Go to Post We may not build the best robots but we're building better students in the long run and means much much more. - Koko Ed [more]
Unread 07-02-2008, 02:24
thatmorman's Avatar
thatmorman thatmorman is offline
David
AKA: David
FRC #1510 (Wildcats)
thatmorman will become famous soon enough
Send a message via AIM to thatmorman Send a message via MSN to thatmorman
building a trailer
Hi, i was wondering if anyone has experience in building a fully covered trailer from nothing but a chasiss. what type of materials and thicknesses, what is the best structural support, etc... thanks
David Cobbley
Captain & Mechanical Leader
Team 1510
I <3 inventor & anyone in FIRST
Unread 07-02-2008, 06:51
tdlrali tdlrali is offline
FRC #0469 (Las Guerrillas)
tdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud of
Re: building a trailer
I'm not sure if that's even possible, since trailers have to fulfill all kinds of specifications. I'd suggest looking up your state's requirements for registering a trailer, I have no idea where to start.
Unread 08-02-2008, 04:39
thatmorman's Avatar
David
AKA: David
you do not have to register a trailer if it will carry less than 8000 pounds, we bought it from someone who was going to fix it up but didn't have the time... so it is possible, we've already discussed with our mentors, just lookin for any designs tips or ideas...
David Cobbley
Team 1510
Unread 09-02-2008, 03:09
Jeremiah Johnson's Avatar
Jeremiah Johnson Jeremiah Johnson is offline
Go VOLS!!
AKA: Budda648
no team (QC Elite)
Jeremiah Johnson has a reputation beyond reputeJeremiah Johnson has a reputation beyond reputeJeremiah Johnson has a reputation beyond reputeJeremiah Johnson has a reputation beyond reputeJeremiah Johnson has a reputation beyond reputeJeremiah Johnson has a reputation beyond reputeJeremiah Johnson has a reputation beyond reputeJeremiah Johnson has a reputation beyond reputeJeremiah Johnson has a reputation beyond reputeJeremiah Johnson has a reputation beyond reputeJeremiah Johnson has a reputation beyond repute
Send a message via AIM to Jeremiah Johnson Send a message via MSN to Jeremiah Johnson
Pop rivets and aluminum... What exactly do you want to know? Cut down on wind resistance w/ as many curves as possible on the corners and edges.
Do The Tyler!
XBOX Live Gamertag = theVelvetLie
Unread 09-02-2008, 21:17
Jay H 237 Jay H 237 is offline
Down at the railroad
AKA: Jason Hartmann
FRC #0237 (Black Magic)
Jay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond repute
Send a message via AIM to Jay H 237
I built an open utility trailer from scratch, but not an enclosed one. From what I'm gathering you're looking for something like the Featherlite here http://www.fthr.com/trailers/style_t...lity&cat =rec ?
They use an aluminum frame with an aluminum sheet as the exterior skin. As mentioned pop rivets are used for the skin and some of the cross pieces in the frame. The main frame parts are TIG welded to the chassis for strength.
What is the frame that you already have? How large will this trailer be? What do you want to do about doors?
Now keep in mind too what the total weight will be (gross) of the trailer PLUS the stuff in it. In some states it will require it's own brakes if it's above a certain weight and may require a second axle (tandem).
If the trailer will be large for safety's sake get a sway control for the hitch, last thing you want is a cross wind catching the trailer and making it sway and thus making the tow vehicle sway (especially with smaller tow vehicles). They call it "the tail wagging the dog".
237 did have a small enclosed trailer (8' Haulmark) that a previous mentor (now deceased) had purchased. Once that trailer was filled with our stuff it was much heavier, will trailers you have to remember that the contents weigh more that the trailer itself. He had no trouble bringing the empty trailer home with his Aerostar but once filled the Aerostar wouldn't pull it. Add in wind resistence and it gets worse.
2006 Maryland Delphi "Driving Tomorrow's Technology" award
2006 Connecticut General Motor's Industrial Design award
2005 Finalists-----------New Jersey (along with our alliances again, 56 & 303)
2005 WINNERS of the Radio Shack Innovation in Control Award (not once, but twice! )
2004 WINNERS ------ Johnson & Johnson Mid-Atlantic Regional (also thanks to our alliances 56 & 303)
2004 General Motors Industrial Design Award Winners
2004 Archimedes Quarterfinalists (also thanks to our alliances 121 & 386)
NEMO _________ NonEngineering Mentor Organization
"Make it idiot proof and someone will make a better idiot!" - author unknown
Unread 11-02-2008, 13:30
Andrew Y.'s Avatar
Andrew Y. Andrew Y. is offline
FunYun
AKA: Andrew Yun
FRC #2415
Andrew Y. has much to be proud ofAndrew Y. has much to be proud ofAndrew Y. has much to be proud ofAndrew Y. has much to be proud ofAndrew Y. has much to be proud ofAndrew Y. has much to be proud ofAndrew Y. has much to be proud ofAndrew Y. has much to be proud ofAndrew Y. has much to be proud of
Really?! We had to register our 1500lb. tboat trailer! I also would check that the trailers dont need to be DOT certified.
pic: 862 Trailer Joe J. Extra Discussion 7 06-03-2007 20:36
Halo 3 Trailer bestvids Chit-Chat 5 29-11-2006 11:44
To Trailer or Not to Trailer? Carol General Forum 14 25-06-2006 18:14
10mph Trailer Joe Matt Dean Kamen's Inventions 13 27-08-2005 12:17
Fahrenheit 9/11 - Trailer MattK Chit-Chat 22 06-06-2004 12:21
