information. Use the Invert property to display the inverse depending on the sensor being used. Use the MinValue and MaxValue properties to set the range.
White Paper Discuss: NEMO White Paper: 25 Ways Sponsors Can Help Your Team Jessica Boucher Extra Discussion 1 20-11-2005 20:01
White Paper Discuss: .NET Composite Dashboard Viewer seanwitte Extra Discussion 8 06-04-2005 00:15
White Paper Discuss: 2004 Visual Basic 6 Dashboard Control CD47-Bot Extra Discussion 2 01-02-2005 01:56
White Paper Discuss: 2004 .NET dashboard control dll CD47-Bot Extra Discussion 7 13-01-2005 17:32
White Paper Discuss: Team 810's 2004 Dashboard Backend CD47-Bot Extra Discussion 1 07-03-2004 10:32
