Go to Post I'm excited. Probably too much, but eh, I'm a big geek. - Brandon Martus [more]
Unread 07-02-2008, 22:40
A.Tup's Avatar
A.Tup A.Tup is offline
AKA: Adam
FRC #2620 (Village Idiots)
Team Role: Driver
A.Tup is an unknown quantity at this point
Send a message via AIM to A.Tup
Joystick help (Rookie)
Hello everyone I was wondering if there is a way to change the sensitivity of the joysticks right now we barely touch them and the wheels go we would like a little less sensitivity help greatly appreciated
A.Tup
2620
Unread 08-02-2008, 00:52
PrincessJae's Avatar
PrincessJae PrincessJae is offline
FRC #2543 (Titan-Bot)
Team Role: Electrical
PrincessJae is infamous around these partsPrincessJae is infamous around these partsPrincessJae is infamous around these partsPrincessJae is infamous around these parts
Send a message via AIM to PrincessJae
Re: Joystick help (Rookie)
its in the programming code, i dont remember exactly because im not at school but i can probably help you tomorrow. What our team did was make three different "gears" you could call them for reverse, and 5 for forward, so that you gradually get faster.
Unread 08-02-2008, 04:59
RyanCahoon's Avatar
FRC #0766 (M-A Bears)
The following code will scale down your joystick sensitivity:
if your original code was
pwm01 = p1_y;
change it to:
pwm01 = ( ((signed int)p1_y) - 127 ) / 2 + 127;
Change pwm01 and/or p1_y according to which PWM output and joystick you are using. You can change the scaling factor by changing the 2 (right now it's set to 1/2). For example, to set it at 1/3 power, change the 2 to a three. If you want to use a fraction like 2/3, change / 2 to * 2 / 3. Note: use fractions this way and not decimals, as it will make your code run faster because it only does integer math.
Hope that wasn't too confusing,
--Ryan
Edit: That's for MPLAB. If you're using EasyC, I'm not sure if I can help as much.
Unread 08-02-2008, 08:26
kylelanman's Avatar
kylelanman kylelanman is offline
Programming Mentor
AKA: Kyle
FRC #2481 (Roboteers)
kylelanman is a name known to allkylelanman is a name known to allkylelanman is a name known to allkylelanman is a name known to allkylelanman is a name known to allkylelanman is a name known to all
This thread has great solution that uses a cubic function.
http://www.chiefdelphi.com/forums/sh...ad.php?t=63069
Unread 08-02-2008, 10:09
A.Tup's Avatar
AKA: Adam
Team Role: Driver
ok thank you all for all the help
Unread 08-02-2008, 10:32
Mr. Lim Mr. Lim is offline
AKA: Mr. Lim
A.Tup
2620
This thread is from 2004. It's a cubic transfer function like above.
http://www.chiefdelphi.com/forums/sh...2&postcount=54
Good luck!
Unread 08-02-2008, 10:33
Adam,
Something no one mentioned is to ask the question "Are your speed controllers calibrated?" Quite often, the Victors do not match the charachteristics of your joysticks. Move your joysticks forward and reverse and see at which point the Victor LED is fully red and fully green. If this occurs at less than full travel on the joystick, you need to calibrate the Victor. For teams who do not perform this calibration in the software, the only way to calibrate is following the method in the 884 users manual found on the IFI website. This procedure matches the full travel of your joystick to the full output of the Victor. The joysticks and the Victors are not matched before they are put in the KOP.
Unread 08-02-2008, 11:51
A.Tup's Avatar
AKA: Adam
Team Role: Driver
ok thank you i will check that next time in with the robot thanks again
Unread 10-02-2008, 13:32
corcarter's Avatar
corcarter corcarter is offline
AKA: Corey
FRC #2620 (TBA)
corcarter will become famous soon enough
Send a message via AIM to corcarter
i think our driver just needs to learn how to drive!!!!!
good year fellas and ladies, good year
Help with joystick lightning_blast Programming 2 12-02-2006 22:25
Rookie help doyler Technical Discussion 55 11-01-2005 08:59
VB6: Joystick help! Astronouth7303 Programming 0 15-06-2004 17:05
Changing 1 joystick code to 2 (rookie team) Brawler006 Programming 5 20-02-2004 17:00
Joystick Help archiver 2001 0 24-06-2002 01:02
